Anthem AVM 60 Preamp Processor Review: Conclusion
Anthem's AVM 60 preamp processor could be considered a high end bargain.
Anthem’s AVM 60 brings long-awaited immersive audio support to those who crave two-channel quality in a multi-channel preamp. Simply put, the AVM 60 is a sweet-sounding sonic powerhouse. Two-channel, multi-channel, or immersive audio are handled with all the finesse, detail, control, and emotion you’d expect in a high end preamp. Pair the AVM 60 with first-rate amplification and you’ll lose yourself over countless nights with any movie or artist you chose.
For custom installers, you might need to rely more on the feature set of home automation controllers to perform some of the things that the past AVM-series did natively. Oh, and should you encounter a minor bug here or there, you can rest assured that you’ll be backed by some of the best and most passionate support in the business. Considering that the AVM 60 is now $3,500 cheaper than it’s predecessor; adds more processing horse power; supports immersive audio; can stream hi-res music files; and comes with one of the best room correction solutions in the business, you might even consider it a bit of a high-end bargain.
Anthem AVM60 11.2CH AV Processor YouTube Review
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Multi-channel Audio Performance | ![]() ![]() ![]() ![]() |
Two-channel Audio Performance | ![]() ![]() ![]() ![]() |
Network Features | ![]() ![]() ![]() ![]() |
Bass Management | ![]() ![]() ![]() ![]() ![]() |
Fit and Finish | ![]() ![]() ![]() |
Ergonomics & Usability | ![]() ![]() ![]() ![]() |
Ease of Setup | ![]() ![]() ![]() ![]() |
Features | ![]() ![]() ![]() |
Remote Control | ![]() ![]() ![]() |
Performance | ![]() ![]() ![]() ![]() ![]() |
Value | ![]() ![]() ![]() ![]() |
See also:
Recent Forum Posts:
1. How do you hookup the STR preamp to the Yamaha cxa5100, Does it get hooked up as an output or an input on the Yamaha?
2. Will this work if you are running biamped on your front 3 channels?
3. When you run YPAO on the Yamaha do you not run the front channels, or are you not running Athems room tune software?
Erod, post: 1343970, member: 89019I just turned mine off did it all manual that's what I usually do with all my recievers although I ran Genesis multiple times it never changed my Dolby offset from 0
ARC Genesis sets my Dolby offset to -12 so the overall system baseline is based on 100dB.
The result is, my levels end up being around 62dB. I think it does this so that all my channels hover closer to 0. I generally get -3 or -4 with my fronts, and +2 to +6 with surrounds and ceiling atmos speakers. My sub ends up at around -5.
As a result, my volume control typically sits between -25 and -15, depending on source material.
Sounds awesome, but I've never had a room correction change my baseline off of 75dB like this. Genesis is the first to do that.
That's interesting it did that for your setup
VonMagnum, post: 1343782, member: 86028Cool yes I did normally I am just fine with -35 if I want to get crazy max I can realistically handle is around -27 so I'm in good shape for where I want the room to be. Thanks!!!
If you ran room correction calibration, reference is normally 0.
