Aperion Audio Bravus II 12D Subwoofer Listening Session
For all of the listening sessions the Bravus II 12D was placed in the front right corner of the room with the PR about 3 inches from the wall. This places the subwoofer about 4 meters from the primary listening position. I have determined this to be the best available single subwoofer placement in the room for most units. Audyssey was run on the system to allow it to integrate the Bravus II 12D, which was then followed by a check and recalibration of the subwoofer and speaker levels prior to the listening sessions. It is assumed that the majority of purchasers would utilize some form of automated room correction system to integrate a new subwoofer. The Bravus II 12D’s internal low pass filter was defeated in favor of a 100Hz internal one inside of the Onkyo PR-SC886P processor.
Editorial Note: I have recently moved into a new home and have a listening room that is significantly different from my previous one. The new room is a smaller 3150 cubic ft but open to a large hallway connecting to the rest of the basement with a shorter ceiling and more complex shape. Additionally the new room is cement slab floor with 3 walls of brick as opposed to the larger wood frame and floor constructed room I had been in. This room is easier to drive than the old space but has much less tactile transmission so I now use a -10 master volume setting for movie playback instead of -15. I am still slowly getting acclimated to the differences in sound in the new room.
Music: With the 12D being the first compact subwoofer that I have listened to in
the new house I was curious as to how it would behave and how much energy it
would impart in a space without wood framing to energize. Turns out it did
rather well. I started off listening to random selections from my collection
including but not limited to: Loreena
McKennit, The Police, Animals as Leaders, Red Hot Chili Peppers and Volbeat. Throughout which the 12D
happily provided solid fundamental tones and support to underpin the music. The
electronic bass tones, bass guitar and drum work from various random genres of
music were all well reproduced by the Bravus 12D and without any sense of over
emphasis on any particular part of the bass spectrum. The sound was neutral and
clear at typical listening volumes for me, especially through the crossover
region. So far so good. For a greater in depth listen I decided on the “Red” album
by the rock band Baroness. This album
has a distinct and clear bass guitar tone that is set very nicely in between
the drums and guitar in the mix while the drum set has a large and thumping
kick drum and booming floor toms. The music is at times relaxed and meandering
and other times morphs into furious rock riffing with the result being that it
sounds better the louder it is turned up. As usual I started off at low volume
for the first couple of tracks where the 12D did a great job tracking the often
wandering bass line amidst the dense guitar and drum work at which point the song
Isak came on and volume knob was
twisted up a bit more. The 12D responded with more volume and seemed to have no
issue with maintaining composure even among the most treacherous and twisty
passages. Tonal accuracy was very good with no obvious smearing of notes, loss
of purity or lack of kick drum attack. The final track is Wailing Wintry Wind which starts off with a great drum build up
running from the rims, to the snare, into tom work descending into the floor
toms before finally breaking into full riff and a bass line that is complex and
prominent with fundamentals covering most of the mid bass and typical crossover
region between sub and mains. During this build up the drums are mixed loudly
with the snare thick and woody when laid into and the floor toms cavernous. I
turned the volume up a bit louder still for this track and the 12D was up to
the task and produced a strong presentation of the low register present in the
track without the warming over or smearing sound that often occurs when smaller
subwoofers are asked to do heavy lifting in a large open room. The kick was even
starting to get a bit of tactile sensation to it and the bass line was still clear
despite the heavy kick drum being reproduced at the same time. Certainly there
are limits to the Bravus 12D but I was impressed at the composure and what
amount of “fun factor” was available from such a compact unit.
Blu-ray Movies: The Grey
Since the
12D did so well supporting the low end of all of the music I listened to, I was
curious to see what it could do with the louder and much lower frequencies
present in modern movies. One movie that I viewed with the 12D covering the
bass range was The Grey starring Liam
Neeson, which isn’t the most demanding soundtrack ever but has a couple of
parts requiring significant power from the subwoofer. There are plenty of
background bass rumbles that accompany the howling Alaskan wind throughout the
movie and it can get quite loud at times. The 12D did a good job of
transporting me into a howling gale force wind when called to do so. Near the
beginning Liam Neeson’s character goes into a bar which is accompanied by loud bar
music. Here the 12D again did a nice job of acting like a bigger sub system and
projected lots of thumping bass into the room sufficient for me to believe that
I might actually be in a club. At about 25 minutes into the film the plane that
the workers are riding in experiences major catastrophic failure in several
systems and the horrific plane crash that follows is home theater demonstration
quality material with violent bass and lower midrange reproduction required
from the subwoofer and mains as the plane disintegrates and plummets from the
sky before finally plowing into the ground. The 12D valiantly gave its all
during this section and produced lots of roaring bass to accompany the onscreen
destruction but seemed to lack the lowest bass frequencies and dynamically the
presentation seemed a bit squashed and muted compared to what it can be. Less
scary lets say. Similar to the difference between experiencing a plane crash
from a hundred feet back rather than having the plane crash around you. I also
thought that I perhaps heard a bit of overload or distortion from the 12D
during this part but with so much going on at once I can’t be sure. This is a
very difficult piece of audio for any subwoofer to handle at these volumes so
considering the price and size of the 12D the fact that it gave a good account
of itself in a large room during this section without going into protect or
obviously sounding bad is a result to be proud of. The 12D can produce
substantial bass output but for loud HT playback adding a second 12D would be
worthwhile.
See also:
Recent Forum Posts:
Looking at the build quality, driver complement (i.e., one 12“ driver plus two 12” rads), and amp power, that's not a bad price for the performance provided and box size.
theJman, post: 921826
You mean the one were you said "If there is an issue shown in the waterfall it will usually show up in the group delay chart or vice versa"? If so, that's what actually prompted my original post.
The ‘usually will show up’ part is a bit of a concern, but the biggest issue I guess is the waterfall is easier for me to read/decipher. That, along with the distortion and compression tests, are usually the first ones I look at, because combined I think they give a good picture of the basic functionality of the sub.
Maybe Ricci will put those up at his data-bass website, if he adds the Aperion data there.
Ricci, post: 921733
See my comment about the waterfall and group delay above.
3db, post: 921761
I don't know what all the excitement is about this sub. I think its performance for the money is not all that great…If given my choices, I would take the Outlaw over the Aperion.
Sure, if you can fit the Outlaw, it's a much better option. But keep in mind, the Aperion is a 15.5" cube. For what it is, it performs quite well.
