Are generic PC hard drive docks OK?
It's time to consolidate the data from the computers I have used over the years, to make sure all of the essential files are easier to access, so I'm looking for a dock that can hold more than two drives. Any recommendations, or just find something and buy it? Some of the computers were built for the HTC cell phone mall kiosks by DFI Technologies in 2015 and they were built to work reliably, not actually for consumer use. WD 2500 drives. I also have a couple of laptops that need the data moved out.
This is (theoretically) for short term use, just to be able to access the data easily while it's being consolidated.
Thanks
jinjuku
jinjuku
Moderator
Buffalo makes affordable kit if you don't need cutting edge bells and whistles.
