Oppo on the Inside, Lexicon on the Outside
It's an Oppo BDP-83. Normally we'd launch into a statement like this with more tact. We may, for example, wax eloquent about the Lexicon BD-30's beautiful chassis or it's billet aluminum front face. We could tell you about the heft of the unit, or the fact that comes double boxed with enough padding to warrant throwing it off the FedEx or UPS truck while it's still moving. While all of that is true, the Lexicon BD-30 is still an Oppo BDP-83 Blu-ray Player. And what's more, it's not just using the same parts - they actually stuck the player inside - chassis and all. This would be OK, were it not for the $3000 premium over the Oppo and THX certification. As Sherlock Holmes would say: The game is afoot!
We first had an inkling that the Lexicon BD-30 was in fact an Oppo clone when we saw it at the 2009 CEDIA Expo in Atlanta. Looking at the player, its button layout and, most importantly, its rear panel, showed us that this product had the exact same layout as the Oppo BDP-83 Blu-ray player. What we didn't know, was how much technology they borrowed or how they repackaged the technology. According to the reps at the show, Lexicon had merely taken components of that player and tweaked them to make it their own - adding technology and making improvements to what was a good basic building block.
What a load of hogwash. When we received the player the first thing we did was open it up to get a look at the inside. Imagine my surprise when I found that not only did the Lexicon share the same boards and transport as the Oppo - it was in fact AN OPPO BDP-83 PLAYER, CHASSIS AND ALL, SHOVED INSIDE AN ALUMINUM LEXICON WRAPPER. As far as we could determine, Lexicon didn't change a single thing in terms of the hardware. Heck, they didn't even lift the boards out of the chassis, opting instead to cut out the bottom of their own chassis to accommodate the venting locations, and putting a darker blue filter over the Oppo's VFD display to give it a slightly deeper hue.
Don't take our word for it, however, check out these pics (click on them for larger images):
Lexicon BD-30 on the left, and the Oppo BDP-83 on the right.
Notice the identical extrusions on the bottom and the venting of both players. The reason they are identical is because the entire BDP-83 chassis is sitting INSIDE the Lexicon BD-30 player. Even the mechanical dampening is the same, as are all wiring and capacitor values and tolerances. Lexicon merely took off the backside so it could fit the connectors flush to its own back plate, and placed a billet aluminum faceplate that sits over the existing Oppo button and VFD hardware.
Lexicon BD-30 on the left, and the Oppo BDP-83 on the right. Same transport, same caps, same anti-vibration material, same CHASSIS
Wanting to do due diligence, Gene DellaSala made me take apart the Lexicon BD-30 after the fact (for the third time) to verify the cap rating, since we noticed a color discrepancy on the two players with a series of three caps on the power supply board. After taking a close look, we verified that both sets of caps are indeed 2200uF 16V caps with a rating of 40-105 degrees C. We have no reason to believe the discrepancy isn't simply due to the fact that my Oppo BDP-83 player, being from an earlier run, used capacitors from a different batch or manufacturer, but at the same specs and rating as those used by current models.
Lexicon BD-30 on the left, and the Oppo BDP-83 on the right. Not a single improvement to the power supply could be found
Lexicon BD-30 on the left, and the Oppo BDP-83 on the right. The more you look, the more amazing it becomes. This is a $3000 chassis.
And the back of the player, of course, sports exactly the same connections on both players, since Lexicon simply used the Oppo's back panel as a template and manufactured its own to meet the height requirements of fitting the Oppo inside.
Lexicon BD-30 connections
Oppo BDP-83 connections
The belly of the Lexicon BD-30
Possibly the funniest shot was the one we took of the bottom of the Lexicon BD-30 Blu-ray player. Here you can see that they literally cut out the aluminum bottom to make space for the vent holes of the Oppo's chassis. If you didn't "get" that Lexicon actually put a full Oppo BDP-83 INSIDE of a chassis, slapped a label on it and is shipping it for $3000 more, this photo should help. Of course, they did add a Lexicon splash screen to the menu system (which, by the way, is identical to the Oppo except that some items are reordered) and a billet aluminum faceplate is certainly nice.
