Bass Management Basics – Settings Made Simple
Bass Management (over)Simplified: Setting the Right Crossover, Size and Delay for Your Home Theater Speakers
This guide is designed to address the numerous questions we receive from new home theater owners who purchase a new system component and don’t quite understand the How’s and Why’s of bass management. More advanced home theater folks may wish to peruse our more in-depth guides available on the site that give a more thorough explanation of this complex and often misunderstood topic.
- Bass Management Dilemma
- Bass Management - The Right Stuff
- Marriage Between the Subwoofer & Tower Speakers
- Setting the Subwoofer/LFE Crossover for Best Performance
Before we begin we’d like to define some terms that we’ll be using throughout this article:
- Bass management: Setting speaker size and the crossover point to best match your home theater system.
- Crossover Point (aka. Filter): The point which low frequency information on any speakers set to ‘Small’ will get routed to the subwoofer and the high frequency information to the speakers.
- Large speakers: Loudspeakers that can reproduce flat full range (approx. 20Hz – 20kHz) undistorted frequencies.
- Small speakers: Loudspeakers that cannot accurately reproduce full range (approx. 20Hz – 20kHz) frequencies and which would need a subwoofer to compliment lower frequency response.
Properly configuring bass management, or the way your receiver handles low frequency information, is necessary for obtaining the best possible sound for your home theater system. There are several types of bass management systems that can exist. Here are a few:
- Fixed: These systems merely ask you whether your speakers are Large or Small and do not offer the option to change the frequency of the crossover point. There is a crossover frequency (usually 80 or 90Hz), but is it not changeable by the user.
- Variable Crossover: These systems offer you the ability to set your speakers to Large or Small, but also allow the user to alter the crossover for more optimal subwoofer and loudspeaker integration. This type of crossover system is found on most modern receivers and preprocessors.
- Multiple Variable Crossover: There exist a few companies that offer the ability to set a different crossover frequency for multiple speakers (front, center, and rear, for instance. Products utilizing Cirrus chipsets come to mind.) This system is more complex by nature, though not necessarily better (but often worse if care is not taken for proper setup.)
- LFE - Low Frequency Effect - this is the dedicated 0.1 channel in 5.1/7.1 discrete surround systems. This channel contains low frequency bass info not found on any of the other channels.
What Is So Important About Bass Management?
Let’s say you bought a receiver and a speaker system. Bass management allows you to set them up in the most optimized way. Without it, you may not even hear the entire soundtrack to movies and music – it’s that important. In addition, speakers that are set incorrectly can often sound muddy or distorted because they are simply being sent too much frequency information that they cannot handle or process. Bass management is one of the most important setup procedures you can learn to tweak your system and make what you have sound even better – and for no cost!
In today's modern 5.1/7.1 home theaters, it is necessary to use at least one subwoofer to properly reproduce the LFE channel and to also reproduce the bass from all speakers set to "small". Using a subwoofer can provide deeper and more consistent bass than running your main speakers "large". It also frees up your speakers to produce the frequencies they were designed to, thus allowing you to play them louder with less distortion.
What is a Crossover Frequency, Anyway?
Before you can understand bass management it’s important to comprehend the terminology and the nomenclature behind the things we’ll be discussing. The crossover frequency is the point at which bass management kicks in, sending low frequency information to the subwoofer, and allowing the information above this frequency to continue to play out of the loudspeakers (more on this in our next section.) In effect, you are attempting to set this frequency to the lowest point at which your smallest speakers can play with authority (+/-3dB). If you have small satellite speakers with 4 or 5” woofers this will likely be around 100-120Hz. If you are using bookshelf speakers, this could be from 60-100Hz. For floorstanding speakers utilizing multiple woofers, this could be anywhere from 40Hz-80Hz, though we’ll give you some suggestions later that may have you setting this to 80Hz for all but satellite systems.
If you have a mixed speaker system where all the speakers are not the same (like most of us) here are some tips for setting the crossover:
- Set the crossover to the
lowest frequency the smallest loudspeaker in the system can effectively
reproduce. If you have a drastic difference (for instance, floorstanding mains
and cube speaker surrounds) then you may need to sacrifice some of the surround
information in order to more effectively balance the system.
