Speaker Cable Faceoff 3 - The DIY Shootout
by Thomas Goldsworthy April 30, 2005
Contributors:
WBT locking banana connector
This effort is an offshoot of my search for a decent performing large OD cable, which will be used for my DIY speaker cables. When I bought my first really good pair of speakers, the salesman sort of talked me into a set of Monster MCX-1S cables. I had been/ am a zip cord type of guy and did not know any better. Well, after purchasing those particular cables, and speakers, I had a bit of buyers remorse. Not over the $1400 pair of speakers, but the $75 pair of cables. At the time, my wife and I were dismantling the recording studio we had in the basement and selling it off in pieces, and saving some for a home theater. And after a lot in internet searches, I found Audioholics among others, and my education really started.
I have always had a bigger is better philosophy, as well as a devote DIYer. So after reading all I could about speaker cables, I started on my path to building a bigger (and better) mouse trap. I wanted diameter as well as performance. I also had the tools to determine which was better. I have my own LCR meter, a BK Precision Model 885. Granted this is no Wayne Kerr model 6420 with unobtanium leads and a $15000 price tag like Audioholics uses in their Test Equipment Arsenal, but it is suitable for most home grown/military applications and cost less than $1000. Not much less, but less (even with the Kelvin clips). Nor does it generate gigahertz frequencies, it maxes out at 10000 Hz. Which is fine with me, after all I cannot hear anything over 16000 Hz so why test speaker cables at 1 GHz? Video cables are another matter, but not in this paper.
So, let's get to the meat of the order.
Cable Descriptions and Comments
The cables tested include some standard speaker cables, and some readily available power or control cable from various sources. I acquired all cable at my own cost. Costs range from $0.21/foot to $16.00/foot (of course to get this particular cable at this price you have to buy 1000 feet). Anyway, some of the cables were tested in a couple of different ways, and some were tested straight. The table below is a list of the tested cables and their construction.
Manufacturer
Model
AWG
Strand Count
Conductors Per Cable
Conductors Used
Construction
Alpha
85104CY
10
658 x 38
4
2
Twisted Lay
Carol
10/3
10
104 x 30
3
2
Twisted Lay
Carol
12/4
12
65 x 30
4
2
Twisted Lay
CAT 5
V1
12
16 x 24
4
4
Twisted Lay
CAT 5
V2
12
16 x 24
4
4
Flat Braid
CAT 5
V3
10
24 x 24
6
6
Twisted Lay
CAT 5
V4
10
24 x 24
6
6
Flat Braid
CAT 5
V5
10
24 x 24
6
6
Twisted Braid
Generic
10/4
10
104 x 30
4
2
Twisted Lay
Generic
12/4
12
65 x 30
4
2
Twisted Lay
Monster
MCX-1S
NA
NA
2
2
Twisted Lay
Parts Express
Part Number 100-768
14
41 x 30
4
2
Twisted Lay
Sound King
V1
10
413 x 36
2
2
Flat Lay
Sound King
V2
10
413 x 36
2
2
Twisted Lay
Sound King
V3
10
413 x 36
2
2
3 Wire Braid
Sound King
V4
10
413 x 36
2
2
4 Wire Braid
Woods
HD Contractors Cord
12
NA
3
2
Twisted Lay
TABLE 1
TESTED CABLES and CONSTRUCTION
Unless otherwise stated, all cables were finished with WBT Clone, crimp style, locking banana plugs (see Figure 1).
FIGURE 1
WBT Clone (GLS) Locking Banana Plugs use for all cable ends
Alpha 85104CY (10/4 shielded)
I acquired 48 feet at a garage sale for $25. I thought this might be great performing cable because of it's high strand count, shielding, and gauge. Internet research indicates a retail price of $16/foot through Allied Electronics with a 1000 foot minimum. It is a marine grade control cable, very flexible, with a very supple feel to it. If I wanted one cable to really perform in my test it would be this one, mainly because of it's ¾ inch diameter, and 3X bend radius. Only two opposing conductors were measured, leaving the adjacent conductors unused.
