EMPtek ES1010i Conclusion
The EMP ES1010i subwES1010_grille.jpgoofer combines beautiful aesthetics with competent performance. NO this sub won’t win any output or extension wars. If that is your primary goal, then look elsewhere, but also realize you will likely be getting a large pedestrian black box with little to no WAF at this price point (and even possibly higher). The ES1010i does deliver solid bass performance at a modest price without requiring a forklift to move it or without occupying too much precious floor space since it’s taller than it is deep. The ES1010i blends beautifully with the EMP E55ti or E5ti matching towers both in form and function. Because of its extended upper bandwidth, it will also blend seamlessly with even the smallest satellite speaker systems by allowing the end user to increase the crossover point in their A/V receiver's bass management system without sacrificing any output in the critical transition region.
If you are looking for a beautifully finished, nicely constructed affordable subwoofer to compliment the rest of your EMPtek speaker system or a similar high value speaker package, the ES1010i will surely fit the bill. It’s not easy to get a woman to actually like a subwoofer and the fact that my sister-in-law doesn’t find two of them in her home obtrusive is a huge positive in winning the war with your spouse on multiple subs. $499 delivered to your door with a generous 30 day return policy seems about right to me and I surely hope you agree if you’re looking to add some boom with style to your system.
Bassaholic Small
Although we didn't use CEA 2010 test data to certify the room rating for the ES1010i subwoofer we extrapolated using RMS sweep data.  The EMP ES1010i subwoofer achieves the Audioholics Bassoholic “Small” room rating which means that this sub is recommended as maintaining adequate headroom in small sized spaces less than or equal to 1,500 cubic feet and/or users who usually listen at a moderate volume level.
Editorial Note about Room Rating of the ES1010i Subwoofer (11/29/12)
While the ES1010i subwoofer didn't receive our "Medium" room rating  at 25Hz, it  passed it for all other frequencies (30Hz to 80Hz). This is a really excellent budget sub with a lot of usable output. It sounds great and looks great. In fact, the ES1010i, if corner-loaded, would easily measure out enough at 25Hz to achieve our "Medium" room rating.
EMP Tek
382 Marshall Way
Layton, Utah 84041
801-991-1308
www.emptek.com
About EMP Tek
Engineered Music Products (EMP) was founded in 2007 by Industry professionals with over thirty years experience in designing, engineering and manufacturing high performance loudspeakers for companies such as Parasound, McIntosh, JBL, RBH Sound, Destination Audio and Fosgate...
The High Performance Loudspeakers designed by EMP differ greatly from the products that sell in mass retail and big box stores. Manufacturers who market their products through mass retail and big box stores have to spend most of every dollar on marketing and advertising, leaving little of that dollar for product development and build quality.
For thirty years, the founding employees of RBH Sound have focused on engineering and manufacturing loudspeakers that stand above the mass produced, profit focused brands that are offered by mass retail and big box stores. RBH has applied this same philosophy to their new sister company EMP Tek whose products are available exclusively online. In short - these are not your garden variety speakers nor company for that matter.
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
Bass ExtensionStarStarStar
Bass AccuracyStarStarStarStar
Build QualityStarStarStarStar
AppearanceStarStarStarStarStar
Dynamic RangeStarStarStar
PerformanceStarStarStarStar
ValueStarStarStarStar
Recent Forum Posts:
KEW posts on November 29, 2012 22:02
FWIW, compared to 2ea 10“ drivers, a 12” driver has 28% less and a 15" driver has 12.5% more surface area.
gene posts on November 29, 2012 19:53
ES1010i Subwoofer Room Rating
Guys;
i fear our room rating may have given people pause considering this subwoofer.
Please realize I used sweep data instead of CEA data to extrapolate a room rating. This usually tracks fairly well above where the sub is driver limited depending on the extent of the limiter circuit.
That being said I updated the review as follows and hope this adds some clarity:
Editorial Note about Room Rating of the ES1010i Subwoofer:
While the ES1010i subwoofer didn't receive our “Medium” room rating at 25Hz, it passed it for all other frequencies (30Hz to 80Hz). This is a really excellent budget sub with a lot of usable output. It sounds great and looks great. In fact, the ES1010i, if corner-loaded, would easily measure out enough at 25Hz to achieve our “Medium” room rating.
Folks at our GTG event were very impressed with the output of this sub as I've also seen by fellow owners here.
raynist posts on June 30, 2012 16:17
spyboy, post: 892552
After clicking on “More Information” I found the $499.00 price, however, the $599.00 price when you first click on this product is yet another example of sloppy practices and a lack of quality control. :o
Strange. I pointed this out to them a few weeks ago. They made the change and now it says $599 again??
theJman posts on June 30, 2012 01:11
gene, post: 892640
You're free to start your own website and do your own product testing. Until then stop trolling or find another forum to complain on.
spyboy stop trolling and do his own testing? Not likely. He merely travels from forum to forum harassing others who put forth the effort he won't (or can't). It's his MO, everywhere he goes.
gene posts on June 29, 2012 20:52
spyboy, post: 892604
I didn't even bother to note that the resonance between 50-55Hz is a fairly serious anomaly. Just looking one would think that this sub is tuned to 52Hz.
I have to tread lightly because you decided to have someone in your family get an entire EMP Tek set-up. Why you didn't have someone else on your staff test this sub mystifies me. I saw all the reviews you have done for EMP TEK. EMP TEK is one of your regular advertisers, no wonder they wanted you to be the first to test this product. IMHO in the future you should recuse yourself instead of continuing to review EMP TEK products.
All the same I don't think there is any rush by other sites to highlight EMP TEK products. In a shootout at any of the different prices (especially $499) there is some pretty good competition.
In the end it still comes down to cosmetics and WAF, and not performance.
PS How does one find out when you are having a promotion like the one on this product?
PPS Do you have any idea if EMP TEK is going to take any steps to improve its quality control? No matter the price a subwoofer with the wrong driver is really sloppy.
