Emotiva ER Build Quality
If you attended the Audioholics 9th Annual State of the CE Union Event last year, you probably heard Emotiva's new speaker offerings long before I did. That's the joys of attending such a progressive event. Reportedly, people walked away from the Emotiva demo so impressed that they pre-ordered speakers on the spot. Well, for everyone that has been sitting on the fence in anticipation, the wait is over. Emotiva's speakers are here (well "here" meaning "at my house" - they're not shipping just yet) and the review is done. What's the final verdict? Read on to find out.
First Impressions
quick conversation with Dan Laufman, President of
Emotiva let me know a few things. First, he is very proud of these speakers and
second, I'm getting a preproduction set to test (or at least the packaging and
grills were). This is good in that this review will get to you while you still
have time to preorder but bad in that some of the issues I've experienced with
these speakers will be resolved before the first set ships to any customer. As
is my custom, I'm going to report, unedited, my experiences as well as any
changes Emotiva has made to the actual production speakers. What is most
important with this, or any, set of speaker is how they sound and I've been
assured that those components won't change at all.
The ER (Emotiva Reference) line
of speakers so far consists of a bookshelf speaker (ERM-1, the "M" stands
for "monitor) and a dipole surround speaker (ERD-1, guess what the
"D" stands for). The ERM-1 speakers
are all boxed individually while the ERD-1 speakers are boxed as pairs. Each
speaker or speaker set has a molded foam top and bottom cap and comes in a
black cotton sock. While I understand that the sock is meant to convey quality
and "audiophileness", it mostly just makes handling the speakers akin
to wrestling a pissed-off fish. Luckily, the size and weight of the speakers
means this isn't much of an issue. The ERDs were double boxed while the ERMs weren't.
Regardless, all the speakers arrived undamaged and in good working order.
Emotiva has provided a mounting plate for the ERDs and included two slots in
their endcaps to ensure that the plates didn't damage the speakers in transit.
Once I got the socks off, I got a chance to take a good long look at the speakers. I'm used to one of two finishes on speakers - glossy or wood grain. The Emotivas were neither. If I had to describe them I'd call them a satin black. It has as non-reflective a surface as you'd hope to see on a speaker. While this might not make for the most aesthetically pleasing appearance in the light of a showroom floor (on in a review's pictures), it is extremely functional in a home theater environment. Sure, they look more like studio monitors than pieces of furniture, but in a dark room, all you really care about is not reflecting the light from your display. The finish did seem to prone to showing every little speck of dust or finger smudge that hit them. The front plate on the speakers and the backplates are both black aluminum which is an unusual choice of parts in a speaker in this price class. From an aesthetic standpoint, it doesn't seem to make much of a difference but functionally, it does. The front adds stability and rigidity to the enclosure while the back is used to mount the crossover. Let's face - it speaker enclosures are generally designed to be as rigid as possible. Most manufacturers use some sort of plastic backplate. What do you think is more likely to flex, a plastic backplate or metal one? Yeah, me too.
Branding on the Emotiva speakers was nearly non-existent with the Emotiva name on the back plates and the mounting bracket. According to Emotiva, you can expect a small logo on the grills. The logo on the ERM will have the ability to rotate for those that want to use the bookshelf lying on its side as a center. The grills on all the speakers are held in place by magnetically charged posts. During transit, the speakers were shipped with a small buffer sheet between the speaker and the grill in order to keep it from scratching up the faceplate (presumably). Unfortunately, during the shipping process, the speaker pressed against the grill and pushed some of the magnets in. This was easily corrected by pressing them back into place. Emotiva has informed me that the full production models will be packed so that the grills aren't under any stress and a stronger glue will be applied to the magnets.
Aesthetically, the Emotiva ER
speakers are just "OK" in my book. I can't get excited by the finish
no matter how functional it is. The black box, black drivers, black aluminum
plate thing reminds me more of studio monitors than actual home theater
speakers. This is great for the ERD-1s
as they are on-wall but for the ERM-1s, which are out in the open, I feel it is a hard sell. Some speakers
look better with the grills on, others with them off. The Emotivas are so uniform in color that they look about the same. Personally,
I'm all about the performance so I'm not as concerned about looks but in many
households, looks is one of the (if not the)
most important thing. I have a hard time believing that Mrs. Consumer is going to get excited about the ER speakers. Gene DellaSala, on the other hand says, " I was quite
impressed with the appearance of the Emotivas as they remind me of the M&K speakers back in the day. They are designed to look like
professional monitors with a single aesthetic goal – to disappear into a home theater.
Also, statistically, black speakers outsell any custom finishes as they are the
easiest to blend into virtually any room décor and the lack of an added price
premium makes it more appealing." As they say, beauty is in the eye of the
beholder.
Build Quality
Let me say that I've had a "grass is greener" sort of
outlook on the whole magnetic grill thing. The Emotivas are the first speaker
I've ever tested with magnetic grills and I've long wanted to. Well, now that I
have, I have to say that I'm a little disappointed. There were no
"dimples" or anything to ensure that the grills were centered so you
had to fiddle with them in order to get them true. Even then, I'd look at them
and think that they were off. Now, I had the problem with the recessed magnets
but I must mention that during some of the listening tests the grills rattled.
