Building an HTPC - Parts List
So Why Build One?
Building an HTPC is going to be FAR more cost effective than purchasing a pre-configured system outright. However, if you are uncertain of your PC-building and/or troubleshooting skills, HTPCs can be bought for around $2000 (prices vary up or down).
If
you are adventurous or technically-inclined, building
your own HTPC can be an exciting and rewarding project.
You are certain to have your share of headaches along
the way, but the results are worth it, and the savings
are substantial . Utilizing this guide as a
reference, you can build an HTPC for anywhere between
$500 - $1000 depending upon the parts you choose and
the goals you have in mind. And yes, you can always
spend more!
Starting at the Top: The Parts List
Starting from the top you need to have the necessary parts to make an HTPC. As this is an intensive process, I've started with a unit that will primarily be used to get high-resolution video signal to my LCD projector and store my music and game files.
What kind of computer does it take to run an HTPC? Depends on what you want to accomplish. In this design, we are using an Athlon 900MHz processor on an old ASUS A7V motherboard. This processor/motherboard combination was great in its day, but is now considered relatively slow by today's standards. The surprising fact is, this type of motherboard/processor combination is more than enough to build a basic HTPC, provided you aren't attempting to decode the new HD formats supported by Windows Media Player 9. Let's take a look at the actual components utilized in the construction of this particular HTPC as well as comparable currently shipping parts:
Part (actual) |
Part (present-day) |
Price |
Where to Buy |
DVD-ROM Drive (Lite-on) |
$34 |
Motherboard (ASUS A7V) |
Motherboard (ASUS A7V8X-X) |
$67 |
AMD Athlon 900 MHz |
AMD AthlonXP 2000+ |
$65 |
256MB PC133 SDRAM |
256MB PC3200 DDR RAM (CRUCIAL OEM) |
$54 |
40GB HD (WESTERN DIGITAL) |
80GB 7200RPM HD (MAXTOR, WD) |
$49 |
10/100 NIC Card |
On-board LAN |
$0 |
SoundBlaster Live! 5.1 OEM |
$33 |
nVidia Geforce4 MX |
Geforce4 MX440 (CHAINTECH) |
$47 |
PSI Vision II HTPC Case |
PSI Vision II HTPC Case* |
$329 |
Matrix Orbital VFD |
$89 |
350W Power Supply |
350W Power Supply |
$32 |
BTC 5113RF Wireless Keyboard/mouse |
$20 |
Chassis cooling fans (2) |
$10 |
Total Cost for HTPC |
$829 |
Total Cost for HTPC without Case/VFD |
$411 |
*If you absolutely cannot afford a true HTPC case, then you may substitute a Cooler Master ATC-610-GX1 for around $137, or even purchase a regular ATX case with power supply for under $60.
