Vizio M19OMV 19" LCD Preview
- Product Name: M19OMV 19” LCD
- Manufacturer: Vizio
- Review Date: April 23, 2010 01:15
- MSRP: $249.99
- Specifications
Model #: Vizio M190MV
- Size: 19"
- Viewable: 18.5" diagonal
- Tuner: NTSC/ATSC/QAM
- Native Panel Resolution: 1366 x 768 pixels
- Signal Compatibility: 720P, 480P, 480i
- Colors: 16.7 Million
- Computer Support: 1366 x 768, 1360 x 768, 1024 x 768, 800 x 600, 640 x 480 via RGB/HDMI
- Dynamic Contrast Ratio: 20,000:1
- Brightness: 250 nits
- Response Time: 5ms
- Viewable Angle: 170/160 degrees (horizontal/vertical)
- Pixel/Dot Pitch: 0.300mm(H) x 0.300mm(V)
- SRS TruSurround HD: Yes
- SRS TruVolume: Yes
- SRS TruSurround XT: No
INPUTS (REAR)
- HDMI with HDCP 2
- RF Connector for Internal Tuner 1
- Component YPbPr plus Stereo Audio: 1
- S-Video: 1
- Computer RGB: 1
- Composite Video: 1
- USB Ports: 1 Multimedia (JPEG only)
- Photo (JPEG): Yes
INPUTS (SIDE)
- HDMI with HDCP
- Composite Video:
- S-Video:
- Computer RGB:
- USB Ports:
- Music (MP3):
- Video (MPEG):
- Photo (JPEG):
OUTPUTS (REAR)
- SPDIF Digital Optical: 1
- Stereo Audio:
- Headphones: 1
ADDITIONAL FEATURES
- Refresh Rate: 60Hz
- Smooth Motion: No
- LED: Yes - edge lit
- Picture-in-Picture (PIP): No
- Picture-outside-Picture (POP): No
- Zero Bright Pixel Defect Guarantee: No
- V-Chip: Yes
- 3D Comb Filter: Yes
- 3:2 or 2:2 Reverse Pull-down: Yes
- ATSC with 8VSB & QAM demodulation: Yes
- ATSC with MPEG-2 decoding: Yes
- NTSC Video decoding via Video: Yes via AV, S-Video, or Component
- Progressive Scan Video: Yes, thru Component HDMI
- Color Temperature: 5400K, 6300K and 9300K
- Color Fine Tuning:
- Speakers: Built-in 5W x 2 Speakers
- Panel Lamp Life (typical): 30,000 Hours
- Voltage Range: 240Vac at 50/60Hz
- Power Consumption: 37W, <1W Standby
- VIZIO Remote Control: VR9
WEIGHT
- Gross: 8.09lbs
- Net With Stand: 5.91lbs
- Without Stand: 5.84lbs
DIMENSIONS
- With Stand: 18.32"W x 13.32"H x 7.27"D
- Without Stand: 18.32"W x 12.25"H x 2.36"D
- Packaging Dimensions: 23.62"W x 16.41"H x 4.72"D
CERTIFICATIONS Energy Star 4.0, UL, CUL, FCC Class B
COMPLIANCES EIA/CEA-766-A
WALL MOUNT SPECIFICATIONS
- Hole Pattern: VESA standard 100 X 100mm
- Screw Size: M4
- Screw Length: 10.0mm
- Screw Pitch: 0.7 mm
VIZIO WARRANTY One Year Parts & Labor Free Lifetime Technical Support
Executive Overview
The M190MV
RazorLED LCD HDTV is brilliant in color, rich in detail and deep in contrast –
all in a razor thin design. This immaculate beauty delivers a 20,000:1
dynamic contrast ratio for deeper blacks and brighter whites. This
RazorLED LCD HDTV also includes touch sensitive controls that illuminate when
your hand draws near and fade away once you’re done. Enjoy ultimate
connectivity with five high definition inputs.
But it doesn’t stop there! Experience advanced sound technologies from SRS Labs
and take pleasure in knowing this mercury free, energy efficient LED LCD HDTV
exceeds new Energy Star 4.0 Guidelines by 10%.
Audioholics hasn't yet done a formal review of this product, but we wanted to get as much information as possible to our readers in order to help them make the best possible purchasing decisions. If possible, we will provide additional info or even a product review at a later date.
For more information, please visit: http://www.vizio.com/flat-panel-hdtvs/m190mv.html
