RBH Sound PM-8 Active Monitor Loudspeaker Review
- Product Name: PM-8 Monitor Speaker
- Manufacturer: RBH Sound
- Performance Rating:
- Value Rating:
- Review Date: November 12, 2020 00:15
- MSRP: $ 1,595.95 each standard, $1,995.95 each w/ accent panels
- System type: Active (Powered) 2-way Monitor Speaker
- Amplifier type: Bi-amplified Class D
- Frequency Response: 32Hz-20kHz (±3dB)
- Woofer: (1) 8" (203mm) Reference Aluminum Cone
- Tweeter: (1) 1.38" x 1" (35mm x 25mm) AMT
- Woofer amplifier: 250-watts RMS
- Tweeter amplifier: 150-watts RMS
- Voltage: 110V-240V Auto Adjusting
- Crossover Frequency: 2,500 Hz
- Crossover Slope: 48dB/Octave
- Line Level Input: Yes (XLR/Adapter)
- Cabinet/Color: Medium Density Fiberboard (MDF)/Black
- Grille: Black Fabric
- Dimensions: 11-3/8" W x 19-1/4" H x 13-5/16" D
- Weight: 43.35 lbs. (19.7 kg)
- Warranty: 5 years cabinet & woofers/3 years amplifier
- Flat on-axis response
- Extraordinarily good vertical dispersion
- Tremendous bass ability for its form factor
- Wide dynamic range
- Superb imaging abilities
- Accent panels add a classy look
- Accent panels have a substantial surcharge
- Background hiss audible in near-field distance
RBH Sound PM-8 Introduction
RBH Sound raised a few eyebrows at the 2019 CEDIA show when they
unveiled the PM-8 studio monitor
which is a product for a very different market
than RBH’s traditional focus of home audio. Perhaps it shouldn’t have been as
much of a surprise since the requirements of studio monitors and home audio
loudspeakers have a multitude of similarities. The only significant differences
are that monitors need to have the appropriate connectivity to work in a studio
environment, and that monitors, more than home audio loudspeakers, should strive
to have an accurate sound that is faithful to the source signal. One would hope
that typical home audio speakers would have some accuracy, but often they can
be designed to sound ‘good’ rather than accurate. That isn’t necessarily a bad
thing, but it can complicate things especially when accuracy has been shown to
sound ‘good’ in tests of human listening preferences. Seeing as how accurate
sound also happens to sound good, it stands to reason then that studio monitors
with ostensibly accurate sound should also be very good for recreational
listening. That is what we will be looking at today since we have a pair of the
PM-8s in for review…
Packing and Appearance
The PM-8s arrived well packed, but they had better be, given the
weight and their cost of $2,000 each. These are very heavy for studio monitors,
weighing twice as much as most of the monitors I have dealt with to date. They
came double boxed with thick polyethylene blocks sandwiching the speakers along
with edge protectors to reinforce the box edges. Once out of the packing, they
PM-8s are revealed in their full majestic glory. These are large studio
monitors, and, as if to emphasize their stately size, there are ½” slabs of
polished engineered stone attached to the side panels. That is an unusual
design decision by RBH Sound, to say the least. Most studio monitors don’t really
make too much of a concession to aesthetics, and they are a product more often
driven by function than form. Perhaps it is because RBH is a newcomer to the
studio monitor market that they thought a monitor should look so fancy. Or
perhaps they are trying to separate themselves from other manufacturers who
tend toward a utilitarian appearance in their monitors. To be fair, the PM-8s
do come in a version that does not have these engineered stone accent panels,
and that version carries a significant $400/ea or $800/pr savings. However, they have a lot
less visual charm, and, of course, the panels do have a functional purpose as
well, which we will discuss in the ‘Design Analysis’ section below.
