Sony BRAVIA KDL-46EX600 46" LED Preview
- Product Name: BRAVIA KDL-46EX600
- Manufacturer: Sony
- Review Date: May 06, 2010 02:10
- MSRP: $1349.99
- Specifications
Model #: KDL-46EX600
•Video Signal : 1080/60p (HDMI / COMPONENT), 1080/60i, 1080/24p (HDMI ONLY), 720/60p, 480/60p, 480/60i
•Power Consumption (in Operation) max. : 135W Max
•Power Consumption (in Standby) : 0.33W Max
•Power Requirements (frequency) : 60Hz
•Power Requirements (voltage) : AC 120V
•Audio Power Output : 20W (10W x 2)
•Speaker Configuration : 2
•Speakers (Total) : 2
•Ambient Sensor : Yes
•Auto Photo Mode : via USB
•Auto Picture Setting w/ HDMI™ : Cinema, Photo, Graphics, Game
•Auto Shut-off : Yes
•BRAVIA Sync : Yes
•BRAVIA Sync Menu Button : Yes (on Remote Control)
•Channel Block (with password) : Yes
•Channel Jump : Yes
•Channel Labels : Yes
•Channel Surf : Yes
•Control for HDMI™ (HDMI™ CEC) : Yes
•Edit Channel Labels : Yes
•Favorites : Yes
•ID-1 Detection : Yes
•Info Banner : PSIP, XDS
•Input Skip : Manual
•Label Inputs : Yes
•Multiple Language Display : English, French, Spanish
•On-Screen Display for External Input : Yes
•PIP (Picture in Picture) : PC Input(HD15/HDMI) & TV Channel/CVBS/(HDMI)/(Component)
•Parental Control : Yes
•Picture Adjustments Lock : Yes
•Picture Frame Mode : Yes
•Program Block : Yes
•Scene Select : Auto, Cinema, Sports, Photo, Music, Game, Graphics, General
•Short Banner : Yes
•Show/Hide Channels : Yes
•Sleep Timer : Yes
•Start Up Sony Logo Display : Yes
•Theatre Mode (Theatre Button) : Yes
•USB Application(s) : Photo Viewer (jpeg), Music Player (mp3), Video Player (mpeg1), Video Player (mpeg2 TS)
•USB Player : Yes
•White Balance : RGB Gain/Bias
•Backlight Type : Edge LED
•Display Device : LCD
•Channel Coverage : VHF: 2-13ch UHF: 14-69ch CATV (analog): 1-135ch CATV (digital) : 1-135ch
•Color System : NTSC
•Number of Tuners (Analog) : 1(Hybrid)
•Number of Tuners (Digital) : 1(Hybrid)
•TV System (Analog) : M
•Tuner (Cable) : QAM
•Tuner (Terrestrial) : ATSC / NTSC
•Dimensions (Approx.) : 42 3/4 x 27 1/8 x 10 1/4" (1085 x 688 x 260mm) with pedestal; 42 3/4 x 25 7/8 x 3" (1085 x 656 x 74 mm) without pedestal
•Weight (Approx.) : 40.6 lbs (18.4Kg) with pedestal; 35.5 lbs (16.1Kg) without pedestal
•24p True Cinema Technology : Yes
•3D Comb Filter : Yes
•4:3 Default : Yes
•Advanced Contrast Enhancer (ACE) : Yes
•Auto Wide : Yes
•CineMotion Reverse 3:2 Pulldown Technology : Yes
•Cinema Mode : Yes
•Live Color Technology : Yes
•MPEG Noise Reduction : Yes
•Picture Mode : Vivid, Standard, Custom
•Video Processing : BRAVIA Engine 2 Technology
•Wide Mode : Normal, Zoom, Wide Zoom, Full (Full1-2 for PC)
•Limited Warranty Term : 1 Year Labor / 1 Year Parts
•VESA Hole Pitch : 300x300(46")
•VESA Hole Spacing Compatible : Yes
•AC Power Input : 1 (Rear) AC Socket
•Analog Audio Input(s) (Total) : 4 (1 Side / 3 Rear)
•Audio Out : 1(Rear)
•Component Video (Y/Pb/Pr) Input(s) : 2 (Rear) (1 fixed/1 selectable)
•Composite Video Input(s) : 2 (1 Side/1 Rear)
•Digital Audio Output(s) : Optical Digital Output - 1 (Rear)
•HDMI™ Connection(s) (Total) : 4 (2 Side/2 Rear)
•HDMI™ PC Input : Yes
•PC In (D-Sub) + Audio In (Stereo Mini) : 1 (Rear)
•RF Connection Input(s) : 1 (Rear)
•USB 2.0 : 1(Side)
•5.1 Channel Audio Out : Yes
•5.1ch Through Out (Handycam) : Yes
•Alternate Audio (Digital) : yes
•Audio Out : Fixed
•Auto Mute (on no signal) : Yes
•Auto SAP : 20FM/10AM
•Clear Voice : Yes
•Dolby : Dolby Digital
•Invisible Speaker (w/Sound Elevation) : Yes
•Sound Mode : Dynamic, Standard, Clear Voice, Custom
•SteadySound Automatic Volume Control : Yes
•Stereo System : MTS
•Surround Effect : Cinema, Music, Live Sports, Game
•Backlight Off Mode : Yes
•Dynamic Backlight Control : Yes
•Eco Settings : Yes
•Estimated Annual Energy Consumption (kWh) : 159 kWh
•Idle TV Standby : Yes
•Power Consumption (On Mode) for Energy Star : 86.14W
•Power Consumption (Standby Mode) for Energy Star : 0.33W
•Power Saving Modes : Yes
•Aspect Ratio : 16:9
•Display Resolution : Full HD 1080(1920x1080)
•Dynamic Contrast Ratio : Infinite4
•Screen Size (measured diagonally) : 46"
•Viewing Angle (Right/Left) : 178 (89/89)
•Viewing Angle (Up/Down) : 178 (89/89)
•Closed Captions (CC) : Analog, Digital
•Finish (Surface Color) : PianoBlack
•HDMI InstaPort : Yes
Executive Overview
The Sony BRAVIA KDL-46EX600 is one of three Bravia-2-powered HDTVs announced in 2010 as part of the KDL-EX600 Series. Unlike the KDL-EX700 models, the KDL-46EX600 is not built for Internet connectivity, although it does, still includes the Bravia 2 Engine for clear and defined color/picture detail. As the largest unit in the series, the KDL-46EX600 is 46”, but still retails under $2000. It provides full 1080p high-definition resolution, an ultra-fast frame-rate, and HDMI connectivity to Blu-ray disc players or gaming consoles. Most notable is the USB Media Player, allowing users to enjoy movies, photos, and music directly from any USB-enabled device.
Audioholics hasn't yet done a formal review of this product,
but we wanted to get as much information as possible to our readers in order to
help them make the best possible purchasing decisions. If possible, we will
provide additional info or even a product review at a later date.
For more information, please visit: http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921666077674#overview
