Sonomax PCS-250 Sculpted eers Conclusion
Are the Sonomax PCS-250 Sculpted eers the best earphones I've tested?
Yes. By far. Of course, that's a short list right now. But even when
comparing them with my full-sized Denon AH-D1000 and Audio-Technica
ATH-M50 headphones, the Sonomax come out on top. They may not have the
flattest frequency response, but they have a very full and rich sound
and is a joy to experience. The molded earpieces means that you've got a
set of earphones that are tailored just for you and, paired with the
earhooks, will take an act of extreme violence to get them off your
head. While the finickiness of the fit means you may not get the best
performance unless you are sitting still, the fact is that these are
headphone that you can take to the gym and, after, do some critical
listening. If you are looking for high-end audio even when working out,
check out the Sonomax PCS-250 Scultped eers. You won't be disappointed.
To hear more about the Sonomax PCS-250 Sculted eers Earphones, head over to the AV Rant Podcast for more.
Sonomax PCS-250 Sculpted eers Earphones
MSPR: $299.99
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Appearance | ![]() ![]() ![]() ![]() |
Treble Extension | ![]() ![]() ![]() ![]() |
Treble Smoothness | ![]() ![]() ![]() ![]() ![]() |
Midrange Accuracy | ![]() ![]() ![]() ![]() |
Bass Extension | ![]() ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() ![]() |
Imaging | ![]() ![]() ![]() |
Fit and Finish | ![]() ![]() ![]() ![]() |
Value | ![]() ![]() ![]() ![]() |