- Be sure to run setup test
tones and recheck all of the speaker levels (preferably with an SPL meter) when
you make any changes. Changing the Crossover or a speaker Size setting can
greatly affect the levels coming from the loudspeaker.
- If you are completely lost or don’t know the frequency response of your speakers, don’t fret it – use the guidelines above and experiment until you achieve sound that you’re pleased with.
We’re making some generalizations here, so your mileage may vary, but if you understand the general concept you’ll enjoy a much better multi-channel home theater experience. If this frequency is set too high or small, then the next section will not function correctly, rendering your soundtracks a bit muddy and adding potential distortion to your system.
A couple things to note:
- THX suggests a crossover
setting of 80Hz with all speakers set to
“Small” – much research on their part went into developing this recommendation
and we also believe this is a great starting point for most
systems.
- Most home theater-in-a-box
systems with very small 3” – 4” driver-equipped speakers will probably need to
have the crossover set at 100Hz or 120Hz.
- Follow these guidelines as a starting point and experiment.
Large, Small – Am I Ordering Food or What?
In addition to setting the correct crossover frequency, determining whether your speakers are LARGE or SMALL is likely the most critical aspect to getting the best sound reproduction in your system. The majority of home theater novices I’ve met have their speakers set to all LARGE (if this is you please read on.) This great “mystery” is actually quite easy to understand if you know what’s happening behind the scenes. When you set a loudspeaker to LARGE, you are in effect telling the bass management to bypass that speaker and send it the full range of that channel’s information. Let’s slow down and think about this for a minute because I’ve actually met people that argue with me that their bookshelf speakers sound better set to LARGE.
If a bookshelf loudspeaker has an effective frequency response of 50Hz – 20kHz +/-3dB that means that information below 50Hz isn’t well produced by the speaker. In fact, it only serves to provide distortion and compression in the form of signal sent to the driver that it simply cannot reproduce. It’s like giving toffee to a person with no teeth! Let’s picture this in a practical example of an underwater explosion on screen. In this scene there is a large (read: loud) amount of 25-40Hz content and all of it gets sent to the bookshelf speaker. What happens? The speaker struggles with the information and plays back what it can, all the while being somewhat negatively affected by fact that it is also receiving content it simply cannot handle. Where is that 25-40Hz content being heard? Nowhere. It doesn’t get sent to the subwoofer, and it cannot be reproduced by the speaker.
Now, what happens when we set that same speaker to SMALL? Well, assuming we set the crossover frequency to, say, 80Hz, that bookshelf is absolutely loving life since it is now using all of its supplied amplifier power to deliver a relatively easy workload of frequency information. Reduced signal 80Hz is being sent to the speaker making it less stressed and resulting in less overall distortion.
Where Does All That Missing Sound Go?
OK, so we set the bookshelf or satellite speakers to SMALL – what happened to that content? Good question – easy answer. It got routed to the subwoofer where it belongs. There are several reasons why this is a very good thing:
- Subwoofers are meant to
handle low frequency information, so why let your other loudspeakers do
it?
- As most subs are powered
these days, rerouting the power-hungry low frequency information there simply
frees up your speakers to use the receiver or amplifier’s power for the rest of the
soundtrack, resulting in better dynamics, greater headroom and less
distortion.
- Low frequency
information below 120Hz is, for the most
part,
non-directional, meaning that even if the info is “crossing
over” from a surround
channel, you won’t know it. The
effect will still sound like its coming from the surround,
thanks to the principles of
psycho-acoustics.
- Better bass management allows you to avoid phasing issues associated with having multiple sources producing bass frequencies located at different distances between the listener and center channel speaker. In essence you are almost guaranteed better system bass integration with one subwoofer and all speakers set “Small” than using a subwoofer and all full range speakers set “Large”.
OK, I Get It But My Speakers Really Are LARGE!
