Starke Sound VLOT Active Wireless Loudspeaker System Review
- Product Name: VLOT Active Wireless Floorstanding Speaker
- Manufacturer: Starke Sound
- Performance Rating:
- Value Rating:
- Review Date: February 21, 2022 00:55
- MSRP: $ 1,300/pair - Black/White, $1,500/pair - Limited Edition
- Drivers: 1 inch tweeter, 2 x 4 inches mid-bass
- Amplifier: 2 x 150W RMS
- Max SPL output(1m): 108dB
- Frequency response (±3dB): 45Hz-25kHz
- Input terminals:
Bluetooth input
RCA stereo inputs, a pair
Coaxial input
Optical input
Power input (Control speaker)
Binding post inputs, a pair (Companion speaker)
- Wireless format:
Bluetooth 5.0
SBC/AAC/APT-X/APT-X HD/LDAC
- Finish:
ABS Varnish
Color options: Black Satin / White Satin / Limited edition
- Weight: 25.6 lbs/11.6kg (Control speaker), 20.3 lbs/9.2kg (Companion speaker)
- Size: H 36.4 x W 6.7 x D 8.1 inches (w/ foot)
- Small footprint
- Easy to use
- A simple, complete sound system
- Lots of bass for a small tower
- Too soft in treble for neutral sound reproduction
Those of us in the hi-fi world might not have noticed it, but the wider world of consumer audio has been changing dramatically over the last several years, and the kind of audio systems that the average person is looking at does not much resemble the traditional setup of an audiophile. That traditional audiophile setup is made up of largish passive speakers, amplifier or integrated amp, preamplifier, and a host of other separate components depending on how intricate the user wants their system to be. That complexity is not appealing to 'normies' thereby giving rise to the market dominance of Bluetooth speakers and soundbars as the systems of choice for the average audio consumer. The problem with these simple user-friendly audio systems is that they just don't sound very good in comparison to serious speakers and audio electronics. They sacrifice a lot of performance for smaller size and convenience.
The speaker system that we are reviewing today, the Starke Sound VLOT, attempts to bridge the gap between lifestyle audio systems and performance-centered audio systems. It is a traditional loudspeaker design at a glance but has the convenience and simplicity of regular Bluetooth speakers and soundbars. It is a speaker system that has a built-in amplifier, pre-amp, and Bluetooth receiver. It is not a large speaker which makes it palatable for many buyers, but it bears signs of serious loudspeaker design. So the question that it poses is can we have the best of both worlds: simplicity and convenience as well as a true high-fidelity sound? Let’s dig in to find out…
Packing and Appearance
The VLOT speakers arrived double-boxed and packed with polyethylene foam pieces that protected all of the edges. The speakers were covered in cotton sacks to protect them from moisture and scuffing. The packing was above average for loudspeakers of this size and should be well-protected against the rigors of typical shipping practices.
Once
unpacked, I was presented with two fairly normal-looking satin black speakers.
Without grilles, they are rather undistinguished in appearance: not bad but not
particularly distinctive. They are on the smaller side of floor-standing
speakers with a rounded lower front-baffle and two smaller woofers below a dome
tweeter. The grilles are the visual elements that separates them from other
loudspeakers; they have an irregular mosaic pattern that I have not seen on any
other speaker. It’s not especially conspicuous in the black finish since it is
black-on-black, but it looks to be more prominent as a visual feature in the
other finishes. I can appreciate it as something that gives the VLOT speakers
some style, and I think that most people would be fine with it in the black
finish since it is a bit more subdued there, but it would be a bolder element in
the other finishes. The unique grille pattern is probably better for them on
the whole since it aesthetically sets them apart from so many other speakers.
The VLOTs can also be had in satin white as well as a special edition finish
that uses a Macassar wood veneer that has a $300 surcharge. What will make the
speaker more acceptable for other household members is not the styling but the
size; these are narrow speakers that do not have a large footprint.