Outside of the accent panels, the PM-8s are finished in a flexible laminate that almost resembles leather. It is more durable than conventional vinyl veneers, and you don’t have to worry about fingerprint smudges marring the finish. It looks nice and ‘leathery’ without being leather. The majority of the front baffle is occupied by a beefy 8” black aluminum cone with a 1.4” AMT tweeter hovering above it. The PM-8 can also be ordered with a silver metallic aluminum cone, but I think I like the look of the black cone just a tad more. There is a large port mounted on the lower end of the front baffle. One oddity about the PM-8s is that they are a studio monitor with a grille. Home audio speakers use grilles for aesthetic purposes (to hide the drivers) and for practical reasons (to protect the drivers), but studio gear isn’t normally very concerned about aesthetics and so very few monitors have grilles. Since they are workplace tools mostly just used around professionals, they aren’t as subject to physical abuse and so don’t really need grille protection. The grille itself is a formidable piece made with a ⅝” thick frame wrapped with a black, acoustically transparent fabric. It uses magnetic adhesion so there are no grille guides on the front baffle. Its inclusion among other design cues leads me to believe that RBH Sound expects the PM-8 to be used as a home audio speaker as well as a studio monitor. It looks higher-end than a studio monitor needs to, and I think that RBH wanted a speaker that will see use both in studios and in homes.
Design Analysis
The PM-8 is a big monitor. RBH’s product page states it is
intended for either near-field and far-field use, so the large size is a
consequence of the wider dynamic range it must have in order to accommodate
far-field use. You can’t get serious bass extension as well as serious dynamic
range in bass from a small cabinet, as that is prohibited by physics. As for
near-field use, a requirement for that is the design can not have the drivers
separated too far apart because the further apart that the drivers are, the
greater the distance needed for their respective sound fields to integrate.
This is why we don’t recommend that most tower speakers be used at proximity
closer than two meters, especially a three-way tower. The center-to-center
spacing of the drivers on the PM-8 seems close enough that it could easily work
for near-field duty, so while the speaker may be somewhat large, the sound
should integrate at a close distance.
The PM-8 looks to be using some high-quality components.At the top, it uses a 1"x1.39" AMT that was the best performing AMT tweeter that RBH Sound could source. AMTs normally have a dynamic range advantage over dome tweeters, especially in higher frequencies, so even though the AMT in the PM-8 is not especially large, it should still be able to pack a punch even in non-near-field listening distances. AMT tweeters can vary in quality by quite a wide range, and we have seen very problematic AMTs in inexpensive speakers that would have been better off simply using domes, and we have seen very well-behaved AMTs, but usually in more expensive speakers. To date, some of the best we have seen were manufactured by Aurum Cantus (used in RBH Sound SVTR System), so that bodes well for the tweeter in the PM-8.
The woofer uses an 8” aluminum
cone and is the same bass driver
seen in RBH’s flagship SVTR speakers. It has a sizable ½” surround and looks to
be very capable. Aluminum is a very good material for a woofer diaphragm on
account of its light weight combined with high stiffness. Its only drawback is
that the stiffness can make for some fierce breakup behavior in upper
frequencies if it is not low-passed sufficiently, but that is not at all a
problem for the PM-8 since it uses an active DSP crossover network. In fact,
the crossover uses a 48dB/octave slope, which would not at all be practical
with a passive design. That should be more than sufficient to keep the woofer
out of trouble. RBH also dopes the aluminum cone and uses a propriety butyl rubber surround to dampen cone resonances. The digital signal processing abilities of the amplifier gives
the speaker engineers far more freedom to control the performance of the
speaker than traditional passive methods.
The DSP on the PM-8 is special and is quite a bit more powerful than what is normally seen on active monitors. The reason for that is it uses finite impulse response filters or ‘FIR’ filters to handle crossover duties and equalization. FIR filters are much more resource-intensive than the standard IIR (infinite impulse response) filters seen on most active speakers but offer much greater control over the speaker’s acoustic performance. FIR filters can control time-domain performance as well as frequency domain behavior, unlike IIR filters. This means that the phase can be controlled, and the entire speaker can be made to be phase linear even at crossover frequency bands. This isn’t possible with IIR filters or in standard passive crossovers. In normal speakers, there must always be phase rotation around the crossover point, and many designs have gone to great lengths in order to minimize this, often at the expense of frequency response linearity. It is much more computationally intensive to use FIR filters and thus needs a much beefier processor, but it solves the problem of shifting phase at crossover points. The audibility of phase distortion has long been a subject of debate within auditory science with prominent figures such as Dr. Floyd Toole taking the position that human hearing is very insensitive to it. However, some new research suggests that phase distortion can have a deleterious effect on speech intelligibility. Audioholics does cover some of this new science in speech intelligibility in this thorough Livestream discussion on our Youtube channel. RBH leverages FIR filters to maintain phase linearity in the PM-8.