So where is our review of the Lexicon BD-30, you ask? It's right here in our review of the Oppo BDP-83 Blu-ray player. We see no reason to waste the time or energy in reviewing the Lexicon when they clearly just put an Oppo BDP-83 into a new case. What did, however, run a series of benchmark tests on the Lexicon player to see if it measured identically to the Oppo BDP-83. As you will see, the results are quite astounding and speak volumes about THX and their certification requirements.
Measurements and Analysis
Tested by: Gene DellaSala
Using the Audio Precision APx585 8 Channel HDMI Audio Analyzer, we measured the analog outputs of the Lexicon BDP-83, oops we mean the BD-30 in the same manner we tested the Oppo BDP-83 using the identical 0dBFS 192kHz 6-channel Dolby TrueHD test signals. Our detailed analog audio test report of the BDP-83 and BPD-83SE was already published herein and we pulled some of the measurement graphs to place them side by side with the Lexicon BD-30 so the results can be more easily compared.
Bass Management
One of the staples behind THX certification has always been to maintain an 80Hz crossover point on all THX certified electronics. As we measured prior, the Oppo BDP-83 did not meet this requirement which wasn't really a huge deal since it wasn't THX certified. We were interested however in measuring the Lexicon BD-30 which was THX certified to see if Lexicon fixed this design deficiency and if THX even tested for it.
Bass Management Frequency Response
Oppo BDP 83 (left graph) and Lexicon BD-30 (right graph)
LPF | HPF |
fc | Slope | fc | Slope | |
Oppo BDP-83 | 143 Hz | 18 dB/ Oct | 90 Hz | 13 dB / Oct |
Lexicon BD-30 | 140 Hz | 18 dB / Oct | 88 Hz | 14 dB / Oct |
THX Spec | 80 Hz | 24 dB / Oct | 80 Hz | 12 dB / Oct |
Bass Management Tabulated Test Results
An ideal THX certified product should exhibit a -3dB rolloff at 80Hz with a 12dB/octave slope for the High Pass Filter (HPF) and a -6dB rolloff at 80Hz with a 24dB/octave slope on the Low Pass Filter (LPF). As you can see, neither the Oppo NOR the Lexicon players meet this requirement and they actually measure identically to each other. The slight tabulated variance is a function of cursor interpretation error on the graphs combined with measurement variances caused by component tolerances. Based on our findings we can unofficially (but in practicality) state that the Oppo BDP-83 is (or might as well be) THX certified despite the bass management doesn't meet their 80Hz 12 dB/octave HPF and 24dB/octave LPF requirements.
Frequency Response
We previously measured a 2.5dB bump above 20kHz on the Oppo BDP-83 when running all channels full range and using a 192kHz Dolby TrueHD test signal. We were curious to see if the Lexicon exhibited similar peculiar behavior.
Analog Fullrange Frequency Response
As you can, see both players exhibit the same frequency peaking above 20 kHz. Incidentally, both players also produce a full range signal via the subwoofer output channel which Oppo deliberately did to accommodate users playing Chesky 6.0 DVD-Audio discs that require a full range subwoofer channel. Although THX doesn't disclose the type of testing they do, we have a hard time believing the frequency response non-linearity we measured above 20kHz would fit within their acceptable performance window.
Distortion (THD + N)
Distortion (THD + N) vs Frequency
Both players exhibited virtually identical and excellent distortion measurements for the main channels. When I originally bench tested the Lexicon BD-30, I restricted my tests to the two main channels plus the subwoofer to quickly identify if there were any differences. There of course weren't any so we wrapped up this article indicating that both players appeared to be identical in terms of audio performance.