For some, your main speakers may actually extend down to 30Hz or lower, especially if they include 10” or 12” side-firing low frequency drivers. The temptation will be to set these speakers to LARGE. The setting is there so there must be a place for its use, right? Actually, we recommend setting almost all speakers to SMALL, even if they are physically large floorstanding speakers. Here’s why: Even though those floorstanders have a low extension, they won’t necessarily go down to the lowest range of your subwoofer as linearly and free of compression (unless your main speakers have more piston area and box volume than your sub – but we won’t address that here) The problem with the LARGE setting is: the ultra low frequency information will not be heard if the speaker cannot reproduce it. Well if by some chance you were able to get your main speakers bass extension flat down to 20Hz, then adding the subwoofer on top of that would yield too much (up to 6dB) of bass output at the frequencies both are producing. Hence integration between the loudspeakers and subwoofer will be poor and the bass may be overpowering, sloppy and/or boomy.
As a practical example, Reference System 3 has a pair of RBH Sound 1266-LSEs which extend down to 32Hz. I have them set to SMALL and I set my crossover frequency to 60Hz. Because of this, the subwoofer handles everything up to 60Hz that would otherwise go to my front speakers. The front speakers are now freed up to concentrate on only 60Hz and up. The result is no lost information, less distortion, more headroom and a better overall sound.
That’s It, Go Tweak!
There’s a whole lot more to this topic, however we’ve fielded so many questions related to the basics that it seemed like a good idea to write a Bass Management Primer of sorts to really drive home how important these settings are to a system. Now that you know a little more about it we hope you’ll go to your receiver and re-check your settings to optimize your speakers and system to operate at its optimal potential.
Recent Forum Posts:
As far as having towers with built in subs, I'm not a fan of those since most of the time the best location in the room for the mains is not the best place in the room for the low bass to come from. Having towers that have subs just seems a waste of money since a lot of the time people don't use them for the low bass. I just think of all the money spent that went to the amp/sub drivers in the towers. Bums me out.
If someone doesn't have a sub & uses the subs in the towers then that's fine & I'm sure there are some out there who love having a system without a big ol' sub in the room (specially the wives haha). But for some serious bass, a dedicated sub is needed, placed right & adjusted correctly.
I'm sure those DefTechs get down to 18hz...just not very loud. I'm sure with the subs engaged in them, 2ch music with them set to Large probably sounds great though!! Home Theater may be another story.
timoteo;883363
As far as your subwoofer, have it set somewhere above the crossover you decide on for the speakers. You want an overlap so you don't miss out on frequencies. I'd say set the sub to 100hz-120hz & leave it. If you set it lower than the speakers then you'll have a hole in the sound.
Example: if your speakers are set to 80hz & sub is set to 60hz then theoretically you will have a 20hz gap. So I recommend setting the sub to its highest available crossover level.
Not quite.
The subwoofer setting you are referring to is the low pass filter for the LFE channel. The LFE channel is the ".1" on a DVD, and is reserved for low frequency effects. This channel is only sent to the subwoofer (when one is specified in the AVR set-up menu).
Since the LFE channel is only sent to the subwoofer, the set-up menu in the AVR is asking how high do you want to allow the LFE channel to play before low passing it. This menu option in the AVR is separate and independent from the speaker/subwoofer crossover frequency that you select for each speaker channel.
In practice, there is very little content in the LFE channel above 80 Hz. However, we occasionally see bass in the LFE channel up to 100-110 Hz. More to the point, the encoding spec for DVDs allows content in the LFE channel up to 120 Hz (at which point it is digitally brick-walled).
So in order to capture everything which could theoretically be present in the LFE channel, this AVR menu option (commonly referred to as 'LPF for LFE') should always be set to 120 Hz. This is usually the default setting on the AVR.
FYI: the THX standard is 80hz for a reason. They have done extensive research & found that 80hz is best for the majority of systems. It happens to be the crossover that best fits most speakers I've owned as well. My current Yamaha allows me to set different crossover points for my center/main/surrounds. So I have mine as follows: Mains-60hz, Center-80hz, Surrounds-90hz, Sub-120hz.