Carol Cable
I bought 50 feet each through Parts Express of 10/3 (Part Number 100-58 for $33.15), and 12/4 (Part Number 100-590 for $33.10). Price does not include shipping charges. I made three tests with the Carol 12/4 cable: The first test was made the way all other four conductor cables would be tested, in this method, only two opposing conductors would be measured. For the second and third tests, I made a rig so that I could use the two unused conductors to power a 500 watt photo lamp (second test) and drive a speaker playing pink noise (third test). The reason for the second and third test was based on my post in the A/V Connections Forum and my question to John Escallier (aka jnuetron) about how a signal may be affected by signals in near by wires.
  • T1 - Two conductors out of four used.
  • T2 - Two conductors used for evaluation purposes, and two conductors used to power a 500 watt photo lamp.
  • T3 - Two conductors used for evaluation purposes, and two conductors used to power a speaker playing pink noise at 75 dB C weighted.
Cat 5
I have read about using cat 5 wire as a speaker cable, but I was not that interested in braiding all those tiny wires hundreds of times. Then I though that since the wire pairs run rather loosely inside the outer covering, how would they test out if I made speaker cables using the entire package? Since cat 5 is just a twisted bunch of 24 gauge wires, I figured that 16 wires was roughly equal to 12 gauge litz wire and 24 wires was roughly equal to 10 gauge litz wire, viola, 4 and 6 individual lengths of cat 5 would be all I need. I took about 100 feet of cat 5 wire where I work and cut it into 10 foot lengths, attaching all wires (left inside the sheath) to banana plugs (see Figure 7). The prices shown in table 5 are based on prices from Parts Express and the number of 10 foot lengths used and does not include the connectors. I used these cables in five different variations using 4 or 6 cables. See Figures 2 through 6 for descriptions.
As I started with many 10 foot lengths, the overall length of the speaker cable was somewhat shorter after twisting and braiding. This shorter length of each version is used below when determining Rs, Cp, and Ls on a per foot basis.
FIGURE 2
CAT 5 - V1 Four Twisted Cables
FIGURE 3
CAT 5 - V2, Four Cables Braided
FIGURE 4
CAT 5 - V3, Six Twisted Cables
FIGURE 5
CAT 5 - V4, Six Cables Braided
FIGURE 6
CAT 5 - V5, Six Cables in Three Twisted Pairs Braided
FIGURE 7
Typical Cable Ends Finished for Testing
Generic
I do not know the brand name of these cables, but they are available at Lowes. The 10/4 cost $1.74/ft and the 12/4 costs $1.46 per foot. I purchased these after being very impressed by the supple feel, flexibility, and large diameter. Both cables have some sort of polyester fill between cables, and the 12 gauge cable has a white polyurethane sheathing inside the rubber external sheath. Both cables have the same OD. 20 feet of each was purchased and the entire length was used in testing.
DIY Cable Faceoff - Testing and Methodology
Figure 8
Cables from Lowes. 12/4 is on left & 10/4 is on right. Both have a 0.75" OD
Monster MCX-1S
I bought this cable from Tweeter when I bought my Mirage Speakers. The 10 foot pair of cables is $50, but, unless you want to use the pins, you need to purchase the Monster banana plugs or spades which cost another $12.50 for four (and you need a total of 8 for the pair of cables).
Parts Express
As the name implies, do not know the manufacturer, but thought is may be a nice to include. This is a 14 gauge, 4 conductor cable.
Sound King
I bought a 100 foot spool of 10 AWG speaker wire from Parts Express. I liked the large strand count. Anyway, I cut several 10 foot lengths of this zip wire and tested four variations of this cable. See Figures 9 through 12 for descriptions.
The same comment here as with the CAT 5 cables. As I started with many 10 foot lengths, the overall length of the speaker cable was somewhat shorter after twisting and braiding. This shorter length of each version is used below when determining Rs, Cp, and Ls on a per foot basis.
FIGURE 9
Sound King 10 AWG Zip Wire (V1 in following Tables)
FIGURE 10
Sound King 10 AWG Twisted (V2 in following Tables)
FIGURE 11
Sound King 10 AWG Three Wire Braid (V3 in following Tables)
FIGURE 12
Sound King 10 AWG Four Wire Braid (V4 in following Tables)
Woods
This is a generic 25 foot heavy duty 12/3 extension cord purchased from Home Depot for $16.
