Audioengine A2 Desktop Speaker Review
- Product Name: Audioengine A2 Portable Speaker System
- Manufacturer: Audioengine
- Performance Rating:
- Value Rating:
- Review Date: June 23, 2010 14:15
- MSRP: $ 199/pr
- Type: 2.0 powered multimedia speaker system
- Power Output: 15W RMS / 30W peak per channel, 60W peak total
- Inputs: stereo mini-jack and RCA jacks
- Voltages: 110-240v, 50/60Hz auto-switching
- Amplifier type: Dual class AB monolithic
- Frequency Response: (+/- 2dB) 65Hz to 22,000Hz
- Input Impedance: 10,000
ohms
- Sensitivity: 88dB
- Signal to noise: >95db
- THD: <0.05% at all power settings
- Tweeter: 20mm
silk dome with neodymium magnets
- Woofer: 2.75” Kevlar
- Driver Configuration: 2-Way
- Enclosure Type: 18mm
MDF, Ported
- Dimensions: 6"
H x 4" W x 5.25" D
- Weight: Left 4 lbs, Right 3 lbs
- Beautiful appearance
- Great frequency response
- Strong bass output
- Nice warranty and return policy
- Portability
- High treble, but not loud enough
- Inconvenient volume knob placement
- No speaker covers
Audioengine A2 First Impression
The
Audioengine team creates powered speakers for use in home and in office to work
with all types of music but are specifically made for digital audio. Audioengine has been in business since 2002
and released their first product, the A5, in the fall of 2005. It is still a young company, so I am not too
ashamed for never having heard about them until I was presented with the A2 speaker
system. The A2 is their attempt to
provide a superior choice and sonic experience for digital music listeners and
video gamers.
The Audioengine A2 speaker system can be found well secured within a box about half the size of a carry-on piece of luggage. The contents are held in place by semi-flexible, shock absorbing foam and will not shift, or move for that matter, during transport. It is almost safe enough for Ace Ventura to deliver it (watch the beginning of that movie). The “Audioengine-ers” went further and encased each speaker in its own protective reusable sock. They did the same for the power supply and the bundle of included cables and speaker wire. If you do not plan on moving the speakers around a whole lot, those protective socks can be good for storing a portable digital music device, jewelry, jacks, marbles, or the loose pieces of a board game. But seriously, at least use the socks to transport the speakers. As pretty as they are, they do not deserve to be scratched. And just like toys should always come with the required batteries, the A2 system is supplied with a 2’ and 6.5’ mini-jack audio cable as well as 6.5’ of 16 AWG pre-stripped speaker wire to get them ready for use right away.
Design Overview
The A2 is a bass reflex (ported) design featuring a 2.75” Kevlar woofer and 0.75” silk dome tweeter. The drivers are recessed perfectly flush into the front baffle which is slot-ported in the front just under the woofer. I must report, for a pair of multimedia speakers, these are the prettiest I have ever seen. The cabinets are made of MDF, rather than plastic. You would not know it unless you were told because the finish is a smooth, glossy type that surrounds the entire box design (except for the back plate) and makes it look like a one-piece enclosure. The small dimensions make it very sturdy as not to vibrate during use. They are also magnetically shielded and are available in white or black and have a slip resistant pad adhered to the bottom of each. It would have bee nice to have a thin, soft cloth grille to complete the speakers’ look. Ideally the grilles would be the same height and width and color as the cabinets.
The Drivers
As mentioned before, the woofer is 2.75” with a Kevlar cone and is
supported by a butyl rubber surround.
Can you really believe that?
Yes. That little driver is called
a woofer. I remember
a time when any speaker less than 4 inches in diameter was a tweeter. Well, based on how these perform, they
honestly deserve the name.
The tweeter is a 0.75” silk
dome with neodymium magnet. Most likely
used for its low profile design to save precious space. While capable of reaching high frequencies,
it seemed that these tended to have a very mild case of laryngitis.
The Rear
The right side speaker is very simple. A metal backplate held in place by six screws. There are two knurled knobs (the + and – connectors) that stick out a half-inch.
