DD Audio PM151 and ABC10 Conclusion
At $279 a pair, the DD Audio Powered Monitor 151 represents a very good value.  They get many things right including good sound, attractive finish and sufficient sound pressure levels for most near field listeners.  The PM151 adds some consumer features including a USB charging port, A/C outlet and easy connectivity to portable devices.  The PM151 does not have balanced connections and I had a hard time with noise where it has not been an issue before.  I was able to solve it but it is just something to keep in mind.
The DD Audio PM151 speakers represent a very good value.
On the sound quality front, the PM151s sound good with a nice downward sloping frequency response giving them a laid-back sound.  In my opinion, the 500Hz to 1kHz range was a little excessive but nothing offensive.  I preferred the speakers slightly above my ears, which improved things for me.  Ultimately, the sound seems to vary quite a bit based on placement so it should be possible to adjust these speakers to taste.  For the given price tag, they are well constructed and attractive.
The ABC-10 subwoofer plate amplifier and driver are both nice for the $429 price point.  The subwoofer easily keeps up with the PM151s in most rooms so they complement each other well. The ABC-10 cabinet uses 5/8 inch MDF on the front, back, sides and top, which makes it pretty light.  The subwoofer sounds good for music and is a good sound quality match for the PM151.  I never had issues with the subwoofer bottoming out or sounding bad.
Acoustically integrating the ABC-10 with the PM151 was not as intuitive as the switches would indicate.  I got the best results by turning off the high pass filter on the PM151s and using a RTA to adjust the ABC-10.  Once they are dialed in, they sound good on just about any recording.  The stereo imaging for music was nothing special but I do not know of a $279/pair desktop monitor that has amazing imaging.
Stock Pictures
DD Audio PM151 (left) and ABC10 (right)
DD Audio PM15S1 Powered Monitors and ABC10 Subwoofer Review
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
Build QualityStarStarStar
AppearanceStarStarStar
Treble ExtensionStarStarStarStar
Treble SmoothnessStarStarStarStar
Midrange AccuracyStarStarStar
Bass ExtensionStarStarStarStarStar
Bass AccuracyStarStarStarStar
Dynamic RangeStarStarStarStarStar
PerformanceStarStarStarhalf-star
ValueStarStarStarStar
Joel Foust's experience in quality control, product certifications and do-it-yourself loudspeaker design bode well for the consistent application and development of in-depth loudspeaker testing. Joel is committed to providing accurate results that are comparable for each loudspeaker tested.
Recent Forum Posts:
shadyJ posts on July 14, 2014 22:17
Kudos for using a polar map. The more I learn about polar map charts, the more useful I think they actually are. Here is a informative presentation by Earl Geddes on the matter, who is, as far as I know, the chief proponent of Polar Maps as a measurement of loudspeakers, he gets into polar charts at around 13:00, but you will want to watch it from the beginning for context:
https://www.youtube.com/watch?v=fE2nWVwFT9k&feature=youtu.be