Design Analysis
The Starke Sound VLOT speakers are a swiss army knife solution to audio systems. For small tower speakers, they can do an awful lot. To get into the design of them, let’s start with the actual speaker part of these speakers, in other words, the transducers. They use two 4” mid-range drivers along with a 1” fabric dome tweeter. The woofers have a fairly beefy motor considering the 4” cone size. They cross over at 3,900Hz using a passive crossover circuit, so the onboard electronics are not used in the crossover. That seems like a missed opportunity, but Starke Sounds say it was done to keep a lower noise floor and to ensure a higher quality system by not having the acoustic components rely on the electronics for a good sound. I can attest to the low noise; there is a soft hiss if you put your ear right up to the tweeter, but the speakers are silent at any reasonable listening distance.
The
front baffle of the MDF enclosure uses a ⅞” thick mount for the drivers and has
multiple braces throughout the cabinet as well as some acoustic stuffing. The
side panels are ½” thick and don’t need to be very massive since it is a small
speaker that uses internal bracing. It is a rear-ported enclosure with a 2”
diameter flared port with a 4 ¼” length. The feet are some plastic rounded
cones mounted on some outriggers. The outriggers don’t let the speakers tumble
over easily from brushing up against them, however, a rambunctious child,
zooming dog, or inebriated adult would topple over one if bumped into with some
force. It would be a good idea to keep the VLOTs away from heavily traveled
paths in your home.
Each channel is driven by a 150 watt RMS Class-D amplifier, a lot of power considering the transducers used. Only one speaker unit has the amplifiers built-in, and it connects to and powers the other speaker by way of an included 8’ speaker cable that is flat so as not to cause a bulge under any rug that it might be run under. Of course, as a full sound system, the VLOT also has a DAC and uses a 32-bit ESS Sabre DAC chip. Connectivity is very good, and the VLOT supports a wireless Bluetooth connection, RCA left and right inputs, and digital coaxial as well as optical inputs. Streaming is easy from any device that supports Bluetooth connectivity, and the VLOT supports a range of Bluetooth codec including aptX HD and Sony’s ultra-high-resolution LDAC. I had no trouble establishing the Bluetooth connection even with my ancient LG smartphone. Digital optical and coaxial connectivity makes it easy to hook up to most available televisions as well. The input channel can be selected by a top-mounted control panel on one of the speakers. The control panel also has a volume control.
The VLOT has a subwoofer output that essentially sends out a full-range summed signal with no low-pass filtering, so the user will need to rely on the sub’s low-pass filter. There isn’t any method of high-pass filtering the VLOT for use with subs, so while there is a subwoofer output, there isn’t any kind of bass management that comes with it.
Listening Sessions
In my 24’ by 13’ (approximately) listening room, I set up the speakers with a few feet of stand-off distances between the back wall and sidewall, and equal distance between speakers and listening position. I angled the speakers to have a slight toe-in toward the listening position. The listening distance from the speakers was about 6 feet. The VLOT speakers were connected directly to my source which was an HTPC. No room correction equalization was used. No subwoofers were used.
Music Listening
Icelandic composer Johann Johannson didn’t live long enough to establish a body of work as vast as many of his contemporaries, but what he did leave behind left no doubt as to his brilliance. While known for his film scores, one of his last projects saw him at the director’s helm as well as doing the film score. “Last and First Men” is a visual and musical essay that features disconnected narration over shots of abstract Yugoslavian monuments that is all set to Johannsson’s contemplative neoclassical music. This lush orchestral score is often abetted by field recordings as well as electronic atmospherics in creating an environment of desolation. I found the score in a hi-resolution format on Qobuz and thought that the breadth and dynamism would make for a great demonstration of the abilities of the VLOT speakers. A good sound system should get out of the way and allow the listener to get lost in such a meditative soundscape; would the VLOT allow that?
The first thing I
noticed is the width of the soundstage that the VLOT speakers could produce.
Perhaps it shouldn’t be so surprising since narrow speakers tend to have a wide
dispersion, but it is always uncanny how small things can make a big sound.
These speakers made the room sound bigger than it was. The bass was reasonably
authoritative as well. The fifth track has some low-tuned bass drums that sound
utterly cavernous. The bass violin had an emphasized low-end which I would
attribute to somewhat hot bass voicing. That isn’t surprising, and we have seen
other manufacturers give a low-frequency bump to smaller speakers to generate a
sound that belies their size. It wasn’t a massive boost that badly deformed the
sound, but it was detectable. Instruments sounded fairly natural otherwise.
