Oppo HM-31 Build Quality and Conclusion
The Oppo HM-31 HDMI Switch is exactly what you'd expect - a little black box. The packaging is well done and plenty protection enough for anything but the most egregious shipping abuse. As all Oppo products seem to be these days, the HM-31 arrived wrapped in its own little black cloth (feels like burlap) container. It's actually form fitted so it could be used to protect the switch if you wanted to bring it somewhere (I'm sure someone does this). The edges of the switch are glossy black with a top of brushed aluminum. The bottom has three keyhole mounts for wall mounting. There are four sticky feet that can be affixed if you don't plan on wall mounting the unit. Overall the HM-31 is solidly built and very nice to look at.
The
back of the unit has three HDMI inputs, one output, an IR input, and an RS-232
port. The front of the unit has an IR sensor dead center with a power indicator
just to the right. The top of the unit also has an IR sensor for wall mounting.
On the far right is a manual selection button which cycles through the
different inputs. On the left are three lights, one for each input. The lights
will not be illuminated if there is either nothing plugged in or no signal
coming from the component that is connected. Red indicates that there is
something plugged and transmitting and blue indicates that the input is both
selected for output and is transmitting. If it is selected but there is no
signal then the blue light will blink.
Setup and Use
Setting up an HDMI switch is not exactly
rocket science. All you need to do is attach the power cable, all the input and
the output HDMI cable, and plug in the unit. The unit doesn't have a power
button so it is on all the time (this is a good thing). Once you connect a
cable, the unit will immediately recognize it (if it is providing a signal) and
route it to the output. I never ran into a problem with HDCP handshake issues
or any of that nonsense. Oppo's literature says that the HM-31 will pass 12-bit
Deep Color so you should be OK no matter what you buy. At least until they
change the HDMI spec again. Understand that this "literature" of
which I am referring is on their website. As far as I can tell, the manual is
of the most basic level and doesn't address the auto sensing or signal boosting
functions.
The
HM-31 has a nifty little feature that will automatically switch inputs for you
depending on which is providing a signal. The idea is that it does two things -
first it prioritizes the inputs with Input
1 having the highest priority and Input
3 the lowest. Second, it recognizes when there is an incoming signal. With
some careful planning, you can take advantage of this auto sensing ability.
What you'll first want to do is to plug in all your HDMI components with their
power OFF. Check to see if there is a red light on the front of the unit. If
there is, that means that even with the power off the component is putting out
a signal over HDMI. This is important to know for later. At the time of the
review I had the Sony BDP-S300 Blu-ray player which did this as did my Comcast
HD DVR box. The Denon DVD-3910 did not.
Now
the next step is to order your components on the inputs. In a perfect world
you'd have no more than one component that is always putting out a signal even
when it is powered off. You'll want to plug that component into Input 3. For instance, if you have a DVD
player, an HDMI game system, and a HD DVR (which is always putting out a
signal) you could plug in the DVR into Input
3 and the other two wherever you want. When the DVD and game system is
powered off, the HM-31 will default to Input
3. As soon as you power on one of the other components it will immediately
switch to that input. If you power them both on, it will switch to Input 1 (remember, Input 1 has the
highest priority). In this scenario you'd never have to use the remote, RS-232
port, or IR input on the back of the unit. You'd just have to remember that if
you want to see what is on Input 2,
whatever is on Input 1 would have to
be turned off and likewise the components on Input 1 and 2 would have
to be powered down to view Input 3.
If
you have two components that are constantly sending a signal, you'll have to
use some method of control over the HM-31 as the unit will constantly default
to the lower numbered input. You have a number of options available to you, the
least sexy of which is the hand held "made to be lost" IR remote. The
back of the unit sports an RS-232 port and an IR input for direct control from
an RF receiver. Of course you can always use an IR flasher on the front mounted
IR receiver if you want. The RS-232 control is really the most unusual of the
control methods and is nearly unheard of at this price point. Of course, RS-232
is useless without the proper protocols, and Oppo indeed provides those on
their website in the form of a downloadable
PDF. Installers should be rejoicing right now at a $100 switcher with so
many options. With the right components, they may not even have to program the
thing!
