SVS SB12-NSD Subwoofer Review Conclusion
I
enjoyed my time spent the SB12-NSD. It has many positive attributes
such
as the compact form factor, excellent build quality and well rounded
performance. The SB12-NSD exhibited excellent pitch definition and
neutrality while having enough headroom in the typical kick drum
range to provide some fun factor as well. The performance turned in
with music in particular I felt was great and along with the
measurements taken outdoors indicate that it would make a very
effective subwoofer for a nearfield monitor system in a project
studio or for smaller spaces. Being a small, lightweight sealed
subwoofer you cannot expect the SB12-NSD to bowl you over with pants
flapping deep bass output, which it does not. Multiple SB12-NSD’s
or perhaps one of SVS’s larger and more expensive vented offerings
will be required for that type of powerful deep bass extension.
However the SB12-NSD does have a surprising amount of headroom for
its size which accompanied by the exceptional limiting employed by
SVS allows the SB12-NSD to operate up to the limits of its
capabilities even in large rooms without having to worry about
damaging it or having your experience degraded by bad overload
noises. This was shown during movie nights where the SB12-NSD was
clearly a little short on firepower for loud playback in my large
4,000+ cu ft room, yet still managed to provide an engaging and
enjoyable experience. Note that if the SB12-NSD (or any other
subwoofer) were employed in a smaller system/room than mine, which is
rather large and difficult to fill, it would likely take on a much
more muscular, powerful character.
At $649 shipped this is SVS’s least expensive and smallest subwoofer, but it still performs in a big way. If you need extra headroom and deep bass output you may want to scratch up an extra $120 and move up to the larger vented PB12-NSD, but many people will have a smaller room or want a smaller form which is easier to fit into their living space and this is where the SB12-NSD excels. The extra cost savings is nice as well. Whenever possible I recommend that at least two subwoofers placed in separate locations be at least considered as in many cases it can help to smooth the overall in room response and increase maximum headroom capability. SVS just so happens to offer a nice discount on a pair of SB12-NSD’s and in my opinion this is where the SB12-NSD would really start to shine. Due to the compact size it should open up more placement options for multiple units than if larger subwoofers were used and in many cases multiple smaller subwoofers can turn in a better overall performance than a single more powerful and expensive unit. Multiple SB12-NSD’s spread out would provide an excellent cost effective bass foundation for a moderate sized room while occupying a minimal amount of space. Highly recommended.
The SVS SB12-NSD receives the Audioholics Bassaholic Medium Room rating, which means that this sub is recommended as maintaining adequate headroom in rooms or spaces of between 1,500 to 3,000 cubic feet and/or for users who usually listen at moderate volume levels. For further information in how we make these recommendations see the full article here.
See: Audioholics Subwoofer Room Size Rating Protocol
SVS
SB12-NSD Review
SVSound.com
Toll
Free: (877)-626-5623
MSRP:
$649 (Shipping Included)
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Bass Extension | ![]() ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() ![]() |
Ergonomics & Usability | ![]() ![]() ![]() ![]() ![]() |
Features | ![]() ![]() ![]() ![]() |
Dynamic Range | ![]() ![]() ![]() |
Value | ![]() ![]() ![]() ![]() |
See also:
Recent Forum Posts:
the CEA-2010 measurements presented here are taken at 2 meters outdoor groundplane and are “rms” not peak values. This is equivalent roughly to a 1 meter anechoic (free space) SPL measurement.
The indoor SPL levels are considered to be a corner loaded subwoofer which puts the sub in 1 meter 1/8th space which adds +18dB over a 1m anechoic (free space) measurement. We are considering the listening distance from the subwoofer as being roughly 4 meters in most cases which drops the spl by 12dB (18-12= +6dB at this point.) A peak SPL report of the same signal reported via an rms calculation method will produce about 3dB higher numbers. (Add 3+6= +9dB) So that is why we are adding 9dB to the reported CEA-2010 numbers to compare them with the indoor peak SPL numbers required.
Note that if a sub just barely misses in one frequency band by a single dB or less, for example falling short by 0.7dB at 31.5Hz only, we will go ahead and give it the benefit of the doubt as long as it meets the other criteria since it is a drastic 6dB drop back to the next smaller room size.
I'm sorry but now I'm a little confused on this issue as well.
From what I understand, the sb12 scored a raw score of 96.3db at 25hz. From there, are you adding in the +12db from putting it in the corner as well as adjusting it +6dB for the conversion?
Is its total score 102.3 or 104.3?
Thanks,
-Matt