FIR Filters & Active Speakers YouTube Discussion with RBH Sound
The PM-8 has built-in Class-D amplification with separate amplifiers for the tweeter and woofer. The tweeter is given 150 watts of power and the woofer is given 250 watts, for a total of 400 watts per speaker, with a 2,500Hz crossover frequency. That is a tremendous amount of power, especially when considering that in typical passive speakers, there is quite a bit of loss occurring in the crossover network. The Class-D topology grants further efficiency by converting a lot more electrical current into power for drivers compared to more common Class-AB amplifiers that lose substantially more electricity as heat.
Speaking of efficiency, what is majorly beneficial for the efficiency of the PM-8 is the sheer size of it. Smaller loudspeakers can produce bass, but the power demands for low-frequency reproduction skyrockets as the enclosure size shrinks. This is a speaker with a large enclosure and a tremendously powerful amp, so it almost maxes out what can be done to increase low-frequency dynamics. In order to get the most from the cabinet, the PM-8 uses a very large front-mounted port that has a 2 ¾” diameter with a 9 ¾” depth. That is the kind of port that wouldn’t be out of place in a subwoofer, and it should provide the PM-8s with prodigious low-frequency capability.
Regarding connectivity, the amp only has an XLR input, but RBH
provi
des RCA to XLR adapters so that those who only have consumer-grade
preamplification will not have to purchase additional components to get the
speakers working. Nonetheless, I would encourage buyers to get a pre-amp with
balanced XLR outputs to ensure the cleanest signal path. After all, if you are
buying $3,000+ monitors, it is worth spending a few hundred extra for a decent
preamp (I can highly recommend the MOTU M2 for an inexpensive but
high-performance pre-amp with balanced outputs). The PM-8 also has a balanced
output in case the user wants to daisy chain another device on the same signal
such as a subwoofer. RBH tells me that they hope to add an AES digital
connection in the near future.
The amp has only two controls: a gain knob and a preset selector knob. The preset selector knob has eight settings that optimize the PM-8 for near-field or far-field use, implements an 80Hz high-pass filter for use with a subwoofer, trims the tweeter output by 3dB, and also changes the low-frequency extension. There are also three LEDs: one that indicates power, one indicating when the limiter is engaged, and an input signal indicator.
The cabinet is a stout affair that uses ¾” thick MDF paneling with two window braces to reduce panel resonance. The optional engineered stone side panels would also be extremely effective at eliminating panel resonance, although it does so at a very hefty surcharge. The internal sidewalls are lined with polyurethane foam and much of the interior space is filled with polyfill type stuffing. Those measures should be very effective at damping inner pressure waves. This build quality is very solid, as one would expect of a speaker at this price point.
Listening Sessions
I used the PM-8 monitors in two different rooms with different conditions to see how they could cope with different environments. I set them up on my PC desk which is essentially a quarter space, or a space enclosed by two boundaries. This desktop environment puts the listening distance at about 2.5 feet. I also set them up in my home theater room, which gave them lots of breathing room and a nearly free-space environment. This is a far more acoustically friendly environment for sound quality. The processor used was a MOTU 828x and MOTU M2 on PCs with Qobuz as the source for music. No subwoofers were used. I used these monitors to listen to completed recordings rather than content creation since this is a home audio publication, and we are more interested in seeing how these fare in a home audio application. I listened to the PM-8s in the preset ‘8’ which should yield the flattest response and deepest extension.
Music Listening
With all the calamity that has occurred in 2020 (so far), Ennio Morricone’s passing may well be what future scholars and culture literati will find most noteworthy about this tumultuous year as time erodes our present fleeting concerns, and art with merit transcends the moment to endure for future generations. With so much output, not every composition by Morricone was solid gold, but with roughly 500 scores to his credit, even a hit-to-miss ratio of ten to one would still grant him dozens of masterpieces, and Morricone certainly batted better than 0.1. To give the RBH Sound PM-8s a spin on something orchestral, I decided to seek out orchestral works by Morricone with a good recording quality by modern standards (i.e., no vintage scores), and a perfect fit for this purpose is ‘Morricone 60.’ This 2018 album has Morricone conducting the Czech National Symphony Orchestra, with whom Morricone has collaborated on a number of works, and the performed pieces are all classic Morricone compositions from films such as ‘Cinema Paradiso,’ ‘The Untouchables,’ ‘The Hateful Eight,’ and, of course, all of Sergio Leone’s major films. The production quality was as good as Morricone pieces have ever sounded, so I queued up the album to hear what the PM-8s could do.
