You are here: Home Pro Reviews Televisions & Displays Flat Panels Toshiba REGZA 46LX177 LCD Review 46LX177 Menu System
46LX177 Menu System
by Clint DeBoer last modified December 10, 2007
I found the menu system for the Toshiba 46LX177 to be very easy to use. It was well organized for the major functions and had direct access via the remote for commonly used features like the THINC system and Picture-in-Picture functions. There was a bit of drill-down to get to the more advanced features, but no more than you would expect to keep the upper levels from being too cluttered. I'll move through each of the major menu functions here:
Applications
menu-applications.jpgThis menu connects you to the Picture Viewer, Audio Player and Email systems. It also allows access to the incredibly cool Channel Browser which is sophisticated enough to allow for some very cool ways to browse though and select channels on your television. I'll go into more detail on this system later in the review. The Applications menu also allows you to start up the Demo mode as well as access the integrated Help system. The Help system is a very slick-looking subsystem that would benefit from additional time and development. For the most part the Help topics ranged from 'mildly useful' to 'go fix it yourself'. Here is one of my favorite screens when selecting help with setting up your PC for filesharing:
Help says: “Go figure it out on your own!”
They made up for it with such helpful screen as this one located under a connections section:
Now that is pretty helpful!
I'd love to see more development in this area as I feel it is a trend-setting feature. An integrated Help system only makes sense with the ever-increasing complexity of our AV devices. Future versions of the Help system should not be afraid to venture into multi-page solutions. Also, running the text by someone who has English as a first language would likely help in smoothing over some of the wording to more consumer-friendly jargon (friends don't let friends use overseas engineers to write their help manuals).
Video
menu-video.jpgThe Video menu provides most of the settings and configuration you'll need to get the basic tweaking done for your display. The [Picture] Mode is located here as are the Picture Settings, Noise Reduction modes, Game Mode, xvYCC (Deep Color), Theater Settings and aspect ratio settings. ColorMaster Pro is a neat gimmicky color adjustment control that is fun to play with but doesn't do anything practical towards garnering more accurate color. The Game Mode turns off some of the internal video processing and in exchange speeds up the display's response time (reduces frame delays) in order to avoid lag time from the gaming console. Gaming Mode disables ClearFrame, Cinema Mode (2-3 pull-down) and Film Stabilization.
The Theater Settings sub-menu allows you to select the Picture Size (Natural, Theater Wide 1/2/3, Full, 4:3, and Native. This affects the way the picture is stretched (or not) to occupy the screen. Toshiba provides some of the more extensive scaling options I've seen to date and they add a feature I'd not seen until now, Picture Scroll, which allows you to take TheaterWide 2/3 modes and scroll the picture up and down vertically. This means you can really take advantage of the flexibility to get a truly custom position on the screen when dealing with letterboxes, closed captioning, etc.
Audio
menu-audio.jpgWhat at first appears to be a very small menu does expand somewhat when you go into Audio Setup (there is both an Audio Settings and Audio Setup sub-menu as well as an Advanced Audio setting believe it or not). Audio Setup allows configuration of whether the PC (HD15) input will receive audio from the analogue audio inputs which are shared with HDMI input #1. It also sets the MTS mode, Language and whether or not the speakers are engaged (a nice feature if you utilize an external set of speakers.) You can also configure Dolby Digital Dynamic Compression and change the optical audio output from Dolby Digital (default) to PCM audio.
Preferences
In Preferences you find your catch-all settings for Closed Captioning, Menu Language and auto-input switching, but you also have access to custom Input Labeling which is cool (though limited) and the Channel Browser setup which lets you determine how channels and inputs will be selected in that menu.
Input Labels are cool, but they could use a few more - like Game Console 2, 3, 4... And while Toshiba included HD DVD in the available selections, Blu-ray was conspicuously absent.
Locks
menu-locks.jpgThis is the menu everyone often skips over, but it's actually very useful. Most programming these days, as you may have noticed, carries ratings in the form of TVY, TVY7, TVPG, MA, etc... The Toshiba's V-chip, like most other televisions can filter out what is allowable. The 46LX177 implements these filters fully, allowing you to not only select which rating you will allow, but also for what reason. Don't mind TVMA as long as the content isn't sexual in nature? No problem, you can enable a block just for that aspect. Now, I can't vouch for how accurate these blocks work or what shows are marked correctly, however it seems to be a very nice feature for parents to use and the Toshiba implementation is very well thought out.