The left side speaker has the same as the right
speaker with some more. There is the
keyed (one-way only) connection for the power, RCA left and right (Input A) and
“ mini-jack (Input B), and the volume control knob. The connections for the audio source can both
be used at the same time if needed. The
volume control also acts as the power on/off switch. The switch seems to be of a high
quality. It starts in the 7 o’clock position and turning it
clockwise, it’s range of motion ends in the 5 o’clock position.
It offers a snug, even resistance through the entire range of
motion. The placement of it, however, is
not ideal. If being used as computer
speakers, one would have to reach over or around to adjust it. If you have a small desk up against a wall,
this becomes a nuisance. On the other hand,
keeping it in the back allows the speaker to keep a classic appearance.
Audioengine A2 Setup
I tested the A2s in two scenarios:
- As a mini multimedia center. (See picture with the TV for setup)
- As a replacement for laptop
computer speakers.
In the
first scenario, I placed the speakers as far apart on the table as they could
be, 33 inches. To provide music, I used
a SanDisk Sansa m250 mp3 player. The
Sansa has an equalizer with adjustable frequencies of 50Hz, 200Hz, 1kHz, 3kHz,
and 14kHz
12db. I first used the
male-to-male mini-jack cable that was included and then I used a left and right
male RCA (connected to the left speaker) to male mini-jack provided by
myself. Then I connected them to the
un-powered RCA audio out of my television, a Sony KDL-32L5000, using a
mini-jack to RCA and then RCA to RCA.
And for the last part of this arrangement, I connected a Sony
Playstation 2 (RCA male connections) directly to the left speaker and then
again with an RCA female to male mini-jack.
For the second scenario, I put the speakers 30 inches apart from each other with the laptop equidistant from each speaker. I first connected them to the audio out on the computer (mini-jack) using the male-to-male mini-jack cable and then male RCA to mini-jack.
Why try so many connections? Because the speakers have two types of inputs and I wanted to hear what each piece of equipment would sound like making note of any differences.
Listening Tests
All tests were performed in stereo only.
MP3 Player
All of the music files were recorded using 192kbps bitrate. To test the speakers’ ability, I maxed the volume of the player and used the volume control of the A2’s amp to adjust output strength. The music I listened to were:
Can’t Get
Enough of Your Love, Babe – Barry White Silent
Lucidity – Queensryche
Unchained –
Van Halen Jet City Woman – Queensryche
316 – Van
Halen The Calling
– Yes
Nothing Can
Come Between Us – Sade Rhythm of
Love – Yes
Never as
Good as the First Time – Sade Africa – Toto
Hey 19 –
Steely Dan Head to Toe
– Lisa Lisa and Cult Jam
Josie –
Steely Dan Cover My
Eyes – Marillion
La Isla
Bonita – Madonna I Keep
Forgetting – Michael McDonald
In My House
– Mary Jane Girls Candy
Everybody Wants – 10,000 Maniacs
Come Undone
– Duran Duran You Can Do It
– Ice Cube
Sad Songs –
Elton John
Also used were various songs by AC/DC, Ozzy Osbourne, Fleetwood Mac, Heart, The Outfield, Doobie Brothers, Hall & Oates, Prince, John Cougar Mellencamp, Eric Hansen, John Williams Conducts The Boston Pops, Billy Joel, and some techno.
The music sounded exactly the same no matter which connection type was used. There was a lot of strong bass emanating from the A2s for each song played. The highs were there, however, it was not enough to perfectly complement the amount of low frequency. To remedy this, I kept the 50Hz setting at +6db and the 200Hz setting at +3db while I raised 1kHz and 3kHz to +10db and the 14kHz to +12db. This improved the output a lot. I was able to max the speakers’ volume, too, for most songs played without much distortion.
The songs
that sounded best were anything by Sade, I Keep Forgetting, Can’t Get Enough of
Your Love Babe, anything by Hall & Oates, Come Undone sounded great, and
believe it or not, Head to Toe.
