You are here: Home Pro Reviews Televisions & Displays Flat Panels Panasonic TH-50PH9UK 50" Plasma Display Review
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Tom Andry last modified December 07, 2007
  • Product Name: TH-50PH9UK 50" Plasma Display
  • Manufacturer: Panasonic
  • Review Date: August 27, 2006 20:00
  • MSRP: $ 3995
Specifications
Screen Size (inches): 50
Aspect Ratio: 16:9
Native Resolution: 1366 x 768
Contrast Ratio: Up to 10000:1
Viewing Angle (degrees): More than 160
New Real Black Creation: Yes
Dimensions (H x W x D): 28.5'' x 47.6'' x 3.7''
Weight: 81.6 lbs
  • Beautiful picture
  • Easy menus with lots of control
  • Great user manual
  • Attractive price
  • No internal tuner
  • Extremely limited number of inputs
  • Optional HDMI/DVI-D inputs are additional
Introduction
Wait a second, didn’t I just review this panel? Well, yes and no. This is the new version (notice the “9”in the model number) of the TH-50PHD8UK I recently reviewed. My first question was, “So, what’s different?”Well, the first thing I noticed from the specs was that the newer display has a stated 10000:1 contrast ratio rather than a 3000:1. The newer model is also missing the REAL Mach system. This new unit uses much thinner glass (from 2.8mm to 1.8mm) which reduces the weight from 94.8 lbs to 81.6 lbs (a 15% reduction). The unit uses 16-bit digital signal processing and improved “sub-field driving technology”to reproduce 3,072 steps of gradation. Other than that, the units aren’t really all that different. The remote is the same, the menus are the same, the inputs are the same... if you have a question about this unit that doesn’t seem covered by this review, check out the review of the TH-50PHD8UK. Unless it is contradicted here, it still applies.
