Epson PowerLite Pro Cinema 810 HQV Projector Review
Brightness:
1600 ANSI lumens (vivid
mode) Projection
Lens: F/2.0 – 3.17,
manual focus & zoom Warranty: 2 years parts & labor + 90 days lamp Dimensions: 16” x 4.9” x 12.2” in (406 x 124 x 310 mm)Weight: 11.9 lbs (5.4 kg) |
Video
Processing: Silicon
Optix TX3 Realta HQV 10-bit external processor, True 1080i to 1080p
deinterlacing, SD/HD multi-directional diagonal filter, Dynamic noise
reduction, 16- to 1024-tap adaptive scaling, Audio delay, Full geometry control Video Outputs: HDMI-HDCP, DVI-D and Analogue PC/RGB (HD15) Audio Inputs: S/PDIF & toslinkAudio Outputs: S/PDIF & toslink Control: RS-232, USB 2.0, Ethernet, IR remote Scanning Formats: 480i/576i/1080i and 480p/576p/720p/1080p/24/60 (PAL and some future formats supported) Remote: IR Power Supply: 100-240 volts, 47-63Hz Power Consumption: 300 watts (maximum) Operating Temperature: 10 – 35 degrees C (storage: -20 to 60 degrees C); up to 80% humidity (no condensation) Dimensions: 17.0” x 1.75” x 9.7” in (432 x 44 x 246 mm) Weight: 7 lbs (3.2 kg) |
- No screen door effect at practical viewing distances
- Excellent contrast & color saturation
- A plethora of calibration options
- Consumer adjustment of RGB gain, cut and gamma
- Backlit remote
- 1080p/24/60 support (not native)
- Premium price added for HQV processing
- HQV TX3 lacks multiple HDMI inputs/switching
- Requires some calibration out of the box
- Non-standard power cable
- Pricey for 720p, especially if you have good source components
Introduction
Hi y'all:
New to this site, so I hope someone can help me. I just had installed the Epson Powerlite Homecinema 1080p. I already had a curved, 4:3 ,100" diagonal screen that was installed some years ago. The installer told me that this projector would work best with a flat screen rather than a curved one. Is this true? Are there anysettings that would adjust for the fact that the screen is curved?
Also, how can I change the aspect ratio to 4:3. Is this done through the settings menu?
Does this projector have a keystone correction?
Thanks
Nitin
First, does using the HQV processor yield a 1080P pix on the 810 projector even though the projector isn't rated at 1080P?
Second, you gave the 810 HQV a score of 125 and an excellent rating, but the 1080P got a score of 85 and failed most all of the film detail tests. Does this mean that, although the 810 HQV can't display 1080P it delivers a far superior picture compared to the 1080P?
Conversely, although the 1080P can display 1080P natively, it's picture quality is far worse than the 810 HQV combo?
I'm new at this so please excuse how dumb it may sound!
Thanks
in the section about performance: Clint says “Shrek 2 looked amazing on the Pro Cinema 1080. Blacks were deep and had plenty of depth. Skin and clothing detail was exceptional, being 3D rendered with an absence of any noise or film deterioration.”
I figure he meant the 810 but i guess i want to be sure!
