Vizio M470VT 47" RazorLED LCD Preview
- Product Name: M470VT 47” RazorLED LCD
- Manufacturer: Vizio
- Review Date: April 02, 2010 01:05
- MSRP: $1169.99
- Specifications
Model #: M47VT
- Size: 47"
- Viewable: 46.06" diagonal; 16:9 Aspect Ratio
- Tuner: ATSC/QAM
- Native Panel Resolution: 1920 x 1080 pixels
- Signal Compatibility: 1080p (FHDTV)
- Colors: 1.06 Billion
- Computer Support: 640 x 480, 800 x 600, 1024 x 768, 1920 x 1080 via RGB or 1920 x 1080 via HDMI
- Dynamic Contrast Ratio: 100,000:1
- Brightness: 450 nits
- Response Time: 8ms
- Viewable Angle: 178/178 degrees (horizontal/vertical)
- Pixel/Dot Pitch: 0.5415mm(H) x 0.5415mm(V)
- SRS TruSurround HD: Yes
- SRS TruVolume: Yes
- SRS TruSurround XT: No
INPUTS (REAR)
- HDMI with HDCP 4
- RF Connector for Internal Tuner 1
- Component YPbPr plus Stereo Audio: 1
- Composite Video:
- S-Video:
- Computer RGB: 1
- Ethernet:
- USB Ports: 1
- Music (MP3):
- Video (MPEG):
- Photo (JPEG):
INPUTS (SIDE)
- HDMI with HDCP
- Composite Video:
- S-Video:
- Computer RGB:
- USB Ports:
- Music (MP3):
- Video (MPEG):
- Photo (JPEG):
OUTPUTS (REAR)
- SPDIF Digital Optical: 1
- Stereo Audio:
- Headphones:
ADDITIONAL FEATURES
- Refresh Rate: 120Hz
- Smooth Motion: No
- LED: Yes - edge lit
- Picture-in-Picture (PIP):
- Picture-outside-Picture (POP):
- Zero Bright Pixel Defect Guarantee: Yes
- V-Chip: Yes
- 3D Comb Filter: Yes
- 3:2 or 2:2 Reverse Pull-down: Yes
- ATSC with 8VSB & QAM demodulation: Yes
- ATSC with MPEG-2 decoding: Yes
- NTSC Video decoding via Video: Yes
- Progressive Scan Video: Yes
- Color Temperature: 6500K, 9300K and 115000K
- Color Fine Tuning: Independent Red, Green and Blue
- Speakers: Built-in 10W x 2 Speakers
- Panel Lamp Life (typical): 60,000 Hours
- Voltage Range: 120Vac at 60Hz
- Power Consumption: 86.6W(avg), <1W Standby
- VIZIO Remote Control: VUR14
WEIGHT
- Gross: 65.04lbs
- Net With Stand: 52.91lbs
- Without Stand: 46.30lbs
DIMENSIONS
- With Stand: 44.32"W x 29.39"H x 9.92"D
- Without Stand: 44.32"W x 28.91"H x 1.85"D
- Packaging Dimensions: 50.39"W x 34.25"H x 8.85"D
CERTIFICATIONS CSA, CSA-US, FCC Class B, BQB
COMPLIANCES ENERGY STAR 4.0
WALL MOUNT SPECIFICATIONS
- Hole Pattern: VESA standard 200mm X 200mm
- Screw Size: M6
- Screw Length: 10.0mm
- Screw Pitch: 1.0 mm
VIZIO WARRANTY One Year Parts & Labor Free Lifetime Technical Support
Executive Overview
With less than a
1.85” thin profile, the M470VT RazorLED LCD HDTV offers razor sharp clarity
with 1080p full high definition resolution and a 120Hz refresh rate delivering
sharp, blur free images. The dynamic 1,000,000:1 contrast ratio present
deeper blacks and brighter whites with colors that stand out brilliantly adding
to the rich detail and deep contrast on this HDTV.
Also included is
the digital ambient light sensor ensuring you will always have the best picture
and most efficient energy savings by adjusting the brightness based on the
lighting conditions of your room. Enjoy ultimate connectivity with up to four
high definition inputs and experience advanced sound technologies from SRS Labs
including SRS TruSurround HD and SRS TruVolume. Take pleasure in knowing
this energy efficient LED LCD HDTV exceeds new ENERGY STAR 4.0 Guidelines to
reduce energy consumption, conserving our planet’s resources while saving you
money.
Audioholics hasn't yet done a formal review of this product,
but we wanted to get as much information as possible to our readers in order to
help them make the best possible purchasing decisions. If possible, we will
provide additional info or even a product review at a later date.
For more information, please visit: http://www.vizio.com/flat-panel-hdtvs/m470vt.html
