You are here: Home Pro Reviews DVD/Blu-ray Players DVD Players Denon DVD-3930CI DVD Player Comparison of Products & Build Quality
by Clint DeBoer last modified July 30, 2009
Let's compare some of the DVD-3930CI features with that of its predecessor, the DVD-3910:
DVD-3910
DVD-3930CI
  • HDMI 1.0
  • DVI & HDMI outputs
  • IEEE 1394 connections (2)
  • 5.1 audio output with redundant 2-channel circuitry (same functionality)
  • Single RCA component video output
  • Two s-video outputs
  • Two composite video outputs
  • Denon Link 2nd Edition (free downloadable upgrade to 3rd)
  • Faroudja FLI-2310 video processing
  • Upconversion to 720p/1080i
  • No 480i via HDMI
  • Analogue bass management
  • HDMI 1.1 with native multi-channel DVD-Audio support
  • HDMI digital video output
  • NO IEEE 1394 support
  • 5.1 audio output with separate 2-channel audio output circuitry
  • Dual component video outputs (RCA/BNC)
  • Single s-video output
  • Single composite video output
  • Denon Link 3rd Edition
  • Silicon Optix REALTA video processing
  • Upconversion to 720p/1080i/1080p
  • 480i via HDMI possible
  • Digital horizontal and vertical keystoning
  • Discrete bass management for analogue and HDMI audio outputs
DVD-3910
DVD-3930CI
The rear panel of the DVD-3910 shows a DVI-D output in addition to the HDMI output. There are also IEEE 1394 connections and a single set of component video outputs.
Enter the DVD-3930CI with dual component outputs (including BNC) a single HDMI 1.1 output and much higher quality audio outputs. DenonLink is now up to 3rd Edition (no firmware upgrade needed)
The DVD-3910 seemed to be very well built with excellent components
The DVD-3930CI (shown with its secondary internal cover removed) is more akin to a tank, with discrete power supply components and an upgraded video processing board that houses the new REALTA chip.
The interface seems to be about the same on both units 舰
But the DVD-3930CI has a slightly more refined look that takes away some of the "my middle school art student designed this interface" feel that plagued Denon until now. You also have more direct access over each function with global, tab-based navigatio
Unpacking & Build Quality
We pulled the DVD-3930CI out of the packaging it came in and balked at the strain it took to haul the unit onto the floor. Wow, a 25 pound DVD player that doesn't have a 1/2" thick aluminum faceplate to "fake" its bulk! We haven't seen this kind of mass since - well, the DVD-5910 came out. The build quality on the DVD-3930CI is nothing short of stellar, which is why I have such a hard time believing this isn't the flagship Denon DVD product. With discrete power supplies for audio and video, as well as a video processing board that takes up more room than the interior components of some AV processors we've seen, it's hard to see how it can be improved upon (at least physically).
We opened up the Denon DVD player (don't try this at home, kids) and found - another cover. The metal grounding and vibration "shield" found inside the normal cover made us very curious as to what this little gem was hiding 舰 Inside we found a little tiny man and a white gerbil running on a wheel - just kidding. The unit, as pictured above, is chock full of component-riddled circuit boards with high quality capacitors, chips and resistors. A very large heat sink covers the REALTA chip and makes it nearly impossible to get a better look at the video processing board without doing some major surgery to the unit. Suffice it to say, I was impressed and continued on with the review in humble silence (or was that a moment of silence for all the lost DVD-5910CI consumer sales this unit will cause?) Hey, don't get me wrong, DVDO scaling, simultaneous progressive component-HDMI outputs, and improved DACs on the 5910CI are cool and for the discriminating audio- and videophile "money is no object" type customer.