I ended up having to adjust the magnets a number of times to get it right (I
think I cracked one of the grills when I did that). If Emotiva is going to use
stronger glue, I HIGHLY recommend that they make sure the fit and finish is
dead on with the grills. Any gap on any one of the magnets is enough for a sub
to take advantage of. Lastly, the magnets just weren't all that strong. Any
little bump and the grill would shoot off. Once you have the speakers set up it
wasn't much of a problem but try mounting a trapezoidal speaker on a ladder
with grills popping off at the slightest provocation. With the tweeter dome
slightly raised from the front baffle, I'm shocked that I didn't damage one of
them at some point.
While the drivers on all the
speakers are identical, the ERMs have two of
the 5.25" composite cone woofers while the ERDs have only one. The woofer
on the ERDs are pointed straight out while the two 25mm tweeters are on either
of the angled sides. The rear of the ERMs have dual
binding posts and a large gold jumper between the two. You also have a two
position switch for Boundary Compensation (on or off) and a three position
switch for Tweeter adjustment (0, -2dB, +2dB). While I've come across many a
piece of AV equipment with buttons, switches, and menu items that seems to be
more decorative than functional, it was easy to hear a difference between all
the switch settings without any test equipment. The ERDs had two switches as
well to orient the speaker for left or right dipole or bipole configuration.
The speakers all utilize a sealed design meaning no ports. The five way binding
posts on the ERMs were large,
well spaced, and easy to access. The binding posts on the ERDs however were
small, tight, and couldn't really accept 12 gauge wire. It was possible to get
12 gauge in them securely while the speaker was on a flat surface, but while
standing on the arm of my couch and balancing the speaker on one arm while
trying to insert the wire with the other… well, I had problems. I think that 14
gauge is probably the largest wire these binding posts can accommodate. Since
12 gauge is the standard recommendation we make for wire run to the back of
your room, I'd like to see the binding posts accommodate. I suppose if you
don't mind cutting out a larger hole behind the backbox you could use banana
plugs.
Taking the speakers apart, I
immediately noticed that Emotiva used all threaded inserts. I also noticed a number
of really high quality components. First, the Ferro-fluid cooled 25mm tweeter has its own heat sink mounted on the neodymium
magnet which is essential for such small motor structures for realizing
uncompromised performance at high power levels. The basket on the woofer is
cast rather than stamped typically found in speakers of this price class. The
cabinet is well dampened with a ton of polyfill shoved in the back half of the
enclosure. And by "ton" I mean a whole lot. I'd venture to say there
was as much if not more polyfill in the ERM-1 as in most
of the tower speakers I've reviewed! There is only one area of bracing in the
ERM and it runs the circumference of the
speaker from top to bottom. It's sort of hard to describe. Basically it is
midway between the front and back of the speaker all the way around the
circumference but it just along the walls and not all the way through the
center. There is also additional bracing around the extremely large crossover
and backplate. Needless to say these speakers are well braced and you get a
deadening thud when wrapping on the side of the cabinet.
The
enclosure is constructed out of 5/8" MDF and the 6mm
aluminum face and backplates are countersunk so that they are flush. The
crossover is an asymmetrical 4th order Linkwitz Riley design utilizing precision
metal film capacitors and low DCR air core inductors. Since the speakers were
designed with THX specs in mind, they roll off at 80Hz and no impedance dips
below 3.2 ohms. This also explains some of the dispersion characteristics I
noticed later in my listening tests (specifically the off-axis response). With
all the attention to detail that I'm seeing here and the adherence to THX specs, I wouldn't be surprised to see a future
iteration of these speakers with THX certification.
Recent Forum Posts:
I think you're right, most places would charge extra for the new grills, but I'm not surprised Emotiva didn't, doesn't seem their style.
Just something else that makes me pleased with my decision to go with the ERDs… -TD
Emotiva just started sending out new speaker grills for all owners of ERD-1's and ERM-1's. FREE
Not that there was anything wrong with the old grills. They just weren't happy with them. The new grills have a little darker black appearance and don't have the slight sheen of the older grills. They also include a new circular chrome company emblem with the “E”.
I received mine last week. They make a great speaker even better.
Most companies would just add a new item to new sales and call it an “upgrade”.
But they went through the expense of shipping them to all owner.
Initially, I thought they were very good surrounds for the money, this was back when they dropped the price from $350 to $315. Now that they are selling at $250 a pair, I'd have to say these are an outstanding deal.
My first objective was to compare them to the performance of the Axiom QS8s that I'd previously owned. While they didn't quite seem to measure up to them at the time, I'd have to say after having them for a couple of months now, they more than hold their own for movies and I'd have to say outperform the QS8s with music. I thought the QS8s would be be impossible to best at their price, but the ERDs hold their own and then some. When you see/hear how well the ERDs perform, you'll be amazed at how tremendous a value they really are… -TD
http://emotivalounge.proboards54.com/index.cgi?board=speakers&action=display&thread=1876
babs, post: 444899
Though I'd certainly never expect the ERM's to hang with B&W 805's at $2k+,
The ERM-1 display many of the qualities I prefer in speakers at any price point. I found them to be clear and detailed without being bright, neutral and without the resonant midrange that I find in a lot of speakers. I think it's an outstanding speaker for the list price, but free is even better. Combined with a good sub, they will be hard to beat (at least to my ears).