On the PM-8s, the lead instruments had such fine definition that I
had to think this was a recording made on a soundstage rather than a concert
hall. However, the liner notes say it was recorded in seven different cities,
which I assume would be concert hall performances during a tour. It must have
been a consequence of whatever microphone techniques they used to record this
album, but it did have more precise imaging than typical classical music
albums. On tracks such as ‘Stage Coach to Red Rock,’ individual instruments had
very clear positioning. Tonal balance was good, although lead instruments
certainly had a greater presence than typical orchestral recordings, but that
is certainly due to recording techniques and mixing rather than anything this
sound system would affect. The dynamic range of the speaker seemed quite good
on the instances that I cranked the system. The bass sounded strong without
being inordinate or excessive. The last four tracks on the album were not
concert recordings but pulled from the original soundtracks, and it was
immediately obvious. This is not to say they sounded bad but ‘vintage’ rather
and did not have the instrumental separation and detail that modern recordings
can achieve. In the end, it was fun to relive these themes from so many classic
movies, especially when the recording and the sound system, the PM-8s, are of
such high quality.
I am not a fan of country music, however, years ago I inherited a
vinyl album collection that had a number of country records from the ‘70s, including
a few from Willie Nelson. I gave them a spin and found myself unexpectedly
enjoying Nelson’s leisurely pace, modest instrumental accompaniment, and
soulful lyrics. I have always intended to explore Nelson’s work further but
that ambition just didn’t seem to reach fruition. I noticed that Nelson
released a new album, and with access to Qobuz, I thought it would be a good
time to dig through his body of work. One album that I found particularly
enjoyable is ‘Spirit,’ recorded in 1995, which is one of the more minimalist
among Nelson’s works since the only instruments used are two guitars, a piano,
and a fiddle. This gives the album an intimate quality, and such sparse use of
instruments allows one to focus more on the sound of individual instruments. However,
first and foremost Nelson’s weatherbeaten voice as he sings about emotional ups
and downs in life, but mostly downs.
The first thing that leapt out from the first track onward is the dead center imaging of Nelson’s voice and lead guitar. The piano gets a wider spread over the soundstage, indicating that it was recorded with the microphone at close proximity. It was easy to distinguish the two guitars being used here: the fuzzy sound of a nylon string guitar and the sharper sound of a steel-string guitar. The fiddle is relegated to mostly a backing support of the main melody, so it is somewhat recessed compared to the other instruments. All these details were crystal clear on the PM-8s, and I don’t know how much more transparent this recording could be presented on any sound system. The PM-8s transported Nelson and his band to my living room, and the imaging had a nearly tangible quality, as if I could tell exactly where the players were in my room. The instruments and Nelson’s voice sounded richly textured and natural; I have to wonder how far this sound is from the intended sound of the mixing engineer, and I would guess not far at all. I enjoyed listening to Nelson’s ‘Spirit’ on these speakers, and I think that the PM-8s expressed the full extent of the fidelity of this album.
Meryem Aboulouafa has been rapidly gaining international
recognition for her debut album ‘Meryem’ that draws inspiration from divergent
sources, which cohere into a natural whole as well as her distinctive voice
that is both soothing yet heavy-hearted. The music here lay somewhere between
R&B, classical, and folk music and is not easy to pigeonhole. The classical
training of Aboulouafa gives the album a nearly cinematic quality, but bursts
of pop music as well as accents of traditional music from her Moroccan roots
add up to a unique and engaging sound. This unique mixture is pulled off with
enormous success, and the talented Aboulouafa most certainly has a bright
future ahead. The production quality is impeccable, and I decided to give it a
spin and listen to this album in its entirety on the PM-8 speakers since I had
only heard bits and pieces before.
