Oppo BDP-80 Universal Blu-ray Player First Look
- Product Name: Oppo BDP-80
- Manufacturer: Oppo Digital
- Review Date: January 25, 2010 09:35
- MSRP: $289
- Specifications
Disc Types* BD-Video, DVD-Video, AVCHD, DVD-Audio, SACD, CD, HDCD, Kodak Picture CD
CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/REBD Profile BD-ROM Version 2 Profile 2 (also compatible with Profile 1 Version 1.0 and 1.1) Internal Storage 1GB (Actual available storage varies due to system usage) Output Analog Audio: 7.1ch (also supports 5.1ch and stereo modes)
Digital Audio: Coaxial, Optical
HDMI Audio: Stereo, up to 7.1ch high-resolution PCM, up to 5.1ch DSD, Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD High Resolution Audio, and DTS-HD Master Audio bitstream output or decoded into LPCM.
Analog Video: Composite, S-Video, Component Video (Y/Pb/Pr, 480i/480p, 720p/1080i available for non-restricted content only)
Digital Video: HDMI with HDCP (NTSC: 480i/480p/720p/1080i/1080p/1080p24, PAL 576i/576p/720p/1080i/1080p/1080p24)Video Characteristics Composite Video Amplitude: 1.0Vp-p (75Ω)
Component Video: Y: 1.0Vp-p (75Ω), Pb/Pr: 0.7Vp-p (75Ω)Audio Characteristics** Frequency: 20Hz - 20kHz (±0.3dB)
Signal-to-Noise Ratio: >115dB (A-weighted)
THD+N: < 0.008% (1kHz at 0dBFS, 20kHz LPF)General Specification Power Supply: ~ 100V - 240V, 50/60Hz AC
Power Consumption: 30W (< 1W Standby)
Dimensions: 430mm x 281mm x 53mm, 16-7/8 x 11 x 2-1/8 inches
Mass: 3.5kg / 7.7 lbs
Executive Overview
What can you do when you're one of the most talked about Blu-ray manufacturers on the market? What can you do when it's been uncovered that your player (or at least the vast majority of it) has been dropped into a different chassis and marked up 700%? Well, if you are Oppo Digital, you release another universal Blu-ray player. While your first thought might be that they would release another "audiophile" player and try to cash in on that high dollar crowd, but you'd be wrong. Instead they release the BDP-80 - a player with most of the same components and performance as the award winning BDP-83 but priced over $200 less.
That's right, while other manufacturers are pricing their universal blu-ray players at multiple of thousands of dollars, Oppo keeps reducing their prices. Before we talk about what is different between the new BDP-80 and the BDP-83, let's talk about what is the same. First, and foremost, they are both universal players. That means that not only do they play Blu-rays and DVDs (like everyone else) but they also play SACDs and DVD-As. While most are moving away from those formats, there are many out their with considerable SACD and DVD-A collections that generally have to keep an extra player around just for those discs. Of course, they play back a multitude of other formats as well including AVCHD, CD, HDCD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, and BD-R/RE.
Both of the players include 7.1 channel analogue outputs for compatibility with legacy receivers and processors. These outputs can be configured for 5.1 or 7.1 output. They both include component upconversion to 1080i, support BD-Live and Profile 2.0 (with a gig of internal memory), and 1080p/24Hz Blu-ray output. On-board decoding of the HD audio formats is integrated and most of the connection types are identical (one each HDMI, component, coaxial, optical, and composite video - also dual USBs, and an Ethernet port).
The differences are fairly substantive but are well chosen in our opinion. The older BDP-83 player definitely was geared for someone that wanted everything. The new BDP-80 player is for the user that has a lot but wants a box with universal capabilities. The main difference is the video processing. While the BDP-83 has an ABT2010 with VRS by Anchor Bay Technology onboard processor which scored a remarkable 110 out of 130 on the HQV test, the BDP-80 has a proprietary processor which will most certainly provide significantly reduced video performance. Will this matter for Blu-ray and SACD/DVD-A playback? Not really (if at all) but it will affect how good DVDs will look on your big screen.
Along the same lines, the BDP-80 does not support 24Hz upconversion of DVDs (a feature that not too many use currently). While the BDP-83 has a dedicated set of stereo analogue outputs for stereo playback, the BDP-80 relies on it's 7.1 outputs (which can be selected for just stereo). In addition, the BDP-80 lacks dedicated IR in/outputs, a RS-232 port (optional on the BDP-83), and a backlit remote. The BDP-80 sports a glow in the dark remote (which means you'll need to either do some button memorization or integrate the remote into a universal remote system).
