You are here: Home Pro Reviews Televisions & Displays Flat Panels Panasonic TH-50PF9UK 50" 1080p Plasma Display Review Panasonic TH-50PF9UK: Build Quality
by Tom Andry last modified August 09, 2007
I’ve had a chance to review a number of 720p displays in recent months. They have, for the most part, all been very good. But there has always been this itch… the 1080 itch I call it. Will it look that much better? Will it be that much better? With a 50” screen, I’ve often heard people say that you can’t tell the difference. Maybe that’s true, but personally, I want to see for myself.
advertisement
Build Quality
Front.The TH-50PF9UK shares the same chassis as the TH-50PH9UK and the TH-50PHD8UK. It is heavier than the PH9UK but it keeps the same styling. The small frame and lack of speakers really give this display that “window” look. The thin frame just disappears into the background and I’ve seen applications where people have actually installed picture frames over the edges of the display.
I’ve read reports of “hums” or noises associated with units in this line of Panasonics. The hum seems to be associated with the plasma screen itself while others have complained about the fan noise. Personally, I don’t see how anyone could complain about any noise from these displays. I specifically paid attention to any stray noises and noticed nothing. I sit about 8 feet away from a 50” display (far closer than I think most would). With the speakers off, and after hours of use, I could only hear noise when I place my head behind the unit. Even with my ear directly up to the screen, I heard next to nothing. If you are experiencing any stray noise, I’d first suggest you look at other sources. If you are sure it is coming from the display, consider placing some absorptive material behind the unit. It could be enhanced by reflections off the back wall.