Testing
All measurements were made on a BK Precision Model 885 LCR meter using the optional Kelvin Clips. This meter has several functions which are very suitable for my purposes. This meter can measure capacitance, inductance, and AC resistance at 100, 120, 1000, and 10000 Hz. However, since I’m using excel to plot everything in a log format I did not bother with the 120 Hz measurements. Prior to making each measurement, the meter was run through a self calibration test.
Figure 13 - Test Gear
Methodology
As stated above, the LCR measurements were made at 100 Hz, 1kHz, and 10kHz. The measured parameters were then averaged. The averages were used to evaluate the cables against each other and to cables from the two cable face-offs performed by Audioholics.
The evaluation process involved generating a dimensionless number based on linear interpolation.
By setting the worst case average, in each case this is the highest average, to 1, and the best average (the lowest) to 10, and interpolating for those averages between the best and worst to develop the dimensionless factors for all cables.
After all factors were calculated, weight factors were applied. These weight factors were arrived at after numerous email discussions between Gene DellaSala, John Escallier, and myself. For the most part, I just sat back and said uh-uh. Anyway, we arrive at the following weight factors.
Resistance 0.41
Inductance 0.32
Capacitance 0.27
Technical Factor 0.6
Cost 0.4
The way this system works is to apply the weight factor to the dimensionless factors for resistance, inductance, and capacitance and arrive at a Technical Weighted Ranking Number (TWRN). The TWRN then has the technical weight factor applied and is summed with the cost dimensionless factor and the cost weight factor to finally arrive at a Final Weighted Ranking Factor (FWRF). The highest FWRF wins.
This method was also used to compare the results of both cable face-offs, and the total combined results of my analysis and both cable face-offs. Check the tables, the results are surprising.
References: Speaker Cable Face Off 1 and Speaker Cable Face Off 2
DIY Cable Faceoff - Measurements and Value
Resistance (Rs)
The results of the resistance measurements are shown in Table 3, as previously stated, the higher the rank, the better. I’ve only shown Rs for each frequency. Rs is the AC resistance at the measured frequency plus the DC resistance.
Manufacturer
Model
Rs (Ohms/Ft)
RANK
100 Hz
1kHz
10kHz
AVG
Alpha
85104CY
0.00208
0.00213
0.00228
0.00216
9.858
Carol
10/3
0.00204
0.00205
0.00206
0.00205
10.000
Carol
12/4 T1
0.00329
0.00329
0.00341
0.00333
8.322
CAT 5
V1
0.00269
0.00269
0.00269
0.00269
9.161
CAT 5
V2
0.00326
0.00326
0.00344
0.00332
8.336
CAT 5
V3
0.00213
0.00218
0.00224
0.00218
9.824
CAT 5
V4
0.00216
0.00215
0.00231
0.00221
9.797
CAT 5
V5
0.00222
0.00227
0.00227
0.00225
9.736
Generic (Lowes)
10/4
0.00202
0.00210
0.00232
0.00215
9.870
Generic (Lowes)
12/4
0.00325
0.00325
0.00345
0.00332
8.345
Monster
MCX-1S
0.00861
0.00882
0.00937
0.00893
1.000
Parts Express
100-768
0.00521
0.00536
0.00536
0.00531
5.742
Sound King
V1
0.00207
0.00222
0.00222
0.00217
9.850
Sound King
V2
0.00210
0.00224
0.00224
0.00220
9.808
Sound King
V3
0.00210
0.00224
0.00224
0.00220
9.808
Sound King
V4
0.00210
0.00215
0.00217
0.00214
9.884
Woods
HD
0.00333
0.00343
0.00345
0.00340
8.232
Carol
12/4 T2
0.00329
0.00329
0.00341
0.00333
NA
Carol
12/4 T3
0.00329
0.00329
0.00341
0.00333
NA
TABLE 2
CABLE RESISTANCE (Ohms/Ft)
Editorial Note
The 1-10 scale ranks the cable resistance for each cable. The higher the #, the lower the resistance or the better performance the cable will yield in this respect.
