You are here: Home Tips & Tricks Get Good Bass Bass Management: The Right Stuff Bass Management: TRS - Recommendations
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Gene DellaSala last modified August 25, 2004
In my opinion, I feel that one of the best speaker configuration for the typical large living room is as follows:
Main Speakers: *Large
Center Channel Small
Rear Channel: Small
Subwoofer: Yes
* assuming bass capable speakers are utilized.
The reason why I champion this type of speaker implementation is that in most cases, due to Wife Acceptance Factor (WAF) or other cosmetic reasons, you are not going to be able to implement large bass capable speakers for the rear channels. Even if you were able, it would be difficult to distance yourself from the rear speakers, given the proximity of the rear wall to your couch, if the speakers were at ear level from the listening position, without being able to localize them. The same applies for the center channel. Most people don't have the shelf space to implement a large center channel speaker. In addition, even if you were to utilize a large center channel speaker, placing it above the TV will surely reduce the bass capability of the speaker and thus undermine what you were trying to accomplish. That being said, I believe it is best for the Main speakers (assuming large bass capable ones), or the subwoofer (if optioned) to produce the bass from the rear and center channels. In addition, I really feel that in a large room, such as your living room, the ultimate combination for critical two-channel audio is large bass capable speakers with a musical subwoofer. Large speakers tend to blend better with a subwoofer in larger rooms, assuming proper phasing, which can result in a seemliness transition of bass between the speakers and subwoofer.
Choosing the Right Receiver / Processor
When you venture out on the market in search for your new Receiver or Processor, make mental note of how the unit handles bass management. If the unit does not have the bass management features that suite your speakers and/or application, don't buy it. Make the retailer aware of your concerns as they will surely get back to the manufacturer and will hopefully lead to design improvements in future models. Most importantly, make sure you get the right stuff for your hard earned dollars!
Key Definitions
LPF: Low Pass Filter. Blocks high frequency content from speaker.
HPF: High Pass Filter: Blocks low frequency content from speaker.
Large Speaker: Bass capable speaker able to produce full bass frequencies down to about 20 Hz.
Small Speaker: Speaker, usually bookshelf type, incapable of producing bass frequencies below 60 Hz with much authority or freedom from excessive cone excursion or distortion.
Subwoofer: Dedicated speaker, usually self powered, designed to produce bass frequencies only.