On January 17th, 2010, a contributing editor of Widescreen Review named Amir correctly pointed out I should check all of the channels to ensure there were no differences. Since I only tested 6 channels in the Oppo, I repeated my test of the Lexicon with the six same channels. To my surprise I found the subwoofer channel went into gross distortion on the Lexicon BD-30. It took me several hours to realize this was a result of setting any channels but the main front channels to "small". Apparently there is a bass management recombination issue with the Lexicon that doesn't exist with the Oppo since the Oppo receives numerous firmware updates to address such issues. To our knowledge, Lexicon has yet to offer any firmware updates for their player to address such issues. Thus at this time I must correct our previous statement that both players are identical and now state that the Oppo actually fairs better than the Lexicon when using the analog audio outputs and bass management facilities under the current firmware Lexicon supports their BD-30 player.
If THX tested the analog outputs this would have never been the case hence why its our opinion that the THX certification should also support their certified legacy devices and connection methods.
Update Regarding 0dBFS
2/11/2010
We have recently discovered that not all BD players handle 0dBFS in a similar matter. We've found that when testing at 0dBFS levels, the summed subwoofer output of some players exceeds 0dBFS and thus causes the distortion problem we've previously documented. It is unclear if this is a real world test scenario so going forward we will be testing at -20dBFS based on Dolby Labs recommendation.
For more information, check out our article: 0dBFS & Bass Management of DVD / Blu-ray Players
We live in a world where everyone is building products with other peoples parts. For most companies it's simply not cost effective to produce their own DVD / BD players. Lexicon isn't the only brand doing this and you would be surprised at just how many others are. Lexicon was smart in choosing the Oppo BDP-83 design for their player since it's currently the best Universal BD player on the market in its price class. It's also a proven design that plays every current format being produced on digital recording media. Where they went wrong, however, was when they simply lifted the Oppo BDP-83 player and threw it into their own chassis without making any performance enhancing modifications - despite claims to have done just that. Sadly they paid for THX certification and THX happily took their money to allow Lexicon to slap their badge on the front panel - apparently without actually testing to see if it met the core requirements of which we would suppose any THX Blu-ray player would have to adhere. If THX is doing this with Blu-ray players, it makes you wonder what they are doing with A/V receivers and other THX certified products. Has the THX badge, for select existing clients, simply degraded into a marketable commodity with no real backing or validity?
It is our opinion that Lexicon released this player as a high margin product to offer their custom installers and dealers a complete Lexicon solution to sell to the end user. Given Lexicon's high end heritage for producing some of the most innovative products in the industry, we are a bit surprised by the apparent lack of innovation on their part to at least attempt to improve upon the hardware that they purchased/licensed. What they've done doesn't seem to even begin to justify the exorbitant price markup. The end user (those end-users not getting this product as part of a Lexicon custom install package, that is) must ultimately determine if it's worth an extra $3000 to pay for an Oppo in a Lexicon casing to match the aesthetics and brand appeal for the rest of the Lexicon equipment in their rack.
Closing Thoughts
We fully disclosed our findings to Lexicon prior to publishing this article and they still maintain their player has audio and video enhancements over the stock BDP-83. We find this rather insulting given the insurmountable evidence we presented here that indicates otherwise. We also emailed THX our findings and our response is posted on the prior page of this review. So far, there is not much to change our conclusion. This situation saddens us as it alienates us from two major companies in this industry that we otherwise have great admiration towards. At the same time, it may also give reservations to other manufacturers on the fence about sending us products for review - knowing our reputation for digging deeper and reporting the facts like no other publication either has the backbone or technical expertise to do. In the end the consumer wins by having the tools at their disposal to make educated buying decisions, assuming of course this type of reporting doesn't inhibit our ability to get product review samples from manufacturers.
We commend Lexicon for giving us this opportunity to review the BD-30 BD player and hope to continue reviewing their products regardless of our findings in this particular instance. In the meantime, we suggest that Lexicon asks for a certification refund from THX and instead have us do their testing going forward with new Blu-ray players. Hmm, maybe they can even place our logo on their faceplate. Now that would be cool!