Instrumental solos had good center imaging, and individual elements of the
soundstage were kept separate and distinct. The speakers could disappear into
the soundstage, and it did not sound like sound was being emitted from two
points in space. At higher loudness levels, the VLOT speakers seemed to handle
themselves well and did not run into any obvious problems, although this isn’t
the kind of music that would be especially distressing for them. Nonetheless,
they could get surprisingly loud for their size. I enjoyed “Last and First Men”
on the VLOT speakers, and they gave this recording a spacious sound that I
think many orchestral music aficionados would delight in.
For an acoustic
recording with human voices, I found a superb new album called “Giosquino:
Josquin Desprez in Italia,” a choral album of renaissance music that was
performed in a similar manner and in a similar setting to the original men’s
choir that first sang these compositions in the early 1500s. The title refers
to an influential composer from this era, Josquin Desprez, and is performed by
the Odhecaton, a highly regarded choral collective who specializes in period
music. This 2021 release on the Arcana label can be heard on Qobuz streaming in
a high-resolution format that is befitting of such an exquisite production. Would
the VLOT speakers be good enough to take advantage of the quality of the
recording and production techniques?
The acoustics from the recording location, the Abbey of Santa Maria, Follina, came through nicely on the VLOT speakers. The sound was expansive and enveloping. Although there was some amount of reverberation from the acoustics of the recording location, the singers sounded natural. Imaging was good, even though this was recorded in a chapel; individual singers still had well-defined positioning within the soundstage. The elevated bass heard on previous recordings was not evident here since this recording didn’t have much in the way of deep bass. Every part of the Odhecaton ensemble sounded lovely, from countertenor to baritone. The sonorous acoustics gave each voice a full-bodied sound without washing out other singing, and the VLOT adeptly reproduced this attribute. They managed to convey the beauty of the music without becoming a part of the performance that I could discern.
For something with a more singular focus on a human voice, I found a delightful album titled “Wary + Strange” by Amythyst Kiah. This music hovers somewhere between bluegrass, alt-rock, and folk music; It has the personal subject matter of blues but the harder sound and swing of rock music and vacillates between softer and harder style from track to track. In this production, Amythyst’s voice is the central figure and is recorded in a pure and unprocessed manner for a more intimate sound. It is a studio album but sounds like a live recording sans audience noise. Again, I listened to this in a high-resolution stream from Qobuz; would the VLOT retain the naturalness of Amythyst’s voice in this recording?
The first thing I noticed from the start was the imaging; Amethyst is strongly centered in the soundstage. Guitars flanking her voice to the left and right are also locked in a firm placement. Through the VLOT speakers, it was easy to tell that the drum kit used near-field recording since the percussion elements spanned so widely from left to right. On the more rowdy tracks, Amythyst’s voice did sound a bit more recessed than on the previous occasion that I listened to this album where I remember her voice having more presence. The sound was a bit softer than I remembered, except that the kick drums also had a bit more weight than I remembered. The tonality had notably changed, but the album still sounded good. Amethyst’s voice simply did not sound as loud as when I had listened to this album previously, but that was on my desktop PC system which used the PreSonus Eris E8 XT speakers. Again, the bass was surprisingly weighty for such slightly-sized speakers. The VLOT gave a pleasant accounting of “Wary + Strange,” although I think the original recording called for a slightly more ‘in-your-face’ presentation. Some people may enjoy the more laid-back sound of these speakers, but some people may want some more sizzle in their rock music.
For something far more into the realm of studio-produced pop music, I put on Kelly Lee Owens’ “Inner Song,” a largely electronic album overlaid with Owens’ ethereal vocals. This is a very clubby album that was unfortunately released in the late summer of 2020 which was just about the worst time to release an album of dance music on account of the COVID-19 lockdown. Happily, this music is eminently listenable on its own and not simply as a vehicle to get people to hit the dance floor. “Inner Song” features a healthy amount of bass and the type of spectral balance we normally find in pop music, and so I thought it would be a good demonstration of what the VLOT speakers could do on the type of musical content that they will likely be asked to play far more than not. I will also just take any excuse to relisten to this album again since I quite enjoy it!