Note, that as expected, the photo lamp test (T2) and the pink noise test (T3), did not affect the resistance of the conductors in a 4 conductor cable. Notice also, the high resistance of the Monster cable, this is characteristic of a 16 AWG or smaller wire.
Capacitance (Cp)
Manufacturer
Model
Cp (picofarads/Ft)
RANK
100 Hz
1kHz
10kHz
AVG
Alpha
85104CY
45.241
41.959
38.097
41.7657
1.364
Carol
10/3
37.625
35.063
32.250
34.9792
3.439
Carol
12/4 T1
27.808
25.769
24.654
26.0769
6.161
CAT 5
V1
26.915
26.863
26.056
26.6115
5.997
CAT 5
V2
24.825
23.776
23.310
23.9705
6.805
CAT 5
V3
38.105
42.663
41.105
40.6246
1.713
CAT 5
V4
32.000
32.222
31.333
31.8519
4.395
CAT 5
V5
40.432
44.865
43.568
42.9550
1.000
Generic (Lowes)
10/4
16.000
18.600
17.500
17.3667
8.824
Generic (Lowes)
12/4
15.600
18.450
17.350
17.1333
8.896
Monster
MCX-1S
29.720
35.710
34.890
33.4400
3.909
Parts Express
100-768
22.400
21.020
20.000
21.1400
7.670
Sound King
V1
22.900
20.800
18.730
20.8100
7.771
Sound King
V2
21.128
19.897
18.154
19.7265
8.103
Sound King
V3
12.410
14.626
13.528
13.5214
10.000
Sound King
V4
20.886
19.697
18.314
19.6324
8.131
Woods
HD
33.320
35.000
32.160
33.4933
3.893
Carol
12/4 T2
26.000
26.192
24.962
25.718
NA
Carol
12/4 T3
28.231
25.962
24.769
26.321
NA
TABLE 3
CABLE CAPACITANCE (pF/foot)
Editorial Note
The 1-10 scale ranks the cable capacitance for each cable. The higher the #, the lower the capacitance or the better performance the cable will yield in this respect.
Several thing to notice from these results are the very good performance of the standard off the shelf power cables. While the Woods extension cord does not appear to be exemplary in this respect, it is comparable to the more popularly known Monster cable. The two cables I purchased at Lowes really impress though, as does the Sound King. Bare in mind the Sound King V3 is a three wire braid and the V4 is a 4 wire chain braid. It seems that inexpensive wire rules here. A final note, the photo lamp test (T2) and pink noise test (T3) do not appear to have a minor impact on capacitance, but this is also within the realm of standard meter error.
Inductance (Ls)
Manufacturer
Model
Ls (microHenries/Ft)
RANK
100 Hz
1kHz
10kHz
AVG
Alpha
85104CY
0.217
0.210
0.215
0.214
4.332
Carol
10/3
0.262
0.260
0.253
0.258
2.393
Carol
12/4 T1
0.256
0.254
0.251
0.254
2.592
CAT 5
V1
0.112
0.095
0.104
0.104
9.162
CAT 5
V2
0.115
0.132
0.126
0.124
8.264
CAT 5
V3
0.097
0.096
0.089
0.094
9.587
CAT 5
V4
0.123
0.122
0.116
0.120
8.432
CAT 5
V5
0.088
0.086
0.080
0.085
10.000
Generic (Lowes)
10/4
0.256
0.255
0.251
0.254
2.582
Generic (Lowes)
12/4
0.290
0.282
0.284
0.285
1.208
Monster
MCX-1S
0.195
0.192
0.186
0.191
5.340
Parts Express
100-768
0.218
0.203
0.210
0.210
4.489
Sound King
V1
0.210
0.196
0.203
0.203
4.810
Sound King
V2
0.217
0.215
0.209
0.214
4.327
Sound King
V3
0.258
0.246
0.253
0.252
2.641
Sound King
V4
0.299
0.281
0.289
0.290
1.000
Woods
HD
0.190
0.190
0.183
0.187
5.493
Carol
12/4 T2
0.254
0.253
0.249
0.252
NA
Carol
12/4 T3
0.256
0.247
0.249
0.251
NA
TABLE 4
CABLE INDUCTANCE (μH/Ft)
Editorial Note
The 1-10 scale ranks the cable inductance for each cable. The higher the #, the lower the inductance or the better performance the cable will yield in this respect.