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
High Definition Video Performance | ![]() ![]() ![]() ![]() ![]() |
Standard Definition Video Performance | ![]() ![]() ![]() ![]() ![]() |
High Definition Audio Performance | ![]() ![]() ![]() ![]() ![]() |
Analogue Audio Performance | ![]() ![]() ![]() ![]() |
Bass Management | ![]() ![]() ![]() ![]() ![]() |
Deinterlacing & Scaling | ![]() ![]() ![]() ![]() ![]() |
Ergonomics & Usability | ![]() ![]() ![]() ![]() |
Ease of Setup | ![]() ![]() ![]() ![]() ![]() |
Remote Control | ![]() ![]() ![]() ![]() |
Fit and Finish | ![]() ![]() ![]() ![]() |
Value | ![]() |
See also:
Recent Forum Posts:
Dear Audioholics:
A couple of questions about your reviews and company. Do you get paid advertising on your web site magazine by the companies whose equipment you review, for instance from Oppo and Lexicon?
Do they send you samples gratis for review or do you purchase the equipment using your own funds? If ‘loaned’ do you have to return the equipment?
As a former subscriber of Hi Fidelity, Stereo Review and Consumer Reports your answers will allow me to properly judge your impartiality. After reading your comments about Lexicon, and their apparent outright fraud, you treated them far more civilly than I would have.
Chris
debauchee69, post: 828429
The business of America is BUSINESS and the foundation of American Business is INTEGRITY. Once it is questioned, it is never recovered (e.g. Portfidio Tequila, Beeches ‘Apple Flavoured’ Apple juice', etc.).
Everyone uses everybody's parts and designs and that is a given in the Electronics business, especially the high-end consumer electronics business. Lexicon didn't do that—they took a $500.00 unit and dropped it into a $3,500.00 unit and palmed it off as their own!!!
I don't have a problem taking one company's product and tweeking it to make it better. ModSquad made a ton of money tweeking ordinary MAGNAVOX CD players and the well heeled consumer paid out the nose for said tweeks.
I have a problem with Lexicon taking a $500.00 OppoBD83 andpalming it off as their own. There is no excuse for what Lexicon did—they could have put in point to point 9999.9 silver wire and leads, put in better caps and beefed up the suspension or power supply and still pocket about $2K. Lexicon didn't do that—it slapped on a $65.00 aluminum front place and a darker blue lt and called it a $3,500.00 Lexicon. In my mind, that is called t-h-e-f-t!!!
There is another villian in this (I can't really spank OPPO because they could claim ignorance in the con and I wouldn't be able to say otherwise ALTHOUGH THEY HAD AN OBLIGATION TO INSPECT THE LEXICON DB30 AND ASK WTF?!!) and that villian is Mr. George Lucus (THX Certification).
Lucus is the GATEKEEPER OF THE PROCESS. Had THX did its job with due dilligence in testing, THX would have prevented this con taking place. You can't blame OPPO because no OPPO piece is THX certified. Had LexicIon spent the money to bring the OPPO BD83 into THX spec, it could justify the $3K expense (kinda sorta). I now question the integrity of the THX badging process—since the specs aren't published (propriety info) how do we know ANY THX badge meets THX specs?
Why am I wringing my hands over this? I just came into a sizeable amount of money and I have allocated $50K just on my Home Cinema and another $200K on my ‘Music Conservatry’ (Mr. Plumb, the Candlestick, yada,yada,yada). Go on, ask me if I will be using Lexicon products? Ask me if I will bother with THX certification?!!! This is why America is in decline—profits over integrity!
Maybe you didn't notice, but this thread is over a YEAR old. The story is old and the flames have long since died out and new grass has already grown. Oppo doesn't even make the 83 anymore… So you are wringing your hands for no reason. OR, you are just spamming for no reason.
santeini, post: 703268
Curiosity killed the cat,greed killed ………………….?
“The major focus of the THX Certified Blu-ray Disc Player certification is on video performance.”
Uhh, then why does THX do that cute little short with the robot and the cow-sound-can at the beginning? Seems like audio.