The VLOT speakers gave this recording and Kelly’s voice in particular an intoxicatingly smooth and expansive sound. The processing in the recording doesn’t often give her a centered image but rather a sweeping choral effect, so she sounds as if she is singing over a broad area, and this effect is nicely conveyed by the VLOT speakers. Indeed, many stereophonic tricks are employed in “Inner Song,” and they are all fun to hear on these speakers. Some of this kind of processing was likely intended for headphone listeners, but in a well set up stereo pair of speakers, these studio tricks make for an engaging effect, and the VLOT speakers managed to pull it off splendidly. As far as bass performance goes, I was again impressed that such small tower speakers could produce such a healthy amount of bass. Kick drums and bass lines were nicely rendered at medium-high volumes, although the bass drivers did complain somewhat when I pushed the speakers toward the higher end of their gain. This happened at a relatively loud level though, and I wouldn’t think buyers would normally attempt to run these speakers that loudly. They can get a bit louder than what one would expect from their size and specifications, but they do have their limits and are not house party speakers.
Movie Watching
To hear how the VLOT speakers could handle a typical major motion picture sound mix, I watched “King Arthur,” Guy Ritchie’s 2017 action-packed historical epic. I had not previously seen this overlooked movie, but I have always enjoyed Ritchie’s past films and figured this would be a good opportunity to watch it as well as a good demonstration of the VLOT’s abilities with this type of content. “King Arthur” had many major action set-pieces and a lot more large-scale CGI-laden action scenes than I was expecting. The VLOT handled the many action scenes fine, however, their sound wouldn’t really be mistaken for a heavy-duty speaker system replete with subwoofers. Their bass did bring a fair amount of thump to the action scenes, although the extra bass also tilted the lower-pitched voices to sound a bit boomier than they would otherwise have been. For example, Djimon Hounsou’s voice sounded particularly bass-heavy and resonant, although the dialogue was still intelligible. The bass boost again reminded me that it seemed to be a way to compensate for the perceived headroom in low frequencies. Imaging was good, and the sound appeared to emanate from the angle relative to its source, whether that be dialogue or effects noises. Daniel Pemberton’s thunderous score was adequately expressed by VLOT speakers, although such a mammoth score did see the dynamic range limits of the speakers I played this movie at a high volume, and the speakers handled it pretty well, although the levels I listened to hovered at the top of their dynamic range. Their unhappiness was made known when the woofers began to audibly distort, but that was at a level no one would reasonably expect from a loudspeaker of their size. Overall, the VLOT speakers had enough oomph to make “King Arthur” an enjoyable experience and well beyond all but the highest-end soundbars would have managed.
For a film sound mix of a much smaller scale, I watched the 2015 thriller “Cop Car” starring Kevin Bacon. In “Cop Car,” two bored kids find a seemingly abandoned police car and decide to take it out for a joy ride, however, they don’t know about the hostage in the trunk or the psychotic sheriff who is using the car for a criminal scheme. Thus begins a cat-and-mouse chase where the boys must outwit the sheriff to stay alive. I figured the smaller scale of the movie would place more emphasis on dialogue which would give me a better chance to gauge the VLOT’s ability at dialogue intelligibility. The movie turned out to be more about silent, tense moments, so it wasn’t overflowing with dialogue, but everything spoken was clearly communicated. The most notable sonic quality of “Cop Car” was the jazzy score by Phl Mossman. The music was playful as well as atmospherically noirish, and the VLOT speakers gave it a full, vivid reproduction. The overall sound mix was rich in detail but restrained, and it was a welcome break from so many contemporary movies which can be wall-to-wall loudness. There were few loud moments in “Cop Car,” but what few there were was lively on the VLOT speakers which again delivered more bass than one would have expected. The VLOT speakers did not just do a serviceable job on “Cop Car“ but a good job and the movie was a great, tense little thriller made better by a competent sound system.
Starke Sound VLOT Active Speaker Measurements & Conclusion
The Starke Sound VLOT speakers were measured in free-air at a height of 4 feet at a 1-meter distance from the microphone, with the microphone raised to a 7’ elevation that was level with and aimed at the tweeter center. The measurements were gated at 8-milliseconds. In this time window, some resolution is lost below 400 Hz and accuracy is completely lost below 200 Hz. Measurements have been smoothed at a 1/12 octave resolution.