Everything else sounded very well.
Even though these speakers seem to be bass biased, they were not able to
pump out all of the low notes to "You
Can Do It" by Ice Cube at high volume.
After all, the woofers are just 2.75 inches. Still, I was impressed and pleased. If you like pop and hair band music from the
80s and 90s, light jazz, and easy listening, the A2 system will provide a nice
listening experience in a convenient and portable package.
Television Connection
This was pretty simple. It was nothing more than turning on both units and changing channels. Again, no matter what connection was used, it sounded the same. This time, though, I was able to get a better response from the tweeters. The woofers were still loud and I noticed the volume could not be maxed on every channel as some were louder than others. The ability to achieve maximum loudness was highly source dependent upon what was on TV. The sound quality from the Audioengine A2s was much better than using the built-in television speakers. I wasn't hearing that vibration distortion TV speakers make at high volume. The only issue I had was my TV lacked variable audio outputs so I couldn’t use the TV remote to control to adjust volume. This was a problem for me since I wasn't sitting near the TV or the speakers and had to get up each time to adjust volume level.
The Playstation 2
Yes, a Playstation 2. I love video games. I am just not eager to spend top dollar on the newest creations when I know they will be available in the near future at a lower price. Anyways, to complete this test, I used Ultimate Spiderman, Mortal Kombat Armageddon, Star Wars Battlefront, and Guitar Hero 3. This is where the speakers really showed off what they can do. Like before, they were still heavy on the bass. But, that can be attributable to the nature of video games and even movies. Punches, kicks, gunshots, and explosions tend to have a lot more bass impact in the virtual world than in real life. Like the TV connection, the treble was better than that of the portable music player. This was most noticeable in Battlefront and GH3. In GH3, it sounded like a “quiet” concert was in the room. In Battlefront, the Hoth battle sounded great! The A2s were able to reproduce the sound of the AT-AT chin mounted cannons perfectly (Pa-pear! Pa-pear!) I love that sound.
One thing I did notice right away was this time I had to use the volume
sparingly. This was a direct connection
to the game console, which does not have its own sound amplification ability. With the mp3 player I could move the volume
to maximum. This was not the case this
time, as I did not dare move it past the 2
o’clock position. The
Playstation 2 obviously had a much higher driver level than my mp3 player
allowing the A2s to hit maximum output at a much lower volume setting.
Computer Connection
This was also an easy test. Like the previous tests, there was no difference in sound with either connection. I must say it was nice to hear much better fidelity than what the built-in computer speakers can produce. I listened to the same music as I did in the first test and I played two games. They were 007: Nightfire and Diablo II. Because the computer is a powered source, it gave results similar to the mp3 player and of course, the games were full of bass as was expected. The great aspect of the A2s in this application is without sacrificing much desk space you can hear a much wider range of sound than you can with the usual computer speakers.
Audioengine A2 Recommendations
The A2 speaker system is meant to be a portable multimedia system. And, I feel comfortable enough to agree with that. Even though they sound very good for such a compact design, I would recommend they be used with software or a device that allows the user to adjust frequencies to increase the treble and decrease the bass if desired. It would be nice if Audioengine could at least increase the power to the tweeters.
Audioengine has hit a solid triple with the A2s. The next version of these will most likely be the home run for this category of speaker. I am happy with the product especially when I use them with my Playstation 2. The 3-year warranty is automatic, and transferable, which means there is no need to register. Just remember to keep the receipt and packaging. You are even given a risk-free 30-day audition period.
Small dimensions, a pretty finish, power to spare, and two accommodating inputs, you can be sure Audioengine’s A2 speaker system will augment your CD player, DVD player, computer, game console, portable music player, or any other product with a mini-jack or RCA output.
— Excellent
— Very Good
— Good
— Fair
— Poor
| Metric | Rating |
| Build Quality | |
| Appearance | |
| Treble Extension | |
| Treble Smoothness | |
| Midrange Accuracy | |
| Bass Extension | |
| Performance | |
| Value |