From the first moments of this album, the PM-8s anchors Meryem’s voice squarely in the center of the soundstage. She is backed up by a simple sine wave synth bassline along with some traditional orchestral instruments, and everything is nicely balanced with the PM-8s never pushing the potent bass over to being dominant in the mix as other speakers with elevated bass might have done. Aboulouafa’s melodic mezzo-soprano voice was rendered with utmost detail, and one could hear every minor contortion of her vocal cord that she used to control her singing. Some moments on this album can turn positively operatic, and the PM-8s could easily scale to the wider soundstage and dynamic range on these big moments. Meryem’s backup instruments are well rendered but the only instrumentation that is given lead attention are the orchestral elements, and that surprised me since I had the impression that this was more of a pop music album. To be sure there is a strong pop vibe on many tracks, but the album as a whole is too diverse to categorize as pop music. It is very much a studio production and sometimes uses effects processors like wildly over-the-top chorus effects to create an unusual singing tonality such as on the track ‘Ya Qalbi’, and these were fun and interesting moments, especially on the kind of wide soundstage that the PM-8 could project. At the album’s conclusion, I again felt that the PM-8s delivered a balanced execution where all the components have distinction but add up to a harmonious whole.
For something on the wilder and more experimental side, I found an album with a
sound unlike any other in ‘Container’ by Shoeg. ‘Container’ can best be
described as a long-form industrial soundscape if that makes any sense. Its
33-minute runtime is composed of two tracks and has elements of ‘Glitch’ type
music with lots of distorted noise with deep bass drones underscoring much of
the music. For those who are seeking out new sounds and have the patience for
longer tracks, this is a fun ride, but I think that many listeners would be
turned off by the harshness of some of the sounds and its overall strangeness.
I decided that it would be a good demonstration of the PM-8’s capabilities due
to many of its spectrally dense passages along with extensive use of deep bass.
The PM-8’s design suggests high capability in low frequencies, and this album
might be a good test of that.
I decided to play this album loud, and let me tell you that the dynamic range of the PM-8s is no joke. The louder treble sounds could be absolutely piercing, and the bass reproduction had the presence of a subwoofer. I could feel air movement from the ports even though I was seated eight feet away. These two 8” woofers could rumble my room like a subwoofer would. The PM-8s are not as large as tower speakers, but they have tower speaker dynamics packed into a large monitor size. If you want tower speaker range but don’t want floor-standing speakers, these are definitely a viable solution. As purely electronic music, the soundstage is quite unnatural, and the PM-8s were able to realize ‘Container’s’ fantastical realm of sound to dizzying effect. It was like sliding down an avalanche while being chased by a metallic swarm of wasps in a panoramic setting like the Alpine mountains. This is what an ancient intelligent cybernetic insect species would regard as classical music. This album really benefits from a good sound system, and I don’t know how listenable it would be without one. It was a bizarre yet epic sound, and I think that the RBH Sound PM-8s nailed the otherworldliness of the artist’s intent.
Movie Listening
A solid action movie is normally a good way to show off a
soundtrack’s dynamics, and to this end, I watched ‘The Old Guard,’ Netflix’s
latest action vehicle for Charlize Theron. This movie concerns the conflict of
a group of nearly immortal warriors against a pharmaceutical company that is
trying to harness their gift of invulnerability. The action scenes are mainly
gunfights and hand-to-hand fights and so are not large scale action scenes.
However, the movie does a fair amount of globe-trotting, from Morocco and
Afghanistan, but it takes place mostly around Paris, so there is a nice variety
of locations and scenery. The music score had traditional orchestral pieces
along with a slew of hip-hop tunes. The PM-8 speakers handled all the elements
of the sound mix with aplomb. Dialogue intelligibility was never a problem,
even though most of the cast spoke with accents. Action scenes were superbly
reproduced, and the PM-8 speakers had more than enough dynamic range for the
loud levels at which I listened. As for bass, I didn’t miss subwoofers at all.
While I don’t imagine these speakers are tuned to an extremely deep frequency,
any bass within their range was accomplished with subwoofer-esque dynamics. A
movie with heavy use of extremely deep bass might have asked for a bit more
than what the PM-8s are able to deliver, but I think they are able to capture
most bass in film sound mixes, and more importantly, it does so with the proper
dynamics. With the ever-escalating number of discrete speakers, I did not feel
the performance of this simple two-channel setup left much on the table. ‘The
Old Guard’ was a fine action movie, and it sounded terrific on a pair of RBH
Sound PM-8 speakers. I have heard many different sound systems, and I would
much rather watch a movie on two good speakers than a dozen middling ones.
