Does this subwoofer room correction result look normal?
2
2Tones
I have 2 Monolith m15's in the corners of my room and completed audyssey xt32 through the application. Curious if these subwoofer results look ok or if I am going to need to move them around. I have them crossed over at 120hz but I see what looks like a big null at 200hz. Is that normal?
Thanks!
Denon x3800h with 2 Monolith m15s, 3 CMT340 SE2's, and 6 polk audio bookshelf surrounds for 5.2.4 Auro3d.
These aren't really results, just a crude view of the measurement in green and what it proposes to do about it in red. It seems to propose pretty flat response for your subs. The null around 200hz may not be critical but more about your room and speakers than the sub particularly. Finding best placement before running Audyssey is always a good way to go about it, and better yet get a measurement mic and use something like REW to see what's really going on.
