Outlaw Audio Ultra-X13 Subwoofer Conclusion
Those readers who have made it this far may have noticed I have not said much critical about the Ultra-X13 and that the tone of this review has been generally positive. This is because the Ultra-X13 has given me virtually nothing to complain about. This is a subwoofer that has lots of strengths and no real weaknesses. If there is any drawback at all to this sub, it is that the Ultra-X13 is somewhat large and a bit heavy. That is difficult to hold against it, because this is something buyers will know going in, and besides, this kind of low-frequency performance requires an enclosure of this size. Reducing the size will also reduce the deep bass performance by the laws of physics, and I will gladly accept the larger size for its terrific deep bass performance. As for heaviness, it could be worse. The Ultra-X13 should be picked up and carried by two people, but it is movable by a single healthy adult by being ‘walked’ on its spiked feet. As was said before, it should not be dragged, but moving it by lifting one end up and pivoting it on its feet is doable.
The overall performance is very good. There are some subwoofers in its same price range that can get louder and dig a bit deeper, but the advantage of the Ultra-X13 is its consummate fidelity, especially in its THX Ultra certified configuration. As was said before, in this mode, it cannot be pushed to make an unwanted noise, and it can not be driven into error. It maintains its extremely linear response at all drive levels in burst tones and almost all drive levels in long term tones until it gets to the last few dB, where a minor amount of compression occurs, but burst tones are more representative of the transient nature of real world content than the continuous sound of a long-term sweep. Every aspect of its performance is solid, and, in my opinion, it has no shortcomings. I have dealt with subwoofers that were higher performing in one metric or another, but the Ultra-X13 put up a very good showing in every single measurement. Nowhere is it lacking or below average.
The Ultra-X13’s splendid acoustic measurements
translate into a great sound, as I found out in my time listening to music and
movies with it. It sounded great, period. I could happily live with this sub.
For my sometimes extreme tastes, I think I would want two, but I am certain
most people would be very satisfied with one. This is a subwoofer that, at 2
meters in an outdoor ground plane setting, can belt out a tight average of 115
dB from 30 Hz to 125 Hz and do so with only 5% distortion, and that is more
than enough headroom for most people. I think the average user would rarely
crank it that hard, but, if they ever wanted to, the Ultra-X13 will do that
without any danger to itself. This is a subwoofer that can be pushed hard
without fear of being over-driven. If an owner wanted to impress their friends,
it is fine to turn to maximum volume for a short while, just to “see what it
can do.” We all know the type of guy who does that as soon as they get any kind
of new toy (and yes, it’s almost always a guy who does that), but the Ultra-X13
can take it. Of course, it shouldn’t be subjected to that sort of abuse
indefinitely, because if it was, it would break down eventually, but for short
periods, go ahead and let it rip; the Ultra-X13 can handle it.
The Ultra-X13 earns our Bassaholics “Extreme” Room Rating, which means it should be able to achieve 115 dB peaks at the typical listening position in a 5,000 cubic foot. The Ultra-X13 just barely clears the hurdle to achieve that with respect to maximum output at 31.5 Hz and above, but it clears it nonetheless, and it doesn’t struggle at all in doing so, since its distortion is so low.
Those wishing to know more about our room rating system can read this article: Bassaholic Subwoofer Room Size Rating Protocol.
It is worth mentioning here that clean, distortion-free bass will sound significantly quieter than bass with audible quantities of distortion. The reason is that harmonic distortion is sound that is higher in frequency than the sound that it is a product of, and, in the subwoofer frequency band, human hearing rapidly rises in sensitivity to sound as frequencies move upward. To see how severe this is, look at the frequency range of 10 Hz to 100 Hz in this chart of the equal loudness contours. What that means is that normal human hearing can hear the upper frequencies of the subwoofer band much more easily than the lower frequencies. For example, a 90 dB tone at 30 Hz only has to be 70 dB at 70 Hz to be heard as the same loudness level, even though it is a 20 dB difference in sound pressure level. To put that another way, a 30 Hz tone (which is a deep bass sound) must be ten times more powerful in amplitude than a 70 Hz tone (which is considered a mid bass sound) to be perceived by human hearing as the same loudness! Since upper bass is so much more easily heard than lower bass, when harmonic distortion does become audible in bass frequencies, it can be substantially louder to human hearing, even against a non-distorted bass sound of a much greater amplitude.
Bottom Line
A big, black, ported subwoofer stamped with the THX
logo is sure to get dismissed by audiophiles as merely a ‘home theater’ sub
that is primarily meant for making explosions louder, but in the case of the
Ultra-X13, that would be a mistake. In fact, there are less expensive options
that are more suited for that task. For those who want accuracy first and
foremost, the Ultra-X13 is a great choice. For those who want their music
reproduced without any additions or subtractions, the Ultra-X13 is an ideal
candidate for that job; the output is faithful to the input. Acoustic
summations and cancellations of room modes will inevitably take their toll on
the bass response, so it might be worth getting multiple subwoofers to even out
the response for those who want a truly neutral response in-room. Outlaw Audio
does give a hefty discount for the purchase of duals, at $2,500 a pair (not including
shipping), but the $1,500 cost of a single is still a good deal, in my view.
Outlaw Audio offers a 30-day full refund for those who wish to return the Ultra-X13 for any reason. They will also pay for return shipping, although not the initial shipment cost. The buyer receives a 3 year warranty on all parts along with Outlaw Audio’s good reputation for customer support. The Outlaw Audio Ultra-X13 is a fine product and a good value, in my opinion. I wish that every product that is sent to me for review gave me as much cause to praise and so little cause to complain.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Bass Extension | ![]() ![]() ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() ![]() ![]() |
Fit and Finish | ![]() ![]() ![]() ![]() |
Ergonomics & Usability | ![]() ![]() ![]() |
Features | ![]() ![]() ![]() ![]() |
Dynamic Range | ![]() ![]() ![]() ![]() |
Performance | ![]() ![]() ![]() ![]() ![]() |
See also:
Recent Forum Posts:
Might be the relationship. :oops:
But in a 8000'3 room, I think a third would be ideal, along with two full range towers tickling 20Hz. Alas, I digress.
Still happy with my Outlaw gear after 1 year!
MrKaffee, post: 1360528, member: 90469Yeah, once you get to a pair of these (in any normal room) it becomes a real question if more would really add anything (that you want added). It is like riding a 1100cc motorcycle - there are bigger bikes, but how much more acceleration do you need when you can twist the grip and flip the bike on top of you!
I now have two of these. Bought one last year and another this year. Took advantage of their Christmas specials at $999 free shipping. All I can say is wow! One was really good but two is simply outstanding. I have both situated behind the sectional. Deep deep bass and can shake the entire room - not just the sitting area! I had one set at eq2 but found with two set at eq1 to be sonically superior. Have the pre/pro set to large fronts and to mirror low bass below 40 Hz to the subs. Its amazing how seamless it sounds. Right now Im in OMG mode but like many of you am in endless pursuit of nirvana.
andyblackcat, post: 1262768, member: 70814A lot of these amps are already sealed in with glue, along side the screws, so I wouldn't worry about leaks too much with this build class of subwoofer. However, very inexpensive subs may be a different story.
Well least you know about that as I was thinking what NASA does when pressurizing the shuttles cabin then they check for leaks to see if its okay to launch. So same for speakers/subs I guess as I had to check over older speakers that had drill holes and had to seal the holes then run a loop frequency sweep checking for air leaks and resonate noises.
Still maybe a little silicon going around the plate amp as you may never know there could be one spot where its venting air?