I decided to watch a movie with a very extravagant sound mix to
see how the PM-8s would handle sounds on a much larger scale, and the movie I
selected for this was 2019’s ‘Alita: Battle Angel.’ This movie is about a
cyborg that is reborn in the distant future and has to play a dangerous
rollerball-type game and fight bad cyborgs while trying to remember her past
(there was a lot going on). Any movie set in the year 2563 is bound to have
some wild sound effects, especially with a $170 million dollar budget, so I
thought it would make for a good demonstration of the PM-8s dynamic range and
bass extension. My expectations were set high from hearing what the PM-8s could
do on other material, and they did not disappoint. There were a lot of cyborg
fights in this movie that used all kinds of imaginative futuristic weapons, and
they all had weight thanks to the PM-8’s visceral low-end. The Centurion
robots, in particular, had a presence of danger due, in part, to their menacing
sounds: the deep mechanical voice and the subterranean thud of their footsteps.
They are like ED-209 on steroids. The rollerball-esque game called ‘Motorball’
had some crashes and wipeouts that looked and sounded spectacular. The ‘Iron
City’ of the movie’s setting was saturated with aural detail: a vast and
crowded place drenched in the din of day-to-day life, and the PM-8s helped to
make it a tangible reality. Tom Holkenborg’s music score was primarily
orchestral with a lot of synthesizer elements, and the PM-8s gave it enough
verve to stand out amongst all the components of the sound mix. This is a movie
to watch loud on a good sound system, and that is precisely what I did with the
PM-8s.
RBH Sound PM-8 Monitor Measurements & Conclusion
The RBH Sound PM-8 was measured in free-air at a height of 7.5 feet at a 1-meter distance from the microphone, and the measurements were gated at an 11-millisecond delay. In this time window, some resolution is lost below 250 Hz and accuracy is completely lost below 110 Hz. Measurements have been smoothed at a 1/12 octave resolution.
The above graph shows the direct-axis frequency response and other curves that describe the speaker’s amplitude response in a number of ways. For more information about the meaning of these curves, please refer to our article Understanding Loudspeaker Measurements Part 1. While there are some ripples throughout the midrange, the overall response of the PM-8 hews pretty closely to a central amplitude line, so this speaker has a good tonal balance much as I heard in my listening sessions. What the PM-8 doesn’t have is any broad peaks or dips that would color the sound. The narrow ripples are much less audible and don’t contribute much to the sound character. This kind of response is what one would hope for in a studio monitor. It will reproduce the source signal with little coloration added. We do see that the directivity is a bit imperfect, but it is not wildly imbalanced. For the most part, everything shows very good performance.
The above graphs depict the speaker’s lateral responses out to 90 degrees in five-degree increments. More information about how to interpret these graphs can be read in this article: Understanding Loudspeaker Review Measurements Part II. Here we get a better look at the slight directivity incongruities that caused some roughness in the directivity indexes in the lower midrange. The off-axis sags a bit after 50 degrees or so. However, keep in mind this is not some major flaw, and I only point it out for academic curiosity rather than a damning critique. It may well be audible if you were listening outside of a 50-degree angle, but realistically no one is going to listen at that angle. It is possible that it could have some discernible impact as an acoustic reflection versus a speaker with perfect directivity, but even then I doubt very much that the difference would be serious since this directivity flaw isn’t very severe. Something else that we do get a clearer view of is how much the tweeter beams at high frequencies. This is seen more with dome tweeters than AMT tweeters, but the PM-8 does squeeze the high treble at off-axis angles. It’s not a serious flaw either since most of the frequency range where the beaming becomes substantial is above 10 kHz. There isn’t a whole lot of content that high, and it isn’t a range that is meaningfully subject to acoustic reflections. If you want to be met with treble flat to 20kHz, you should be listening within a 20-degree angle of the on-axis response.
