Sceptre E320PV-FHD 32" LED TV First Look
- Product Name: E320PV-FHD
- Manufacturer: Sceptre
- Review Date: April 15, 2011 03:05
- MSRP: $499
- Specifications
LED Panel
Active Screen Size
31.5"
Aspect Ratio
16:9 Wide Screen
Frame Rate
60 Hz
Brightness
400 cd/m2
Contrast Ratio
4000 : 1
Dynamic Contrast Ratio
50,000 : 1
Resolution
1920 x 1080
Response Time
6.5 ms
Colors
16.7 million
LED Backlight Life
> 30,000 hours
Viewing Angle
178º (horizontal) / 178º (vertical)
Features
On Screen Display Control (OSD)
Picture, Sound, Channel, Parental, Setup, Others
OSD Language
English / French / Spanish
Build-in Tuner
ATSC / NTSC
Auto Dynamic Contrast Enhancement
Yes
Comb Filter
3D
De-interlace Technology
3D
Noise Reduction
Yes
Noise Reduction
Yes
Build-in Speaker
9 Watts per Channel x 2
Surround Mode
Virtual surround
Sound Equalizer Setting
Yes
Auto Volume Level Control
Yes
Swivel Angles
+/- 30 Degree
Height Adjustable
No
Neck & Base Detachable
Yes
Wall Mountable
VESA
Inputs
HDMI
3
Cable / Antenna Input
1
Component Video Input
1
Composite Video
1
S-Video
0
VGA
1
Audio In
1
USB Input
1
Outputs
Headphone Output
1
SPDIF Audio Output (Coaxial or Optical)
1 (Coaxial Type)
Analog Audio Output (L + R)
1
Signals Compatibility
HDTV
1080P, 1080i, 720P, 480P, 480i
HDMI Input Support
1080/24P, 1080/60P, 1080i, 720P, 480P
Component Input Support
VGA Input Support
1920 x 1080@ 60Hz (Native & Max)
Regulation
Certificates
FCC, cCSAus
Compliances
RoHS
Power Source
Power Range
100 – 240VAC, 60/50 Hz, 3A (Max.)
Power consumption
110W (Max), 100W (Typical), < 0.5W (Standby)
Wall Mount Specification
Hole Pattern (mm)
200mmx100mm
Screw Size (mm)
M4 x 12mm
Weight
Net Weight (lb)
24.4 lb (with Stand), 19.8 lb (without Stand),
Gross Weight (lb)
32.67 lb
Dimensions
with stand (inch)
30.5”x7.5”x22”
without stand (inch)
30.5” x1.9” x20”
Packaging Dimension
33.86” x 5.51” x 25.19”
Warranty
One Year Limited Parts and Labor
Executive Overview
That's right, it's freaking pink.
Okay, now that we've gotten that out of the way, Sceptre has released an new line of 32" LED LCD televisions that come in a variety of colors, one of which is pink with brushed nickle accents. The others are black with brushed nickle accents and nickle with black accents. The difference in the model numbers changes the P to a B or G respectively.
When we think of devices we'd like customized, we think of things like remotes, cell phones, and MP3 players. We might even think of small LCDs to put in our blinged out Chevy Nova. What we don't think of is 32" LED LCDs.
But now that you mention it, we can see the allure. Spectre's new line of LED backlit LCD panels come in at a fairly affordable $500 MSRP (street price sure to be less) and in three colors. Funny thing is that it is already discounted. The list price on the Spectre site is $699 but the press release says $499. As you can imagine, it is a bit of a gamble offering different color options. Spectre risks being stuck with warehouses full of pink monitors (unless they just made a handful, cause that's what we'd do). But that said, it isn't a bad strategy. There are so many displays on the market these days, having a way of differentiating yourself is definitely a bonus. Plus, when you just can't buy your daughter a pony, a pink display is the next best thing right?
The E320PV-FHD is a 1080p display with a 60Hz refresh rate. It claims a 50,000:1 dynamic contrast ratio and over 30,000 hours for the LED backlight. There are three HDMI inputs, a cable/antenna input, a component video input, and a composite video input. There are one each of headphone, SPDIF (coaxial), and analogue audio (RCA) outputs. Lastly there is an USB input for streaming pictures or music directly to the TV.
What is telling here is not the lack of technology (really 60Hz?) or the missing features (3D), but the intended use. Spectre is marketing these displays not only as televisions, but as alternative to monitors. For that, we really like them and the color option makes sense. This is not a TV that is designed to be a centerpiece of a home theater (at 32", that'd be a pretty sad home theater - sorry for those offended but come on, 32"?) but as one that is designed for an office (black/grey) or kids room (pink), they start come into focus. Sure, for $500 you might be able to get bigger or even better, but can you get something that matches you room?
Well, maybe but let's leave it at "probably not."
The inputs are all well recessed which means hiding the cables won't be a problem. Plus, you can remove the included stand and use any VESA compliant wall mount to give your new pink beauty the clean look she deserves. With an internal tuner, more than enough inputs, and the ability to stream off a USB drive, the Sceptre E320PV-FHD and her cousins look to be a great second monitor.
We did some research and a starting point of $499 for a 32" LED LCD isn't too high or low. It comes in about middle of the road. Of course, where that price ends up is the real question. With the added advantage of multiple colors (something that Sceptre has done in the past with smaller TVs so one has to assume they've had success enough to justify more line), they are sure to grab attention. While you won't see cutting edge technology in them, what you will see is a monitor that you can use in a game room, office, or just about any casual viewing environment.
For more information, please visit www.sceptre.com.
