Vizio E470VA 47" LCD Preview
- Product Name: E470VA 47” LCD
- Manufacturer: Vizio
- Review Date: April 02, 2010 01:05
- MSRP: $969.99
- Specifications
Model#: Vizio E470VA
- Size: 47"
- Viewable: 46.96" diagonal
- Tuner: NTSC/ATSC/QAM
- Native Panel Resolution: 1920 x 1080 pixels
- Signal Compatibility: 1080P, 1080i, 720P, 480P, 480i
- Colors: 1.06 Billion
- Computer Support: 1360 x 768 via HDMI, 1360 x 768, 1024 x 768, 800 x 600, 640 x 480 via RGB
- Dynamic Contrast Ratio: 50,000:1
- Brightness: 500 cd/m2
- Response Time: 5ms
- Viewable Angle: 178/178 degrees (horizontal/vertical)
- Pixel/Dot Pitch: 0.5415mm(H) x 0.5415mm(V)
- SRS TruSurround HD: Yes
- SRS TruVolume: Yes
- SRS TruSurround XT: No
INPUTS (REAR)
- HDMI with HDCP 4
- RF Connector for Internal Tuner 1
- Component YPbPr plus Stereo Audio: 1
- S-Video:
- Computer RGB: 1
- Composite Video:
- USB Ports: 1 (Jpeg Only)
- Photo (JPEG):
INPUTS (SIDE)
- HDMI with HDCP
- Composite Video:
- S-Video:
- Computer RGB:
- USB Ports:
- Music (MP3):
- Video (MPEG):
- Photo (JPEG):
OUTPUTS (REAR)
- SPDIF Digital Optical: 1
- Stereo Audio:
- Headphones:
ADDITIONAL FEATURES
- Refresh Rate: 120Hz
- Smooth Motion: Yes
- Panel Type: CCFL, LCD
- Picture-in-Picture (PIP): No
- Picture-outside-Picture (POP): No
- Zero Bright Pixel Defect Guarantee: Yes
- V-Chip: Yes
- 3D Comb Filter: Yes
- 3:2 or 2:2 Reverse Pull-down: No
- ATSC with 8VSB & QAM demodulation: Yes
- ATSC with MPEG-2 decoding: Yes
- NTSC Video decoding via Video: Yes
- Progressive Scan Video: Yes
- Color Temperature: 5400K, 6300K and 9300K
- Color Fine Tuning: Red/Green/Blue
- Speakers: Built-in 10W x 2 Speakers
- Panel Lamp Life (typical): 60,000 Hours
- Voltage Range: 120Vac at 50/60Hz
- Power Consumption: 88W, <1W Standby
- VIZIO Remote Control: VUR11
WEIGHT
- Gross: 67.46 lbs
- Net With Stand: 55.34 lbs
- Without Stand: 43.37 lbs
DIMENSIONS
- With Stand: 44.13"W x 29.57"H x 10.75"D
- Without Stand: 44.13"W x 27.96"H x 3.69"D
- Packaging Dimensions: 50.39"W x 34.25"H x 8.85"D
CERTIFICATIONS CSA, CSA-US, FCC Class B
COMPLIANCES Energy Star 4.0 ATSC Spec A/65, EIA/CEA-766-A
WALL MOUNT SPECIFICATIONS
- Hole Pattern: VESA standard 400 X 200mm spacing
- Screw Size: M6
- Screw Length: 10.0mm
- Screw Pitch: 1.0 mm
VIZIO WARRANTY One Year Parts & Labor Free Lifetime Technical Support
Executive Overview
VIZIO’s E470VA 47” LCD HDTV delivers full 1080p HD picture quality and superior audio at an amazing value! This flat screen LCD HDTV features 120Hz refresh rate for razor sharp clarity, SRS TruVolume and SRS TruSurround HD audio for advanced virtual surround sound, 50,000 to 1 Dynamic Contrast Ratio giving you deeper blacks and brighter whites, and four HDMI ports to connect up to four HDMI devices to your TV. The E550VA also exceeds ENERGY STAR 4.0 Guidelines, offering 60% less energy consumption than the 47" 2009 model and utilizes built-in ambient light sensing technology, which automatically adjusts backlight levels to the brightness of its surroundings.
Audioholics hasn't yet done a formal review of this product, but we wanted to get as much information as possible to our readers in order to help them make the best possible purchasing decisions. If possible, we will provide additional info or even a product review at a later date.
For more information, please visit: http://www.vizio.com/flat-panel-hdtvs/e470va.html