Cable Metric Definitions
Rdc
Commonly referred to DCR which is the series resistance of a cable at zero frequency.
Rac
The resistive portion of the cables series resistance as a function of frequency due to skin effect.
Rs
Total Series Resistance (mohms) measured tip to tip at one end of the cable while the other end is shorted. Note: Rs = Rac + Rdc (minus instrumentation inaccuracies identified below)
Ls
Series Inductance (uH) measured tip to tip at one end of the cable while the other end is shorted.
Cp
Parallel Capacitance (pF) measured tip to tip at one end of the cable while the other end is open circuited.
CAT 5 rules, as expected. Extension cords almost rule as not expected. I wonder why the braided Cat 5 wire performed so much better than the braided Sound King. Let’s not start the argument that Cat 5 is designed for low inductance, especially since the way I made the cables - each of the eight wires inside the sheath acted as one thick wire, the same way as the Sound King cable. It would be nice to hear some knowledgeable opinions or even swags. Finally though, the Monster cable is at least looking mediocre.
Editorial Note
By braiding multiple conductors in close proximity you have taken advantage of mutual inductance by cancellation of self inductance to minimize the overall inductance of the cable. For more detailed information on cable inductance check out our article: Calculating Cable Inductance
Value and Price
Manufacturer
Model
Price/Ft
Rank
Alpha
85104CY
$16.00
1.000
Carol
10/3
$0.66
9.756
Carol
12/4 T1
$0.66
9.756
CAT 5
V1
$0.26
9.985
CAT 5
V2
$0.23
10.000
CAT 5
V3
$0.37
9.923
CAT 5
V4
$0.33
9.943
CAT 5
V5
$0.32
9.948
Generic (Lowes)
10/4
$1.74
9.140
Generic (Lowes)
12/4
$1.46
9.300
Monster
MCX-1S
$3.75
7.992
Parts Express
100-768
$0.34
9.939
Sound King
V1
$0.72
9.722
Sound King
V2
$0.74
9.712
Sound King
V3
$1.11
9.501
Sound King
V4
$1.56
9.244
Woods
HD
$0.64
9.768
TABLE 5
CABLE COST ($/Ft)
Editorial Note
The 1-10 scale ranks the cable cost for each cable. The higher the #, the lower the cost or the better value to the consumer.
The cost per foot shown in Table 5 is based on one cable for one channel. So you will need to double the cost for a pair of speaker cables. The thing to observe here is that the least expensive cables require the most work. Do you have any idea how tiring it is to neatly braid Cat 5? Also notice that all cables except the Monster and Alpha have rankings above 9. That is because the cost of the Alpha wire is so much more than all others. In my field (mechanical engineering) we would almost call this a wash. Yes the cable from Lowes is almost 8 times as expensive as the cheapest Cat 5 variant, but you just have to put connectors of you choice on the Lowes cable - no assembly required. When these cables are compared to other esoteric cables (see Table 7) that $16/foot may not seem so expensive anymore.
DIY Cable Faceoff - Results and Conclusion
Speaker Cable Face Off II previously conducted by Audioholics provided a lot of meaningful information, but no clear idea of which was best. While we are waiting on Gene to finish his cable analysis in Face Off II, I thought I would assign ranking based on his measurements using my linear interpolation method. So, here before you, I give you my opinion on which of these cable is the best. Granted, my opinion is worth is weight in copper (I would have said gold, but the resistance is too high, definitely not silver as it tarnished too easily). All of those ranking numbers contained in tables 2-5 are put to use right now. But first let us discuss weight factors. I have measured three electrical parameters of each of these cables (Resistance, Inductance, Capacitance), and know from first hand experience how much each cable cost me to make. So now we (in the royal sense) decided which factors are the most important based on an educated estimation their impacts may have on system stability and frequency response variation. Under different circumstances, each parameter measured may rise in importance. For very long cable runs all three may be of equal importance, but I think we should just consider normal runs of less then thirty feet (since the longest cable I measured was 26 feet). Based on this, we assigned rankings for each metric with a certain weight function based on perceived importance. Therefore, Resistance is weighted at 41%, Inductance is weighted at 32%, Capacitance is weighted at 27%. These technical factors are weighted at 60% and Cost is weighted at 40%.
