Vizio SV472XVT 47" TruLED LCD Preview
- Product Name: SV472XVT 47” TruLED LCD
- Manufacturer: Vizio
- Review Date: May 06, 2010 02:10
- MSRP: $1799.99
- Specifications
Model #: Vizio SV472XVT
Model Features: VIZIO Internet Apps, 802.11N Dual Band Wireless Networking, TruLED Superior LCD HDTV Performance, Smart Dimming, 2,000,000:1 Dynamic Contrast Ratio, 240Hz SPS, Full HD 1080P, 45% below Energy Star 3.0, Mercury Free
- Size: 47"
- Viewable: 46.96" diagonal
- Tuner: ATSC/Clear QAM Tuner
- Native Panel Resolution: 1920 x 1080 pixels
- Signal Compatibility: Supports 1080I(HDTV), 720P(HDTV), 480P(EDTV), 480I(SDTV)
- Colors: 1.06 Billion
- Computer Support: 1920x1080, 1360x768, 800x600, 640x480 via VGA/HDMI
- Display Compatibility: 1080P(FHDTV)
- Dynamic Contrast Ratio: 2,000,000:1 w/DCR
- Brightness: 500 cd/m2 (typical)
- Response Time: 5ms
- Viewable Angle: 178/178 degrees (horizontal/vertical)
- Pixel/Dot Pitch: 0.4845mm x 0.4845mm
- SRS TruSurround HD: Yes
- SRS TruVolume: Yes
- SRS TruSurround XT: No
INPUTS (REAR)
- HDMI with HDCP 3
- RF Connector for Internal Tuner 1
- Composite Video: 1
- Component YPbPr plus Stereo Audio: 1
- S-Video: 1
- Computer RGB: 1
- USB Ports:
INPUTS (SIDE)
- HDMI with HDCP 1
- Composite Video:
- S-Video:
- Computer RGB:
- USB Ports: 1 (Service and Future Multimedia Functionality)
- Music (MP3):
- Video (MPG):
- Photo (JPEG):
OUTPUTS (REAR)
- SPDIF Digital Optical: 1
- Stereo Audio: 1
- Headphones:
ADDITIONAL FEATURES
- Refresh Rate: 240Hz
- Smooth Motion: Yes
- LED: Direct Type LED Backlight Technology with Smart Dimming - 640 LEDs (80 control Blocks)
- Picture-in-Picture (PIP): Yes
- Picture-outside-Picture (POP): Yes
- Zero Bright Pixel Defect Guarantee: Yes
- V-Chip: Yes
- 3D Comb Filter: Yes
- 3:2 or 2:2 Reverse Pull-down: Yes
- ATSC with 8VSB & QAM demodulation: Yes
- ATSC with MPEG-2 decoding: Yes
- NTSC Video decoding via Video: Yes
- Progressive Scan Video: Yes
- Color Temperature: 5400K, 6500K and 9300K
- Color Fine Tuning: Independent Red, Green and Blue
- Speakers: 15W x 2 speakers
- Panel Lamp Life (typical): 40,000 Hours
- Voltage Range: 100~240 Vac at 50/60 Hz
- Power Consumption: 120V < 1W
- Universal Remote: VIZIO Bluetooth Remote Control with Qwerty Keyboard - VUR10
WEIGHT
- Gross: 71.43lbs
- Net With Stand: 51.81lbs
- Without Stand: 46.52lbs
DIMENSIONS
- With Stand: 43.854"W x 29.669"H x 10.035"D
- Without Stand: 43.854"W x 28.146"H x 4.067"D
- Packaging Dimensions: 49.213"W x 35.433"H x 12.795"D
CERTIFICATIONS CSA/ CSA-US, FCC Class B
COMPLIANCES Energy Star 3.0, ATSC Spec A/65, EIA/CEA-766-A
WALL MOUNT SPECIFICATIONS
- Hole Pattern: 400mmx200mm
- Screw Size: M6
- Screw Length: 20mm
- Screw Pitch: 1.0mm
VIZIO WARRANTY One Year Parts & Labor Free Lifetime Technical Support
Executive Overview
VIZIO’S 47” TruLED HDTV LCD continues to break the mold of traditional HDTV’s, delivering the latest technologies for superior picture quality and sound! This direct type, backlit HDTV is comprised of 640 LED’s divided into 80 control blocks and utilities Smart Dimming to intelligently control these blocks, turning them on and completely off based on the content you’re watching. This cutting edge technology stops light leakage enabling you to achieve REAL 2,000,000:1 contrast ratio for rich, dark scenes delivering an experience that will blow you away. Rounding this out are features such as full 1080p high definition resolution for crystal clear images, 240Hz Smooth Motion for fluid transitions and SRS audio technologies for amazing sound! And using the latest wireless technology, you can easily connect to the Internet and stream movies and TV shows using the Netflix and Amazon widgets, listen to your favorite music via Rhapsody and get the latest news, sports and weather through Yahoo. The Universal Bluetooth remote with slide out QWERTY keypad makes sending a Tweet or changing your status on Facebook a breeze.
Audioholics hasn't yet done a formal review of this product, but we wanted to get as much information as possible to our readers in order to help them make the best possible purchasing decisions. If possible, we will provide additional info or even a product review at a later date.
For more information, please visit: http://www.vizio.com/flat-panel-hdtvs/sv472xvt.html
