Fathom f112 Measurements
Test samples were taken using 16 bit resolution with a 48 kHz sampling frequency. Fast Fourier Transformations were performed at 64K allowing for a frequency resolution of .73 Hz, which is more refined than even 1/24th octave resolution at the lowest octave; the A0 key on the piano has a fundamental frequency of 27.5 Hz.
Figure 1: Impulse response.
Figure 1 is the subwoofer’s impulse response. The basic shape of the curve is typical of low frequency driver; here we see a fairly smooth curve that decays within a few cycles indicating good damping characteristics.
Figure 2: Frequency response.
Figure 2 shows the nearfield frequency response for a sound pressure level of 80 dB when measured at 1 meter. Significant roll off starts to occur around 21 to 22 Hz based on this measurement, which is within reasonable measurement tolerance of the published specifications.
Figure 3: Power compression curves.
Figure 3 shows frequency response at various SPL levels at 1 meter. Measurements were taken nearfield with peak sound pressures of 90, 100, 105, and 109 dB when measured at 1 meter from the sub. Analysis of these curves must include some understanding of measurement and instrumentation limitations. Due to environmental conditions prevailing in a Chicago winter, ground plane measurements were precluded as a possibility and due to the high output capabilities of this sub, nearfield measurement of max SPL caused clipping of the microphone preamp as volume is increased.
Tests I performed indicate that the sub can get between 105 and 109 dB at 1 meter before compression using a wide band frequency input such as an MLS signal. Consideration of measurement accuracy at high SPL must be tempered with understanding that MLS testing is sensitive to any nonlinearity in the measurement, including from test gear. The microphone preamp indicated clipping at 109 dB under the maximum gain adjustment I could make, so it is very likely that the f112 can actually get higher than indicated by these measurements.
Figure 4: Maximum in room SPL at 2 meters by frequency.
Figure 4 was provided by JL Audio with a reported maximum rms SPL output of over 117 dB for a single frequency, a 62 Hz sine wave, and 112 dB averaged over a range between 25 and 62 Hz with THD between 5.2 to 9.9% for various frequencies, in room at 2 meters.
For real world input signals, such as music, the frequency content will be somewhere between these two limits and correspondingly, the SPL output will also be between these two bounds. Either way, SPL that exceeds 109 dB is a substantial amount of output.
Recent Forum Posts:
The correct location for inf-rooms_3: http://www.infinitysystems.com/home/technology/whitepapers/inf-rooms_3.pdf
billy p, post: 260136The local Toronto retailer would be Kromer and I just auditioned the f113 yesterday for a possible purchase at the end of the month. To me the f113 is not a WOW sub (spl) it is more of a “I didn't know those sounds/effects were there!” It is one of those rear audio components that reveals “stuff” that you could not feel before, because with this sub you do not need tactile transducers.
driving home on Friday a commercial from a local Toronto retailer made mention of the the new JL's having arrived. They went as far, as to call them the subwoofer of the Gods. Auditions will be for serious audiophiles only and by appointment only.
Then, again I'm not surprised because I would line up to have a listen .
Ps: I am serious, just don't have that kind of money.
Billy p
Go listen/feel for yourselves.
Then, again I'm not suprised because I would line up to have a listen .
Billy p
gene, post: 258726
David's review and forum response has inspired me to request a review sample of their Gotham sub. Problem is I loath carrying a 300lbs sub up two flights of steps to my theater room, and knowing me, I'd want at least two of them
That's what JL's own top end demo room uses. Bryston electronics, PMC speakers, and two Gothams on the front soundstage.
billy p, post: 258756
I fully concur with post 14 & 18. Well said, no.5
Oh, stop… you'll make me all embarrased.
Thanks though.