The above graphs depict the VLOT speakers’ direct-axis and horizontal dispersion out to a 90-degree angle in ten-degree increments. Information on how to interpret these graphs can be read in our article: Understanding Loudspeaker Review Measurements Part II. These measurements bode for a rather warm speaker. The tweeter level is considerably lower than that of the woofers. Such reduced treble can make for a soft or warm sound. Some people will find that pleasing, and others will find it dull. It may be a voicing made for modern sound mixing that tends to be heavily compressed as a measure to make it less fatiguing. Most popular media is mixed rather loudly. Nearly all commercial streams such as news channels, radio stations television programming, much of pop and rock music, and the noisier movies from Hollywood are deep into the loudness wars, and long bouts of exposure to this kind of sound can be wearying. I would guess that is the kind of content that the VLOT speakers would be used for most of the time, and so Starke Sound may have decided to tone down the treble for that reason. Something else that can lend the VLOT speakers a softer sound is the beaming that occurs above 10kHz. Outside of the 30-degree angle, treble output rapidly decreases, so for the fullest sound, the VLOT speakers should be listened to at the on-axis angle; make sure these speakers are angled to face the listening position directly.
When we inquired Starke about the reason for this response shape, they replied that this response should provide a natural sound in an open placement away from nearby surfaces. That seems strange since most floor-standing loudspeakers end up being placed near a wall by most people in practice- and this seems like it would be even more true of those people shopping for speakers with a small footprint. I do have to agree that these speakers would sound best if placed away from walls and corners since the boundary gain that comes from that placement will elevate the lower frequencies even more.
Manufacturer’s comments: VLOT will perform well in a wide variety of room placements including on either side of an HDTV. Our experience is that they are especially good when setup well out into the room, away from walls and with clear space all around. We are proud of their stereo imaging that presents throughout a rectangle defined by the inside edges of the speakers. Recent DACs from iFi are well matched to VLOT and raise their performance to a new level with hi-res and MQA content.
The above polar map shows the same information in the preceding graphs but depicts it in a way that can offer new insight regarding these speakers’ behavior. Instead of using individual raised lines to illustrate amplitude, polar maps use color to portray amplitude, and this allows the use of a purely angle/frequency axis perspective. The advantage of these graphs is they can let us see broader trends of the speaker’s dispersion behavior more easily. More information about interpreting this graph can be read in our article: Understanding Loudspeaker Review Measurements Part II.
Here we see how weighted the VLOT speakers are in bass and lower midrange frequencies. Something else we get a clear look at is how wide the dispersion is at lower frequency bands. As we move up in frequency, not only does the level decrease, it also narrows in dispersion. With 4” bass drivers, the VLOT does have a very wide dispersion, and it holds that wide dispersion out to 10kHz. The narrowing above 10kHz isn’t all that consequential for those who are listening far off-axis, since there just isn’t that much recorded content that high. A lowering of energy in this region may lead to some lack of “air” or sparkle in the sound if given close attention.
The above graph shows the VLOT speaker’s low-frequency response captured using groundplane measurements (where the speaker and microphone are on the ground at a 2-meter distance in a wide-open area). One thing that surprised me in this measurement is that I was certain that I would find a bump centered around 100 to 150Hz based on my listening sessions, but that isn’t seen here. There is a mild bump at 200Hz, but that is a bit deceiving since it jumps up right after the pipe resonance (or rather, anti-resonance) at about 190Hz. This resonance can turn into a dip or peak depending on the angle at which this speaker is measured, and in-room is will probably average out, so in actuality, the bass response may be a bit smoother sounding than what can be measured from a few mic positions in a groundplane environment. So it turns out that the bass bump that I heard was the elevation of the entire bass range relative to treble rather than a 100hz bump. The elbow of the bass response seems to happen at around 50hz, and in-room, listeners should have pretty solid bass extension down to 40Hz since the roll-off is relatively shallow.