There are a few that will look at the above lists of differences and feel that one (or more) is a deal breaker. The upside is that the BDP-80 is still a remarkable value at $500. For $289, the BDP-80 is ridiculous. So, who should buy the BDP-80? The major downside (for most) will be the video processing. If you have a device in your chain that handles upconversion well (like a top of the line display, an upconverting receiver, or a standalone video processor), than you should be fine. Alternatively, if you are upgrading from a cheapo Blu-ray or universal player and don't care about video processing or watch on a smallish screen and/or from a great distance, perhaps you'll be OK. For those that want a player that some think is worth $3500, the BDP-83 is for you. For those that want a one box solution but don't care that much about all those bells and whistles, check out the BDP-80. Either way, you are getting a lot of performance and features for not a lot of scratch. At least until an A/V manufacturer with high-end aspirations decides to drop it in a pretty case and charge enough for a used car.
For more information, please visit www.oppodigital.com.
| OPPO Blu-ray Disc Player Comparison | BDP-80 | BDP-83 |
| General Features: | ||
| Blu-ray Disc Playback: | Profile 2.0 (BD-Live) | Profile 2.0 (BD-Live) |
| DVD-Video Playback: | Yes |
Yes |
| DVD-Audio Playback: | Yes |
Yes |
| Super Audio CD (SACD) Playback: | Yes | Yes |
| Additional Media Formats: | CD, HDCD, Kodak Picture CD, AVCHD, MKV, and other audio/video/picture files | CD, HDCD, Kodak Picture CD, AVCHD, MKV, and other audio/video/picture files |
| Video Processing Technology: | ||
| Video Processor: |
"System-on-Chip" |
ABT2010 VRS by Anchor Bay |
| Digital Video Output: |
HDMI |
HDMI |
| HDMI Output Resolutions: | 1080p, 1080p24, 1080i, 720p, 480p/480i (NTSC), 576p/576i (PAL) | 1080p, 1080p24, 1080i, 720p, 480p/480i (NTSC), 576p/576i (PAL) |
| Blu-ray 1080p24 Output: | Yes | Yes |
| DVD 24p Conversion: | No | Yes |
| Source Direct Mode: | Yes | Yes |
| Component Video Output: | up to 1080i | up to 1080i |
| NTSC/PAL Conversion: | Yes | Yes |
| Audio Output: | ||
| Dolby TrueHD Bitstream (HDMI): | Yes | Yes |
| Dolby TrueHD Decoding (HDMI & Analog): | Yes | Yes |
| DTS-HD Master Audio Bitstream (HDMI): | Yes | Yes |
| DTS-HD Master Audio Decoding (HDMI & Analog): | Yes | Yes |
| 7.1-channel Analog Output: | Yes | Yes |
| Stereo Analog Output: | Shared with 7.1ch | Dedicated Stereo Output |
| SACD output over HDMI: | DSD/PCM | DSD/PCM |
| SACD output over Analog: | PCM | DSD/PCM |
| Other Features: | ||
| Front Panel Appearance: | Plastic with black brushed metal appearance | Heavy gauge black brushed aluminum |
| Chassis Appearance: | Black metal | Black metal |
| Dual USB Ports: | Yes | Yes |
| IR In/Out Ports: | No | Yes |
| RS-232 Remote Control: | No |
Optional |
| Remote Control: | Glow-in-the-dark | Back-lit |
| OPPO Recommendations: | ||
| For home theaters with large screens: | (Not Recommended) | Yes |
| For small or medium display screens: | Yes | Yes |
| For use with an external video processor: | Yes | Yes |
| For use as a digital audio/video transport: | Yes | Yes |
Recent Forum Posts:
PENG;753599
I know I am self serving in saying this as I have a Denon 3910 already but I want them to come up with a BD only player that can compete with Sony and Panasonic in price. I don't even care if they exclude the ABT VRS if that allows them to bring the price down further.
I don't get the impression that they are going to tackle the $100 market again. They turned everything upside down with their early players, but since they switched to BD, they haven't been focusing on the less expensive segment.
j_garcia;753590
It was officially discontinued.
http://www.blu-ray.com/news/?id=5181 [blu-ray.com]
supervij;753172
FYI, the 80 is no longer on Oppo's website.
cheers,
supervij
Confirming the scoop this site gave you just days ago about the end of life for the Oppo BDP-80 Blu-ray player (see Blu-ray.com, September 19), Oppo Digital replied to our query for confirmation with the following: "The BDP-80 has been discontinued and we do not have any immediate plans to design or sell a replacement product." The CE maker clarified that it is working on a new Blu-ray platform, but it will probably not be released until early 2011, or "if we are lucky," by end-of-year 2010.
Oppo explained to Blu-ray.com that they "will not be making any product announcements at CEDIA," the reason being that "our general business motto is to only announce a product when it is available for immediate purchase."
The discontinuation has also been announced through Oppo's Facebook page. No reasons were given for this decision. However, when asked there if a new, cheaper BDP-80 was coming, the reply was: "Definitely some exciting things coming down the pipe, stay tuned."
cheers,
supervij
