Vizio M220VA 22" LCD Preview
Vizio M220VA 22” LCD
  • Product Name: M220VA 22” LCD
  • Manufacturer: Vizio
  • Review Date: May 06, 2010 02:10
  • MSRP: $299.99
Specifications
Model #: Vizio M220VA
  • Size: 22"
  • Viewable: 21.53" diagonal
  • Tuner: NTSC/ATSC/QAM
  • Native Panel Resolution: 1920 x 1080 pixels
  • Signal Compatibility: 1080P, 1080i, 720P, 480P, 480i
  • Colors: 16.7 Million
  • Computer Support: 1920 x 1080, 1360 x 768, 1024 x 768, 800 x 600, 640 x 480 via VGA/HDMI
  • Dynamic Contrast Ratio: 20,000:1
  • Brightness: 250 nits
  • Response Time: 5ms
  • Viewable Angle: 170/160 degrees (horizontal/vertical)
  • Pixel/Dot Pitch: 0.248mm(H) x 0.248mm(V)
  • SRS TruSurround HD: Yes
  • SRS TruVolume: Yes
  • SRS TruSurround XT: No
INPUTS (REAR)
  • HDMI with HDCP 2
  • RF Connector for Internal Tuner 1
  • Component YPbPr plus Stereo Audio: 1
  • S-Video:
  • Computer RGB: 1
INPUTS (SIDE)
  • HDMI with HDCP
  • Composite Video:
  • S-Video:
  • Computer RGB:
  • USB Ports: Multimedia (JPEG only)
  • Music (MP3):
  • Video (MPEG):
  • Photo (JPEG): Yes
OUTPUTS (REAR)
  • SPDIF Digital Optical: 1
  • Stereo Audio:
  • Headphones: 1
ADDITIONAL FEATURES
  • Refresh Rate: 60Hz
  • Smooth Motion: No
  • LED: Yes - edge lit
  • Picture-in-Picture (PIP): No
  • Picture-outside-Picture (POP): No
  • Zero Bright Pixel Defect Guarantee:
  • V-Chip: Yes
  • 3D Comb Filter: Yes
  • 3:2 or 2:2 Reverse Pull-down: Yes
  • ATSC with 8VSB & QAM demodulation: Yes
  • ATSC with MPEG-2 decoding: Yes
  • NTSC Video decoding via Video: Yes via RF or Composite Video
  • Progressive Scan Video: Yes, thru Component VGA or HDMI
  • Color Temperature: 5400K, 6300K and 9300K
  • Color Fine Tuning: Independent Red, Green and Blue
  • Speakers: Built-in 3W x 2 Speakers
  • Panel Lamp Life (typical): 30,000 Hours
  • Voltage Range: 120Vac at 60Hz
  • Power Consumption: 28W, <1W Standby
  • Universal Remote: VIZIO Remote Control - VR10 or VR10W
WEIGHT
  • Gross: 13.45lbs
  • Net With Stand: 8.653lbs
  • Without Stand: 7.364lbs
DIMENSIONS
  • With Stand: 20.63"W x 14.09"H x 5.03"D
  • Without Stand: 20.63"W x 14.09"H x 2.27"D
  • Packaging Dimensions: "W x "H x "D
CERTIFICATIONS Energy Star 4.0, UL, CUL, FCC Class B
COMPLIANCES EIA/CEA-766-A
WALL MOUNT SPECIFICATIONS
  • Hole Pattern: VESA standard 75 X 75mm
  • Screw Size: M4
  • Screw Length: 10.0mm
  • Screw Pitch: 0.7 mm
VIZIO WARRANTY One Year Parts & Labor Free Lifetime Technical Support
Executive Overview
With only a 0.75” thin profile, the M220VA RazorLED LCD HDTV offers Full 1080p high definition resolution for crystal clear images, brilliant color, rich detail and deep contrast - all in a sleek razor thin design with black and white bezel color options. The LED LCD HDTV also includes a digital ambient light sensor ensuring that you will always have the best picture and most efficient energy savings by adjusting the brightness based on the lighting conditions of your room. Enjoy ultimate connectivity with five high definition inputs and when you’re not watching TV, the M220VA can be used as a digital picture frame to enjoy a slideshow of your family and friends.
Experience advanced sound technologies from SRS Labs and take pleasure in knowing this mercury free, energy efficient LED LCD HDTV exceeds new Energy Star 4.0 Guidelines by 33%.
Audioholics hasn't yet done a formal review of this product, but we wanted to get as much information as possible to our readers in order to help them make the best possible purchasing decisions. If possible, we will provide additional info or even a product review at a later date.
For more information, please visit: http://www.vizio.com/flat-panel-hdtvs/m220va.html
Submit News!