The last claim on the Oppo website about the HM-31 is that it will act as an HDMI extender through its HDMI "signal equalizer". According to the site they "tested the HM-31 successfully with a 50-foot cable between the source and the HM-31's input, and another 50-foot cable between the HM-31's output and the TV. The total cable length from the source to the TV is 100 feet." This claim seems a bit dubious to me, especially taking 1080p and 12-bit color into account - but I don't have 100 feet of HDMI cable lying around to run my own test so we'll have to take them at their word. My guess is this test was conducted with a 1080i signal at 8-bit color. At the very least, the signal boost shouldn't hurt your connection and may actually help if you've got a poorer performing cable with a run at the end of its usable length.
Manufacturer Note on Extender Testing Methodology
In the test we used 2 pieces of 50-foot 22 AWG HDMI cables. For the visual test we used the 1080p60Hz output from our own DVD player and a Sharp Aquos 1080p TV. There was no HDCP or visual problem. For instrument test we used a Quantum Data 802BT HDMI signal generator and analyzer. We did the HDCP test with the Sharp TV, again at 1080p, and found no error in 200 rounds of test. We also did the loop back test (802BT TX – 50ft HDMI – HM-31 input 1/HM-31 output – 50ft HDMI – 802BT RX) at 1080p60Hz, the 802BT measured 0 pixel error on all three TMDS channels. At this point we do not have in-house equipment to test HDMI 1.3 with Deep Color. All HDMI 1.3 test for this switch were done initially at the Silicon Image Shanghai test lab (an official HDMI.org authorized test center), and then confirmed again at Silicon Image Sunnyvale CA test lab (another HDMI ATC). The HDMI 1.3 tests done at the ATCs do not include long cable test but their eye-diagram test has the same effect and is a more scientific way to measure transmission loss.
Remote
If you've
seen one of these remotes, you've seen them all. Smaller than a credit card and
only barely thicker, this remote is just the right size to be lost forever in the folds of your couch. What I like about
this one over some of the others that I've use is that it has both an input
toggle button and individual input selection buttons. A nice feature.
Suggestions for Improvement
Absolutely none.
What's to say about an HDMI switch? It
either works or it doesn't. This one works and, with the auto switching
feature, it may make it painless for you to set up. Even if you have to control
it directly, you have just about every option under the sun to do so. Fully
featured? Oh yeah. And at this price point, it's a no-brainer. If you need an
HDMI switch, this is the one to buy. You may find an HDMI switch for cheaper,
but it'll likely be missing some of the features that this one has. Make sure
you really don't need those features before you purchase something else.
About Oppo
Based in the heart of Silicon
Valley, award-winning OPPO Digital, Inc., manufactures and markets
high quality digital electronics that deliver style, performance, innovation, and
value to A/V enthusiasts and savvy consumers alike. The company's attention to
core product performance and strong customer focus distinguish it from
traditional consumer-electronics brands.
Oppo HM-31 HDMI Selector Switch
$99.99
OPPO
Digital, Inc.
2629B Terminal Blvd.
Mountain View, CA
94043
[email protected]
Phone: (650) 961-1118
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Video Performance | ![]() ![]() ![]() ![]() ![]() |
Ergonomics & Usability | ![]() ![]() ![]() ![]() ![]() |
Ease of Setup/Programming/Integration | ![]() ![]() ![]() ![]() ![]() |
Remote Control | ![]() ![]() ![]() ![]() |
See also:
Recent Forum Posts:
fmw, post: 325398
I was disappointed in the Oppo switcher because it doesn't turn on and off. It stays on constantly. In other words, for me it isn't full featured at all. I had one of the little 2 port switches from Mono price. It was less than half the price of the Oppo and was a better unit all the way around. I could even program it to turn on and off with my universal remote. I got the Oppo when I needed to upgrade to a 3 port unit thinking it would be better than the Monoprice. Not better. I recommend the Monoprice.
Who cares if you can't turn it off? Why would you really want to?
Austin M, post: 325331
Can you plug this into one of the HDMI-switching ports on a Denon receiver (expanding the number of HDMI ports), or does this need to plug straight into the TV? Do HDMI devices work when routed through two switches?
Clint already answered this but again, yes. For the review, the Oppo was used between two transports and a Denon 2307CI receiver. I experienced no problems.
blacks4, post: 325071
I have an HD-XA2 which won't work at all through a 5x1 HDMI switch from Impact Acoustics. Toshiba said it's not meant to work through a switch (only a direct connection or through an HDMI receiver).
I'm just curious if this switch is any different. Thanks.
- Steve
I'll be testing this out as soon as I can. I'll let you know.