The above polar map graphs show the same information that the preceding graphs do but depict it in a way that can offer new insight regarding these speakers’ behavior. Instead of using individual raised lines to illustrate amplitude, these polar maps use color to portray amplitude, and this allows the use of a purely angle/frequency axis perspective. The advantage of these graphs is they can let us see broader trends of the speaker’s behavior more easily. For more information about the meaning of these graphs, we again refer the reader to Understanding Loudspeaker Review Measurements Part II.
From the above polar map, we can see that the PM-8’s dispersion pattern gets a bit ragged at off-axis frequencies but the bulk of the projected sound remains confined within certain angles. Much of the raggedness is higher-Q peaks and dips which aren’t all that audible, as was explained before. So, while the off-axis response doesn’t exhibit perfect uniformity, it isn’t likely to be seriously deleterious as acoustic reflections.
The above graph shows the PM-8’s response behavior along its vertical axis where zero degrees is directly in front of the tweeter, negative degree values are angles below the tweeter, and positive degree values are angles above the tweeter. There is a lot to like about this response. Typical speakers tend to have a large gap in the vertical off-axis response around the crossover frequency. This is because as the microphone moves off-axis, the difference in distance between the drivers becomes significant, and that distance difference causes phase cancellation within the range of shared frequencies which they reproduce. The shallower the slope of the crossover design, the larger the cancellation null that occurs in the vertical off-axis response. Sometimes these nulls begin to set in at just ten degrees above or below the on-axis angle. Because of these cancellation nulls, it is usually recommended to be listening to the speaker where the tweeter is level with the listener’s ear, where the drivers normally have equal distance from the listener.
As a consequence of their steep 48dB/octave crossover slopes, the PM-8s exhibit very little crossover cancellation. In fact, the vertical off-axis response is unusually good. These speakers may well be usable on their sides, in contrast with many other two-way speakers in this class. Many studio monitors use waveguides in an attempt to limit vertical dispersion based on the idea that acoustic reflections off of desktops or mixing consoles degrade the sound. Implicit in that idea is that the vertical dispersion patterns of most two-way designs are badly flawed. RBH Sound takes a different approach: they do not limit the vertical dispersion but rather ensure that it has good correlation to the on-axis response. In other words, there is no need to confine the vertical dispersion if the reflections that it produces are benign. Aside from the matter of reflections, PM-8 users benefit from this excellent vertical dispersion by being able to listen at lower or higher angles and still be met with a full sound as opposed to many other speakers of this type.
The above graphs show the PM-8’s low-frequency responses that I captured using groundplane measurements (where the speaker and microphone are on the ground in a wide-open area). This graph depicts the low-frequency responses of each of the presets that affect the low frequencies. The purple curve for presets 1, 4, 5, and 8 shape the response for situations where no boundary or room gain is expected (or also if the user just likes a lot of bass). The blue curve for presets 2 and 6 is the low-end response intended for situations where room gain will give an acoustic boost to low-frequency output, and that response attempts to compensate for the boost. The green curve is the response for presets 3 and 7, which set a high-pass filter for use with subwoofers. While room acoustics will invariably screw up the low-end response, the PM-8 puts out a nicely smooth or linear response for whatever preset it is used in.
The above graph exhibits the changes that can be made to the PM-8’s treble response using the preset knob settings. The red curve represents presets 1 through 4 and is intended for further distance placements that can attenuate higher frequencies. The green curve represents preset 5, which is also intended for far-field placement but shelves the high frequencies by 3dB. The blue curve represents presets 6 through 8 and is the response intended for near-field placement. Preset 5 gives the most neutral anechoic response from these options, but those who are looking for a more detailed, forward sound might enjoy presets 1 through 4 more, and those looking for a slightly more relaxed sound use presets 6 through 8.
As always, before wrapping
this review up, I will briefly go over the strengths and weaknesses of the
product under review. As always, I will start with the weaknesses, although
there aren’t many weaknesses here. However, at this price point, few weaknesses
should be expected. One issue that might be a nuisance for some users of the
PM-8 who need a near-field monitor is there is a slight background hiss when
the speaker is turned on which is not affected by the gain, so it has the same
loudness level irrespective of anything else. Many active monitors, especially
those with class-D amplifiers, seem to have this background noise which sounds
like a soft white noise. It is not loud, and you do have to be in a near-field
distance to hear it, but when you are, it is audible. Unlike other studio
monitors though, these speakers are so large that I doubt many people are going
to use them as desktop speakers, so this complaint might be a moot point
(although I did use them as desktop speakers for my PC system for a while and
the noise wasn’t intrusive enough to bother me).