While I enjoyed
Starke Sound’s VLOT speakers, I do feel there are areas of improvement for this
design. However, they feel like they are potentially opening a door to bring
floor-standing loudspeaker systems back into the homes of the average person.
They are a foot forward, but more work needs to be done and more products need
to be developed along these lines. Before wrapping this review up, I will go
over a few of the aspects that I hope get revised in future speakers of this
kind.
Firstly, while I was hoping the VLOT speakers could deliver a high-fidelity speaker with something that has the ease and convenience of soundbars, these speakers do fall short in accurate sound reproduction. They place too much emphasis on bass to recreate a fully natural sound. That isn’t to say they sound bad, and I can appreciate a laid-back voicing, but it doesn’t work with everything. That being said, there are people who will enjoy this flavoring, and it does take the edge off of noisy content. Nonetheless, I feel like there was a missed opportunity here. An active speaker can easily use digital signal processing to flatten out the response for a neutral sound. What is more, it could also easily be activated or deactivated in a system that uses a passive crossover such as what has been done in the VLOT, so it could be something that could be turned off if Starke thought that the existing sound would be the preferred one.
Related to the above point, I think the use of a passive crossover should have been avoided. It’s less efficient than active crossovers as well as less optimal in achieving a perfect blend in the response of the drivers. There are simply more advantages in the use of an active crossover circuit than a passive crossover, and it seems like that would have been a relatively simple step to take in the VLOT speakers seeing as how they are already self-amplified and has digital circuitry onboard.
Another missed area that would have been easily remedied by DSP is that while the VLOT speakers have a subwoofer signal output, they have no bass management. The subwoofer output would have been a much better feature if there was a way to high-pass filter the speakers. The speakers have fine bass extension as it is with extension to below 50Hz, so if you don’t want the system to double up on deep bass (on a loudspeaker that is already bass heavy), you would have to set the sub’s low pass filter to about 50Hz or maybe slightly lower. A 50Hz low-pass filter is a waste of headroom on a system with the VLOTs since most subs would be able to handle the range from 50Hz to 80Hz or higher with a lot more power than the VLOT’s 4” bass drivers can handle. What’s more, an internal high-pass filter on the VLOTs could take a load off of the woofers which could be driven to make some distressing noises with low-frequency signals at higher playback levels.
Some things that
would be neat to see in future versions of a speaker along these lines would be
an app control like so many subwoofers have these days. An app with volume
control, EQ with tone controls, and input selectivity would be pretty neat,
although I realize that app controls are expensive and complex to develop.
Something else that would be nice to see included would be HDMI connectivity,
although I realize that is not a simple matter either. However, the current
prevalence of HDMI would make such an input to be a rather useful feature.
Something worth mentioning is that the VLOT speakers worked fine without any weird hitches or bugs. The reason why that is worth mentioning is that I half-expected that something of its complexity would have at least one thing not quite run smoothly as so often happens on so much consumer electronics these days, but the VLOT speakers really were a matter of plug and play. That was a pleasant surprise, although perhaps it shouldn’t be, but that says more about the state of the consumer electronics industry than the product under review.
As a fairly heavy-duty audio enthusiast, I am willing to make more room for loudspeakers and electronics than the kind of people that Starke Sound is aiming at with the VLOT speakers. However, I think they largely hit the mark for their intended buyer. They have the ease of use of a soundbar, but they offer a more full-bodied sound as well as an actual stereo soundstage from a floor-standing speaker. Soundbars can not really deliver a soundstage since they are essentially monoaural devices. Listeners would have to be seated ridiculously close to a soundbar to get any real sense of stereo separation. My hope is that Starke Sound can use the VLOT platform to develop the idea into more formidable speakers that can partially supplant the use of soundbars, so that more people can have actual loudspeakers in their homes again, much like the golden years of hi-fi when every middle-class home had a serious stereo system.
— Excellent
— Very Good
— Good
— Fair
— Poor
| Metric | Rating |
| Build Quality | |
| Appearance | |
| Treble Extension | |
| Treble Smoothness | |
| Midrange Accuracy | |
| Bass Extension | |
| Bass Accuracy | |
| Imaging | |
| Dynamic Range | |
| Fit and Finish | |
| Performance | |
| Value |