RESULTS BASED ON RANK FACTORS
Manufacturer
Model
Weight Factors
Final Weighted Ranking Number
Technical Rank
Final Rank
0.41
0.32
0.27
0.6
0.4
L
Cost
CAT 5
V1
9.161
9.162
5.997
8.30704
9.985
8.97822
1
1
CAT 5
V2
8.336
8.264
6.805
7.89959
10.000
8.73975
3
2
CAT 5
V4
9.797
8.432
4.395
7.90166
9.943
8.71820
2
3
CAT 5
V3
9.824
9.587
1.713
7.55819
9.923
8.50411
7
4
Sound King
V1
9.850
4.810
7.771
7.67587
9.722
8.49432
4
5
CAT 5
V5
9.736
10.000
1.000
7.46176
9.948
8.45626
8
6
Sound King
V2
9.808
4.327
8.103
7.59373
9.712
8.44104
5
7
Sound King
V3
9.808
2.641
10.000
7.56640
9.501
8.34024
6
8
Generic (Lowes)
10/4
9.870
2.582
8.824
7.25542
9.140
8.00925
9
9
Sound King
V4
9.884
1.000
8.131
6.56781
9.244
7.63829
10
10
Woods
HD
8.232
5.493
3.893
6.18399
9.768
7.61759
12
11
Parts Express
100-768
5.742
4.489
7.670
5.86160
9.939
7.49256
14
12
Generic (Lowes)
12/4
8.345
1.208
8.896
6.20993
9.300
7.44596
11
13
Carol
12/4 T1
8.322
2.592
6.161
5.90493
9.756
7.44536
13
14
Carol
10/3
10.000
2.393
3.439
5.79429
9.756
7.37897
16
15
Monster
MCX-1S
1.000
5.340
3.909
3.17423
7.992
5.10134
17
16
Alpha
85104CY
9.858
4.332
1.364
5.79630
1.000
3.87778
15
17
TABLE 6
MUDCATS CABLE FACE OFF FINAL RESULTS
Editorial Note
The 1-10 scale ranks the overall score of the cable regarding technical and final rankings. The lower the #, the better the cable scored with respect to the test criteria, where the technical ranking is based solely on performance and the Final ranking also factors in value.
Surprisingly the Monster Cables performance was outclassed by extension cord. For ease of construction, I preferred the 10/4 cable from Lowes with techflex and banana plugs resulting in a nice looking, large diameter garden hose – err speaker cable. of the technical tidbits (Resistance, Inductance, and Capacitance) and does not include any cost factors.
For your continued enjoyment, I've included a table comparing all the cables I tested and all the cables from Audioholics two previous cable face-offs. If you do not like the results, change the weight factors.