One other small flaw is the PM-8’s directivity control, which isn’t quite as good as some other monitors that we have seen which use waveguides. However, as I mentioned before, it isn’t bad, and the adverse effects of their imperfect directivity control aren’t likely to be an audible matter, just an academic one.
One caveat is that they are
large monitors, but you can’t get their level of performance from a small
enclosure, so that is not a reasonable complaint. However, those looking for
some speakers for a tight space may want to make a mock-up of the PM-8’s size
first to see if they will fit before ordering a pair. Otherwise, if you want the RBH Sound with the PM-8 technology, you'll have to wait until they offer a 6" version in a PM-6 model.
With those nitpicks out of the way, let’s now discuss the PM-8’s strong points. Their strongest attribute is, of course, their sound. They have a very balanced and detailed sound along with an outstanding dynamic range. The on-axis response is very good, the off-axis response is decent, and, unlike many of the monitors that we have looked at, they aren’t picky on the vertical axis. You can have these aimed a fair bit above or below you and you will still be met with a full and linear sound. They are certainly neutral enough to use for studio work. What you put in them is what they give out without adding or omitting anything. They project a superb soundstage with excellent imaging abilities. Their ability in bass can match that of a full-sized tower speaker. Even though they are stand-mount speakers, they can dig well below 40 Hz with real dynamics and low distortion, and their 32Hz low-end in their specified +/-3dB window is very real.
The ability to alter the response with the preset knob is also an advantage for those who want to tailor the sound to their tastes or who want to use a subwoofer in a system without bass management. Being able to high-pass filter at 80Hz along with the XLR outputs make it easy to incorporate subwoofers without needing extra processing gear. Many studio gear setups don’t have easy bass management like a typical home audio AVR, so those features can be advantageous.
RBH Sound PM-8 Active Studio Monitor
The PM-8’s build quality is also very good, befitting a speaker of this price point. The accent panels are a pretty significant surcharge at an additional $400 per speaker, and individual buyers will have to decide whether it is worth it to them. The accent panels really do give these speakers some serious heft though, and make them feel and look more like a high-end home audio speaker than a studio monitor. Buyers should keep in mind that the accent panels are made from engineered stone and can be had in a variety of colors and stone mixtures, and inquiries should be made to RBH Sound to see what can be had. Outside of the accent side panels, the textured laminate surface is certainly a cut above the usual plastic or vinyl finishes that most monitors have in both appearance and durability. Those who want their studio gear to look high-end, as well as sound high-end, will want to give a close look to the PM-8s.
As I mentioned earlier in
this review, it looks to me like RBH Sound isn’t just making a studio monitor but a
high-fidelity speaker with the flexibility to take on a lot of roles:
near-field monitor, far-field monitor, or an upscale home audio standmount
speaker. It is the swiss-army knife of hi-fi speakers, but that does engender a
pricey speaker since it has to accommodate the aesthetic requirements of home
audio, the dynamic range needed for far-field monitoring, the connectivity
needed for pro-audio gear, and the linearity needed for studio production work.
It does all of these things well, and that, to me, makes its cost very
reasonable.
Those who are interested in the PM-8s can try it as an in-home demo from RBH Sound for 30 days with the option to return it for a full refund for any reason (although they will have to cover return shipping costs). Buyers get a five-year warranty on the cabinet and drivers and a three-year warranty on the amp. I quite enjoyed the RBH Sound PM-8s, and I think anyone looking for a high-performing loudspeaker that can meet the needs of a wide range of situations has a rock-solid choice in the PM-8s (get it? “Rock-solid” since they have engineered stone side panels… I’ll be here all week, try the veal, and don’t forget to tip your waitress).
— Excellent
— Very Good
— Good
— Fair
— Poor
| Metric | Rating |
| Build Quality | |
| Appearance | |
| Treble Extension | |
| Treble Smoothness | |
| Midrange Accuracy | |
| Bass Extension | |
| Bass Accuracy | |
| Imaging | |
| Dynamic Range | |
| Fit and Finish | |
| Performance | |
| Value |