Don't mind the violence, but don't want the sex-shows... not a problem.
Setup
Whether it's your cable/antenna system, THINC network settings or just whether or not you intend to use the CE-Link system, the Setup menu is where it's at. I liked the optional Power-Saving mode – it lets people who care about saving power feel good about being inconvenienced while allowing more performance-based people like me to have a quick turn-on mode and retain my Channel Browser settings. It's also in this menu where you can configure the Slide Show Interval for photos and also enable automatic Demo mode which is nice for retailers.
If you're in possession of a new HD-DVD player (of either flavor) you can enable both Deep Color and xvYCC support to benefit from these new color-enhancing technologies.
Technical Note: What's the difference between Deep Color and xvYCC?
This is a good question and the two terms are often, incorrectly, used interchangably. Deep Color refers to the increasing of the bit depth per channel of RGB from 8-bits to 12-bits. This means that Deep color allows for more color resolution within the RGB or YCbCr color range. xvYCC actually expands the color range to what is essentially 1.8x the sRGB color space. Deep Color gives us more resolution (all but eliminates banding), and xvYCC gives us more colors.
Recent Forum Posts:
Thunder18 posts on January 13, 2008 10:54
MDS;356840
So now to add insult to injury Toshiba is releasing a whole slew of new models starting February. I've already proven I can go 6 months without TV so maybe I'll wait a little longer to see what these new models can do.
Anyone wanna bet that I'll get my whole house tiled before I pick another TV?
From what I've seen at AVSforum, I'd be surprised if their new models were any different. Both the HL167 series and LX177 series had this issue of not being adequately set from the factory. They didn't want to address it before and I'm loathe to believe they will address it now. I guess we can wait till the new model line is reviewed to see how much work they have to do to get an accurate picture setting. Why they can't just put the setting necessary to calibrate the set accurately in the user's control is beyond me. Hell, add a new button on the remote....all reset. Brings all setting back to the factory defaults. Make it one of those buttons that you have to press with a safety pin so it's not easily activated and there you go.
MDS posts on January 13, 2008 03:22
mtrycrafts;356721
Because the 'general public' has no idea and don't care if they were impressed with what they saw in the store thinking falsely that is how it is supposed to be.
And, it is the 'general public' that buys most of the sets, not us.
I want to be part of the general public.
I am sick to death of this process of choosing a TV. As I've said the Toshiba was mostly pretty good to my eyes with the exception of the few cases where there was excess green when I thought there shouldn't be (I don't think it qualified as 'green push' where you saw green in the blacks - I never saw that). It was mostly the SD quality that annoyed me and with my limited experience with actually owning an HDTV for all I know that is all you can expect.
mtrycrafts posts on January 12, 2008 17:57
MDS;355954
... no TV in the history of mankind has been shipped with an accurate gray scale (to the D6500K standard).
jlahk posts on January 12, 2008 17:56
avaserfi;356687
Most source material isn't necessarily 60Hz for example most film is done in 24Hz.
LCDs suffer from image blur where a fast moving image stays on the screen slightly (but visibly) longer than intended. Sometimes known as trailing this problem is due to the nature of LCD technology - having a faster refresh rate helps this problem by in a sense erasing the screen more often.
Another plus of properly done 120Hz refresh is that if your player does 24Hz output rather than having to deal with 3:2 pulldown to make the 24 frames match up to 60 you can just show the same frame 5 times and have less video issues.
Where you don't have 24Hz output though, doesn't the faster refresh rate just reapply the same image more frequently?
mtrycrafts posts on January 12, 2008 17:54
Thunder18;356448
... I have to say I was a lot more easily satisfied before HD. I couldn't see any difference and honestly I didn't really care at that resolution. Now that I can see the grease in the pores on the actors faces I can clearly see something is wrong and it bothers me to no end.
See what happens to us when we know a bit more
