You are here: Home Pro Reviews DVD/Blu-ray Players DVD Players Denon DVD-3910 DVD Player Review DVD-3910 Resolution and Benchmark Testing
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified February 12, 2007
Resolution Test
Using the Avia test DVD, I checked the resolution capabilities of the player. The 6.75MHz pattern in the test is clearly visible and well defined as shown in the photo lower right corner. Be sure to use the Widescreen enhanced version on the Avia test disc on 16:9 HDTVs. The 4:3 version will show the same results and is a valid test, but the aspect ratio will be incorrect on a widescreen TV unless you set it to 4:3 mode. As a fun note, using the DVD-3910's DVI output I ran a test pattern that determined the unit only crops 1 pixel from the bottom of the screen and a combined total of 3 pixels from the sides. Average pixel cropping for NTSC compliant DVD players is somewhere between 6-12 pixels, so the Denon is doing an incredibly accurate job at showing the full composition of the encoded signal. This is often hidden by your display's overscan, but for those using digital front projection or displays with less overscan, this can mean a bit more picture information for you to enjoy.
After the resolution check, I proceed to the black level test using Video Essentials' pluge test pattern. The ability to display correct black level is an important part of a DVD player's performance. Correct black level settings will preserve shadow detail and improve the depth and contrast of an image. Viewing the pluge pattern, I noted that when the DVD-3910 is in the factory default setting, and HDMI/DVI Black Level Enhancer set to ON, and the picture settings set to Standard, the black level was almost dead on. The blacker than black pluge was clearly visible. This is the setting we recommend for most installations.
Editorial Note about Silicon Optix HQV Benchmark Test DVD
Silicon Optix developed the HQV Benchmark DVD in an effort to set a new standard for video processing quality and to attempt to make the testing more objective rather than subjective. The main goal was to help reviewers and consumers measure the performance of the video processing logic inside DVD players, scalers, and displays. The HQV Benchmark helps reviewers generate a ratings score that may be used by consumers to compare products and get a better understanding of the differences they will have in their viewing experience with various competitive products.
The source material for the HQV Benchmark was accumulated by Silicon Optix' Teranex division over the past five years. Teranex has been working closely with Hollywood post production facilities and major broadcasters to collect a variety of real-world samples of video processing challenges. Those sequences are included on the HQV Benchmark DVD. Where possible, the tests include both synthetic tests to aggravate a particular problem along with real-world material that shows the same problem. For the past year, numerous reviewers and industry experts have been evaluating this content and providing feedback to Silicon Optix on both the content and the ratings systems. The current HQV Benchmark DVD is a direct result of this industry collaboration.
Perfect Score is 130
Denon DVD-3910 Benchmark total score: 75130 (This player had some surprising issues but is still a decent performer )
Test
M ax
Points
AUTO 1
Results
AUTO 1
PassFail
AUTO 2
Results
AUTO 2
PassFail
Color Bar
10
10
Pass
10
Pass
Jaggies #1
5
5
Pass
5
Pass
Jaggies #2
5
5
Pass
0
Fail**
Flag
10
10
Pass
0
Fail**
Detail
10
10
Pass
10
Pass
Noise
10
5
Pass
5
Pass
M otion adaptive Noise Reduction
10
5
Pass
5
Pass
Film Detail
10
0
Fail
0
Fail
Cadence 2:2 Video
5
0
Fail
5
Pass
Cadence 2:2:2:4 DV Cam
5
0
Fail
5
Pass
Cadence 2:3:3:2 DV Cam
5
0
Fail
0
Fail
Cadence 3:2:3:2:2 Vari-speed
5
0
Fail
0
Fail
Cadence 5:5 Animation
5
0
Fail
0
Fail
Cadence 6:4 Animation
5
0
Fail
0
Fail
Cadence 8:7 animation
5
0
Fail
0
Fail
Cadence 24fps film
5
5
Pass
5
Pass
Scrolling Horizontal
10
10
Pass
10
Pass
Scrolling Rolling
10
10
Pass
10
Pass
Total Points
130
75
70
** See note about AUTO 2 Mode lock-on issue.
Comments on HQV Testing
We had a very interesting time running the Silicon Optix HQV tests and ran into several interesting anomalies that we would like to note in an effort to make sure you get the best possible performance out of this player. First off, it's important to remember that each display device is different, and some displays will fare better at different output resolutions than others. When using the DVI or HDMI outputs of the DVD-3910, be sure to experiment with different output formats to arrive at the best possible setting. An example of this is that we first began testing the player using 720p in conjunction with a Yamaha LPX-510 3LCD projector (1280 x 720 resolution). During the Film Detail test, the player could not seem to lock on and eliminate the moiré pattern from the scene quickly or consistently. Switching the DVI output to 1080i immediately rectified this problem and resulted in a perfect Passing score - however it's important to note that at this point, the projector was hadling the deinterlacing, so the DVD-3910 still technically fails this test. The Film detail test would not pass via component video or HDMI, even when we tried another display (a MAXX Products LCOS projector with a resolution of 1400 x 1050.)
The cadence tests also presented unique challenges for the DVD-3910 and our reference display. We found that in AUTO 1 mode (the default progressive mode) the Denon DVD player passed all of the Jaggies tests with only minor artifacting. AUTO 2, however, was not without its interesting traits. After switching to AUTO 2, which is more optimized for video cadences) we found that upon returning to the Flag test or Jaggies #2 test, the player would not correctly apply directional filtering until the Setup Menu of the DVD player was engaged and disengaged. We have brought up this anomaly with Denon and are also reproducing it in-house to see if we can isolate and identify the problem. We recommend staying with AUTO 1 mode for general use of this player.
