Integra Introduces All-New Professional Amplifier Series
- Product Name: 4125DSP 4-Channel 125W DSP Amplifier, 4500DSP 4-Channel 400W DSP Amplifier, 8125DSP 8-Channel 125W DSP Amplifier, 8500DSP 8-Channel 500W DSP Amplifier
- Manufacturer: Integra
- Review Date: November 18, 2025 00:00
- MSRP: $1,900 - 4125DSP, $3,600 - 4500DSP, $ 3,700 - 8125DSP, $6,000 - 8500DSP
- Power Output: 4 x 125W @ 4 ohms/8 ohms, 2 x 250W @ 70/100V
- Dimensions (H x W x D): 1.75" x 8.66" x 12.6"
- Weight: 6.2 lb
- Power Output: 4 x 500W @ 4 ohms, 4 x 250W @ 8 ohms, 2 x 1000W BTL @ 70/100V
- Dimensions (H x W x D): 3.5" x 17.3" x 12.6"
- Weight: 16.1 lb
- Power Output: 8 x 125W @ 4 ohms/8 ohms, 4 x 250W @ 70/100V
- Dimensions (H x W x D): 1.75" x 17.32" x 12.6"
- Weight: 8.4 lb
- Power Output: 8 x 500W @ 4 ohms, 8 x 250W @ 8 ohms, 4 x 1000W BTL @ 70/100V
- Dimensions (H x W x D): 3.5" x 17.3" x 16.3"
- Weight: 25.6 lbs
Integra
has introduced the all-new Professional Amplifier Series, developed in
collaboration with custom integrators and engineered for reliability, high
performance, and long-lasting precision, according to the company. Intended for
both residential and commercial installations, the four models in the Pro
Amplifier Series promise precise amplification and easy-to-use controls. The
imaginatively-named 4125DSP ($1,900), 4500DSP ($3,600), 8125DSP ($3,700),
and 8500DSP ($6,000) offer various channel counts and power output amounts
in 70V or 8-Ohm/4-Ohm configurations to suit the distributed audio needs of pro
integrators and savvy whole-home audio customers. Each unit benefits from an
intuitive online setup GUI, included rack mounts for seamless integration, a
reassuring 5-year warranty, and easy-to-read back panels with black text on a
white background. An optional wall controller completes the offering.
Integra says that these compact, Class D amps provide market-leading power density, delivering up to 4 × 125 W constant-voltage channels in a 1RU half-rack format. Channels can also share power, providing up to 250 W each for maximum installer flexibility. The amps are configured though software called Intuitive Control SW, which is reportedly optimized for both commercial and residential installations. Inputs, zones, outputs, and backup settings can all be adjusted via the web. Or, for both simple setup and day-to-day operation, Integra offers an optional ($370 each) wall-mounted Zone Controller, which runs on an intuitive, web-based platform, according to the company. Available in black or white, it offers a secure 4-pin passcode, real-time syncing, and quick navigation of your smart home audio system. The Professional Amplifiers include built-in software tools for streamlined installation in partnership with Q-SYS, C4, RTI, Crestron, Symetrix, AMX, and URC.
Klipsch Speaker Presets
All of the Professional Amplifier models include built-in Klipsch Speaker Presets for optimal alignment with the loudspeaker manufacturer’s custom installation products. We’re told that these presets seamlessly integrate EQ, limiters, compressors, and more, in order to optimize performance and simplify setup. Integra has also launched an all-new website built for custom integrators to give them faster access to product documentation, both during the design phase and during on-site setup. The company is placing a focus on simplicity from start to finish.
The Pro Amplifier Series is poised to make a lasting impact with performance-minded integrators. This is precisely what we needed to elevate Integra’s Custom Solutions portfolio, and we’re proud to once again deliver an amplifier series unlike anything else in the CEDIA channel.
— Vincent Bonacorsi, COO of Integra
Integra Professional Amplifier Series Models
Integra 4125DSP — $1,900
The compact, half-rack 4125DSP delivers 4 x 125W into 8 or 4 ohms, or 2 x 250W @ 70/100V. This slim unit is just 1RU (1.75 inches) in height, and comes with a desktop mount kit included, in addition to the regular rack mount kit that is packaged with all the Pro Amplifier Series models.
Integra 4500DSP — $3,600
The 4500DSP delivers 4 x 250W into 8 ohms, 4 x 500W into 4 ohms, or 2 x 1000W BTL @ 70/100V. With 8-ohm and 4-ohm loads, 2 x 1000W output is possible in BTL (Bridge-Tied Load) mode. The amp features a front air intake with rear exhaust for “reliable, efficient performance.” Rack unit size is 2RU (3.5 inches) in height.
Integra 8125DSP — $3,700
The 8125DSP delivers 8 x 125W into 8 or 4 ohms, or 4 x 250W @ 70/100V. The amp is 1RU (1.75 inches) in height.
Integra 8500DSP — $6,000
The 8500DSP delivers 8 x 250W into 8 ohms, 8 x 500W into 4 ohms, or 4 x 1000W BTL @ 70/100V. It features a front air intake and rear exhaust. With 8-ohm and 4-ohm loads, 4 x 1000W output is possible with BTL. The 8500DSP is 2RU (3.5 inches) in height.
More information: Integra Professional Amplifier Series
