Google Nexus Q Media Streaming Player Preview
  • Product Name: Nexus Q Media Streaming Player
  • Manufacturer: Google
  • Review Date: July 03, 2012 09:45
  • MSRP: $299.99
SIZE
  • Diameter: 4.6 inches (116mm)
WEIGHT
  • 2 pounds (923 grams)
FINISH
  • Die-cast, precision machined zinc bottom housing
  • Injection-molded, interactive balanced top dome with precision bearing and satin touch coating
HARDWARE CONTROLS
  • Rotating top dome volume control
  • Capacitive touch sensor for mute
LIGHTING
  • 32 RGB perimeter LEDs
  • 1 RGB LED for mute indicator
CPU
  • OMAP4460 (dual ARM Cortex-A9 CPUs and SGX540 GPU)
MEMORY
  • 1GB LPDDR RAM
  • 16GB NAND flash memory
OS
  • Android 4.0 (Ice Cream Sandwich)
SUPPORTING APPLICATIONS
  • Google Play Music
  • Google Play Movies and TV
  • YouTube
CONNECTORS AND PORTS
  • Micro HDMI (Type D)
  • TOSLink Optical audio (S/PDIF)
  • 10/100BASE-T Ethernet (RJ45)
  • Micro AB USB (for service and support)
  • Banana jack speaker outputs
WIRELESS
  • Wi-Fi 802.11a/b/g/n
  • Bluetooth
AMPLIFIER
  • 25W class D (12.5 watt per channel)
  • POWER
  • Integrated 35W switching power supply
  • World-ready 50/60Hz 85-265V AC input
  • Automatic shutdown for audio amp supply when not in use
It's been (semi)widely known that Google was getting into the media streaming box business. This week they leaked a page on their Google Play website for the Google Nexus Q streaming media device. The Google Nexus Q is a $299 is a 'social streaming media player' that streams movies and music directly from the cloud to your living room. It runs Android 4.0 (Ice Cream Sandwich) and comes with 1GB of RAM and 16GB of local storage. It's a lot bigger than it looks in the photos (4.6" in diameter) but is still relatively small. With the Google Play and YouTube apps on your Android phone or tablet, you can use the Nexus Q to send high definition content to your television and home theater speakers. Since everything is cloud-based, the Nexus Q promises no downloads waits or syncing - everything is instant.
Since Google's Nexus Q uses the Google Play Music app, you can grab your Android phone and purchase and/or play video and music instantly and even upload up to 20,000 of your own songs for free. And, a nice tip of the hat to Mac and iTunes users, the Music Manager also uploads your iTunes or Windows Media Player library to Google Play so that your collection is available anywhere, anytime.
Nexus Q rear
Thousands of movies and TV shows are available instantly from Google Play on your Nexus Q. You can just browse or search on your phone or tablet and stream whatever you want to watch to your HDTV. The Nexus Q uses either a wired (recommended) or wireless b/g/n Internet connection to connect it to the cloud and it supports Bluetooth. But what's more amazing is that even "guest" users on your network can stream music in your home, provided they have an Android phone or tablet and a connection to your Wi-Fi network. Of course, you can always shut them down and turn off guest mode to override the system.
Nexus Q tablet
The Nexus Q is also flexible in how it outputs audio. For one, Google claims it has an "audiophile-grade" 25-watt amplifier built-in so you can hook your speakers right up to it. But if you want to tie it into an existing system or AV receiver, you can use either optical TOSlink or HDMI as well. Once the system is playing back content, you can raise and lower the volume from your Android phone or tablet... or you can physically  turn the top half of the Nexus Q. To mute the system, you just touch the capacitance-sensitive top LED.
Nexus Q player switcher
Of course, the Nexus Q also has some "bling" to it. 32 LEDs ring the circumference of the player, and they shift and change color in time to the music... kind of like those obnoxious car stereos we love to hate on. Presumably this is all defeatable, and you can choose your favorite effect in the event you want to make the Nexus Q a focal point of your home entertainment system.
You can also use and connect multiple Nexus Qs to zone your house with sound. You just select the devices you want to play music on from within the Google Play apps or YouTube. Google shows the Nexus Q as shipping in 2-3 weeks.
