Vizio E371VA 37" LCD Preview
Vizio E371VA 37” LCD
  • Product Name: E371VA 37” LCD
  • Manufacturer: Vizio
  • Review Date: June 15, 2010 01:00
  • MSRP: $629.99
Specifications
  • Size:     37"
  • Viewable:     37" diagonal viewing
  • Tuner:     NTSC/ATSC/QAM
  • Native Panel Resolution:     1920 x 1080 pixels
  • Signal Compatibility:     1080p (FHDTV), 1080i (HDTV), 720P (HDTV), 480P (EDTV), 480i (SDTV)
  • Colors:     1.06 Billion
  • Computer Support:     1920 x 1080, 1024 x 768, 800 x 600, 640 x 480 via RGB/HDMI
  • Dynamic Contrast Ratio:     50,000:1
  • Brightness:     500 nits
  • Response Time:     5ms
  • Viewable Angle:     178/178 degrees (horizontal/vertical)
  • Pixel/Dot Pitch:     0.42675mm(H) x 0.42675mm(V)
  • SRS TruSurround HD™:     Yes
  • SRS TruVolume™:     Yes
  • SRS TruSurround XT™:     No
INPUTS (REAR)
  • HDMI with HDCP     4
  • RF Connector for Internal Tuner     1
  • Component YPbPr plus Stereo Audio:     1
  • Composite Video:
  • S-Video:
  • Computer RGB:     1
  • USB Ports:     1
  • Music (MP3):
  • Video (MPEG):
  • Photo (JPEG):     Yes
INPUTS (SIDE)
  • HDMI with HDCP
  • Composite Video:
  • S-Video:
  • Computer RGB:
  • USB Ports:
  • Music (MP3):
  • Video (MPEG):
  • Photo (JPEG):
OUTPUTS (REAR)
  • SPDIF Digital Optical:     1
  • Stereo Audio:
  • Headphones:
ADDITIONAL FEATURES
  • Refresh Rate:     120Hz
  • Smooth Motion:     No
  • LED:     No
  • Picture-in-Picture (PIP):     No
  • Picture-outside-Picture (POP):     No
  • Zero Bright Pixel Defect Guarantee:     Yes
  • V-Chip:     Yes
  • 3D Comb Filter:     Yes
  • 3:2 or 2:2 Reverse Pull-down:     Yes
  • ATSC with 8VSB & QAM demodulation:     Yes
  • ATSC with MPEG-2 decoding:     Yes
  • NTSC Video decoding via Video:     Yes via AV or Component
  • Progressive Scan Video:     Yes, thru HDMI
  • Color Temperature:     6500K, 9500K, 11500K
  • Color Fine Tuning:     Independent Red, Green and Blue
  • Speakers:     Built-in 10W x 2 Speakers
  • Panel Lamp Life (typical):     60,000 Hours
  • Voltage Range:     120Vac at 60Hz
  • Power Consumption:     79W, <1W Standby
  • VIZIO Remote Control:     VUR11
WEIGHT
  • Gross:     42.11lbs
  • Net With Stand:     32.19lbs
  • Without Stand:     27.78lbs
DIMENSIONS
  • With Stand:     35.41"W x 24.30"H x 8.76"D
  • Without Stand:     35.41"W x 22.92"H x 3.76"D
  • Packaging Dimensions:     41.92"W x 27.75"H x 8.07"D
CERTIFICATIONS
UL, FCC Class B, ATSC Spec A/65, EIA/CEA-766-A
COMPLIANCES
Energy Star 4.0
WALL MOUNT SPECIFICATIONS
  • Hole Pattern:     VESA standard 200mm X 200mm
  • Screw Size:     M6
  • Screw Length:     10.0mm
  • Screw Pitch:     1.0 mm
VIZIO WARRANTY
One Year Parts & Labor Free Lifetime Technical Support
Executive Overview
VIZIO’s E371VA 37” LCD HDTV delivers full 1080p HD picture quality at an amazing value. This flat screen LCD HDTV features 120Hz for fluid transitions, SRS TruVolume and SRS TruSurround HD audio for advanced virtual surround sound, 50,000 to 1 Dynamic Contrast Ratio, and four HDMI ports to connect up to four HDMI devices to your TV. The E371VA also exceeds ENERGY STAR 4.0 Guidelines to reduce energy consumption and utilizes built-in ambient light sensing technology, which automatically adjusts backlight levels to the brightness of its surroundings.
The E371VA's 120Hz refresh rate allows it to display faster movement much more clearly as it is capable of showing 120 frames per second, twice as many as standard televisions, resulting in a much clearer high definition experience. The photo viewing feature allows for direct viewing of most standard image file types on the E371VA by way of a USB flash drive. Additionally, the E371VA's built in ambient light sensor adjusts image brightness to adjust for lighting levels in the room, resulting in reduced power consumption and an optimal picture.
Audioholics hasn't yet done a formal review of this product, but we wanted to get as much information as possible to our readers in order to help them make the best possible purchasing decisions. If possible, we will provide additional info or even a product review at a later date.
Submit News!