Brand
Model
Source
Weight Factor
Overall Final Weighted Factor
Technical Rank
Final Rank
0.41
0.32
0.27
0.6
0.4
Resistance
Inductance
Capacitance
Technical Weighted Ranking Factor
Cost
CAT 5
V5
Mudcat
9.191
8.220
8.893
8.800
9.995
9.278
1
1
CAT 5
V3
Mudcat
9.246
7.963
8.958
8.758
9.993
9.252
2
2
CAT 5
V1
Mudcat
8.845
7.696
9.347
8.613
9.998
9.167
3
3
CAT 5
V4
Mudcat
9.228
7.237
9.202
8.584
9.995
9.148
4
4
CAT 5
V2
Mudcat
8.347
7.126
9.421
8.246
10.000
8.948
9
5
Cobalt Cable
10 AWG
CFO
9.518
5.705
9.621
8.326
9.654
8.857
7
6
Axiom Audio
Speaker Cable
CFO II
8.174
7.856
9.018
8.300
9.677
8.851
8
7
Sound King
V1
Mudcat
9.257
4.957
9.508
7.949
9.975
8.759
14
8
Sound King
V2
Mudcat
9.238
4.663
9.539
7.855
9.974
8.703
16
9
Tributaries
11 AWG
CFO II
8.940
7.084
8.140
8.130
9.501
8.679
11
10
AVCable
10 AWG
CFO II
9.075
5.209
9.586
7.976
9.707
8.668
13
11
River Cable
Starflex
CFO II
8.759
7.522
9.002
8.429
9.000
8.657
6
12
Sound King
12 AWG
CFO
8.467
4.974
9.694
7.681
9.988
8.604
20
13
Monster Cable
Original
CFO
8.533
5.047
9.550
7.692
9.948
8.594
19
14
Monster Cable
Navajo
CFO
8.068
5.429
9.625
7.644
9.930
8.558
21
15
Woods
HD
Mudcat
8.281
5.380
9.156
7.589
9.979
8.545
23
16
Sound King
V3
Mudcat
9.238
3.597
9.711
7.561
9.955
8.518
24
17
Avic
SC1100
CFO II
7.687
7.839
8.949
8.076
9.130
8.498
12
18
Generic (Lowes)
10/4
Mudcat
9.275
3.551
9.604
7.532
9.923
8.489
25
19
Carol
10/3
Mudcat
9.352
3.431
9.115
7.393
9.978
8.427
26
20
Cardas
Crosslink 1S
CFO II
7.495
7.298
9.225
7.899
9.119
8.387
15
21
Alpha
85104CY
Mudcat
9.262
4.654
8.926
7.697
9.195
8.296
18
22
Sound King
V4
Mudcat
9.281
2.567
9.541
7.203
9.932
8.294
27
23
Carol
12/4 T1
Mudcat
8.339
3.560
9.362
7.086
9.978
8.243
30
24
Parts Express
100-768
Mudcat
6.771
4.755
9.499
6.863
9.994
8.115
33
25
River Cable
Flexygy
CFO II
8.324
5.991
9.082
7.782
8.585
8.103
17
26
Generic (Lowes)
12/4
Mudcat
8.349
2.687
9.611
6.878
9.937
8.102
32
27
Stealth
Premier II
CFO
10.000
5.678
9.842
8.574
7.204
8.026
5
28
Acoustic Research
Speaker Cable
CFO II
8.986
2.447
9.898
7.140
8.991
7.880
29
29
Audience
Maestro
CFO II
7.536
9.042
6.020
7.609
7.896
7.724
22
30
Goertz
MI-2 Veracity
CFO II
8.524
10.000
1.000
6.965
8.710
7.663
31
31
Monster
MCX-1S
Mudcat
3.903
5.288
9.158
5.765
9.820
7.387
34
32
Cardas
SE 9
CFO II
8.738
9.262
2.201
7.141
6.548
6.904
28
33
Empirical Audio
Clarity 7
CFO II
8.284
8.925
7.379
8.245
1.000
5.347
10
34
Stealth
Fine Ribbon
CFO
1.000
1.000
10.000
3.430
7.969
5.246
35
35
TABLE 7 - Comparison of all Cables from the 3 Speaker Cable Face Offs
Editorial Note
Conclusions
So, now that I went and did all this, who does it benefit? You I hope. For those with the most remote DIY capability, the path to a really thick, large diameter cable to impress the ego and neighbors, and performs as well as super high tech, expensive, snake oil laden (or even snake oil free), speaker cables is contained herein.
Hopefully, this will generate a lot of discussion, and I hope Mr. Escallier backs me up instead of insulting my mechanical engineering background. For my part, I think I'll try a blend of Cat 5 and the Sound King next.
P.S. Anybody want to buy some Monster MCX-1S speaker cables? I've got a couple of pairs to get rid of.
FIGURE 14 - Finished Lowes 10/4 Cable, TechFlex Braid, and GLS Locking Banana Plugs
Audioholics would like to thank Thomas Goldsworthy for his Herculean efforts in writing this article, constructing the cables, and testing them. In future cable articles we will be implementing the Linear Interpolation method that Thomas established for ranking cables.
