You are here: Home Pro Reviews Televisions & Displays Flat Panels Proton LX-37B1C2 37-inch LCD TV Review Proton LCD Menu System, Remote & Calibration
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Clint DeBoer last modified February 20, 2007
I checked all of the available inputs and determined that the Proton correctly allows for independent user settings for each. The available inputs are:
  • DVI-D
  • VGA/RBG/HD15 (up to 1280x1024 @ 60Hz, or 1024x768 @ 75Hz)
  • Memory card (CF/MicroDrive/SM/MS/SD/MMC)
  • Component video (2) [480i/480p/720p/1080i]
  • Composite/S-video (2)
Switching inputs is accomplished through the remote - but be quick, the menu only stays up for about 2 seconds. Hitting the "Source" button brings up a menu of input choices (including the "Card Reader" and TV tuner inputs). You can either continue pressing the "Source" button to toggle through your options (stopping activates that input after a brief delay), or use the remote control's navigation keys to scroll up or down (and hit the "OK" button to select).
Both of the component inputs can handle 480i, 480p, 720p or 1080i input. All inputs retain their own picture settings - a big plus and considered a requirement for any serious display. The menu system is broken up into six icon-labeled sections for layout, picture, window, audio, options, and settings.
Proton37_layout_lg.jpgLayout
This menu section controls the picture-inon-picture and split-screen functions. There are four options. The first two, full screen and PIP, can also be cycled and accessed via the remote control's PIP button. The last two are somewhat special and involve split screen and multi-view modes. We mentioned the pop 3 mode earlier when we outlined some of the Proton's features, but it's important to note that it does this multi-channel update feature with only a single NTSC tuner, cycling through each channel as needed to update the image (the channels freeze during the cycle period). You can also feed any of the AV inputs into these screens should you really want to multitask.
Proton37_picture_lg.jpgPicture
The picture menu is by far the most feature-packed section of the user menu. It features color, tint, sharpness, contrast & brightness settings. There are also three color temperature settings plus a fourth "user" setting whereby you can dial in the color temperature incrementally to a desired value (there is no numeric designation). A "digital focus" setting seems to act as a sort of noise reduction circuit and makes analogue cable channels look quite a bit better, reducing some of the grain inherent in those lower channels.
A room lighting feature has 4 settings allowing you to alter the gamma settings of the display for Normal, Bright, Movie, or Factory modes. Factory supports the best black levels, but you can use the "Movie" or "Bright" modes for daytime viewing once you have calibrated the system for nighttime use.
Window
The window menu, like all of the menu items is contextually aware and features settings and controls for image size (aspect ratio and zoom control), h position, v position, pip size, pip position, freeze window, and digital pan and zoom. Most of these features are self explanatory; however the image size is the one that will likely get used the most. Here is how the settings affect a simple 4:3 circle crosshatch pattern:
Normal
Anamorphic
Fill All
Video Game Zoom
Zoom
Wide
As you can see, the Normal and Anamorphic settings perform as you would expect (and I noticed only a few pixels of difference between Anamorphic and Fill All). The Zoom mode maintains the aspect ratio when viewing 4:3 content on a 16:9 screen by simply enlarging the picture to where the top and bottom are lopped off, leaving the center to fill the entire screen. Video Game Zoom vertically compresses the image a bit in order to net a bit more screen real estate for heads up displays and CG data that is common in games. The Wide setting cuts off a little bit of the top and bottom in order to deliver a slightly more true-to-shape image over Anamorphic. I was disappointed to not find a logarithmic scalable mode whereby the center of the screen remains less horizontally stretched than the edges. Many new displays have this and it is a very effective way to stretch 4:3 content to fit on a 16:9 television.
Remote Control
Proton37_remote_lg.jpg No remote will ever make everyone happy. This remote is sufficient to the task of getting the job done, but does run into some significant failings. The IR sensitivity is way too low. We put in fresh batteries and if you do not point the remote within 5 degrees or so of the IR sensor on the TV, it is likely that the command will not be interpreted and carried out (we were only 10 feet away). I like a little bit more leeway with my remote controls. The button arrangements are good, but not great. No backlighting is provided and the keys do not glow. Depending upon what menu function you are using, navigating images on a memory stick for example, you may find yourself using the outside volume and channel buttons instead of the more sensible arrow pad to navigate around the interface.
The top of the remote has the navigation keys for using the menu system as well as volume and channel buttons. The navigation area is bordered by four buttons which engage the menu, mute, source and power functions. "Menu" and "Source" can be toggled or you can interact with the navigation controls to make selections.
There are four colored buttons on the remote, however the manual does not tell you much about them let alone if they are programmable (we do not believe they are). Here is an Audioholics exclusive:
  • Red - Adjusts PIP size
  • Green - Swaps PIP
  • Yellow - Turns PIP on and off
  • Blue - Toggles the PIP mode and/or movies it if engaged.
The upper button section features a numeric keypad, but also performs double duty as controls for memory card functions. With them you can browse, zoom, rotate, and increment photos as well as engage a slideshow and show the photos as black & white images. A dedicated setup menu allows you to set the slideshow delay, select the card source, adjust the display mode (full screen or actual image proportions), set the slideshow transitions, erase photos or display photo information.
The lower button section on the remote takes care of such features as freeze frame, which freezes the current image on the screen, PIP functions (size, position, swap, etc), aspect ratio adjustment, MTS audio, and closed captioning. All in all, this remote is sufficient (except for the IR range), but nothing fancy.
Calibrating the Television
We used Datacolor's Colorfacts Professional 5.0 software to measure and help calibrate this LCD television. It allowed us to evaluate grayscale uniformity and contrast on the set as well as generate some telling histograms and CIE information. The worst thing I could say about the Proton television in terms of its default calibration was that it's color temperature is a bit high, making skin tones and such a tad on the blue side. The default Color Temp setting is medium, but we recommend setting it to just above the "low" value by using the User controls to manual adjust it. The other thing I quickly noted was that black levels at the bottom end 2.5-20 IRE were crushed - meaning you couldn't differentiate anything from 0-20 IRE. After turning down the backlight to 50% I was able to get much better dark resolution without reducing the overall contrast ratio (in fact it increased it by exactly 1 to 113:1 ANSI). While this isn't the best contrast ratio we've measured, the real-world picture quality still seems quite reasonable.
Before Calibration
After Calibration
In checking the RGB Level Histogram I found that there was a significant amount of blue in the picture. Whites looked really cool, but we were going for a more accurate calibration.
After calibrating the LX-37B1C2, we were able to get better accuracy out of the red and blue levels; green stayed pretty much dead on. This was all accomplished using only color temperature, tint and color settings along with adjusting the backlight level. RGB gain and cut is not available in the user controls.
As you can see here in the Luminance Histogram, the gamma curve is such that the black levels are crushed up to around 20 IRE and there is a bit of a hump between 40 and 70 IRE.
After adjusting the set, we got a slight amount of gain (resolution) at 20 IRE and smoothed out our hump to contain it to between 40-60 IRE and reduce the size.
The initial Temperature Histogram shows what we noted about the high color temperature of the set. This showed that it was universally high from black to white (0-100 IRE).
After dialing in the color temperature by hand sing the User controls, we got it down to a respectable level, more closely matching the ideal 6500K target.
