Sony BRAVIA KDL-40EX700 LED 40" Preview
- Product Name: BRAVIA KDL-40EX700
- Manufacturer: Sony
- Review Date: May 06, 2010 02:10
- MSRP: $1259.99
- Specifications
Model #: KDL-40EX700
Video Signal : 1080/60p (HDMI / COMPONENT), 1080/60i, 1080/24p (HDMI ONLY), 720/60p, 480/60p, 480/60i
BRAVIA Internet Video : Ready
DLNA : Renderer (Photo/JPEG); Renderer (Music/LPCM,MP3); Renderer (Video/MPEG2,AVCHD); Client (Photo/JPEG); Client (Music/LPCM,MP3); Client (Video/MPEG2,AVCHD)
DLNA : Yes
Photo MAP : Yes
Backlight Off Mode : Yes
Dynamic Backlight Control : Yes
Eco Settings : Yes
Energy Saving Switch : Yes
Estimated Annual Energy Consumption (kWh) : 130.5kWh/year
Idle TV Standby : Yes
Power Saving Modes : Yes
Presence Sensor : Yes
Aspect Ratio : 16:9
Display Resolution : Full HD 1080(1920x1080)
Dynamic Contrast Ratio : Infinite3
Screen Size (measured diagonally) : 40"
Viewing Angle (Right/Left) : 178(89/89)
Viewing Angle (Up/Down) : 178(89/89)
Audio Return Channel : Yes
Closed Captions (CC) : Analog, Digital
Finish (Surface Color) : Black
HDMI InstaPort : Yes
XMB : Yes
Dimensions (Approx.) : 38 7/8 x 25 7/8 x 11 1/8" (985 x 655 x 280mm) with pedestal; 38 7/8 x 24 5/8 x 2 5/8" (985 x 623 x 64mm) without pedestal
Weight (Approx.) : 39.3 lbs. (17.8kg) with pedestal; 32.9 lbs. (14.9kg) without pedestal
Power Consumption (in Download Acquisition Mode) : Less than 16 W
Power Consumption (in Operation) max. : 107W
Power Consumption (in Standby) : 0.13W
Power Requirements (frequency) : 60Hz for UL,cUL 50/60Hz for other
Power Requirements (voltage) : AC 120V for UL,cUL AC110-240V for other
Audio Power Output : 20W (10W x 2)
Speaker Configuration : 2
Speakers (Total) : 2
Ambient Sensor : Yes
Auto Photo Mode : via HDMI, via DLNA, via USB
Auto Picture Setting w/ HDMI : Cinema, Sport, Music, Photo, Graphics, Game
Auto Shut-off : Yes
BRAVIA Sync : Yes
BRAVIA Sync Menu Button : Yes (on Remote Control)
Channel Block (with password) : Yes
Channel Jump : Yes
Channel Labels : Yes
Channel Surf : Yes
Control for HDMI (HDMI CEC) : Yes
Edit Channel Labels : Yes
Favorites (Simple UI) : Yes
Info Banner : TV Guide on Screen, PSIP, XDS
Input Skip : Automatic
Label Inputs : Yes
Multiple Language Display : English, French, Spanish
On-Screen Clock : Yes
On-Screen Display for External Input : Yes
On-Screen Operating Instructions : Yes
On/Off Timer : Yes
PIP (Picture in Picture) : PC Input/TV Channel&CVBS
Parental Control : Yes
Picture Adjustments Lock : Yes
Picture Frame Mode : Yes
Quick Start : Yes
Scene Select : Auto, Cinema, Sports, Photo, Music, Game, Graphics, OFF
Show/Hide Channels : Yes
Sleep Timer : Yes
Stand Swivel : Yes
Stand Swivel Range : Left 20°/Right 20°
Start Up Sony Logo Display : Yes
TV Guide On-Screen : Yes
Theatre Mode (Theatre Button) : Yes
Theatre Mode with Cinema Surround : Yes
USB Application(s) : Photo Viewer (jpeg), Photo Viewer (RAW), Music Player (mp3), Video Player (AVCHD), Video Player (AVC), Video Player (MPEG4)
USB Player : Yes
White Balance : RGB Gain/Bias
Wireless LAN : Ready
Backlight Type : Edge LED
Display Device : LCD
Channel Coverage : VHF: 2-13ch UHF: 14-69ch CATV (analog): 1-135ch CATV (digital) : 1-135ch
Color System : NTSC
Number of Tuners (Digital) : 1(Hybrid)
TV System (Analog) : M
TV System (Digital) : ATSC
Tuner (Cable) : Clear QAM
Tuner (Terrestrial) : ATSC / NTSC
5.1 Channel Audio Out : Yes
5.1ch Through Out (Handycam) : Yes
Alternate Audio (Digital) : yes
Audio Out : Variable/Fixed
Auto Mute (on no signal) : Yes
Auto SAP : 20FM/10AM
Clear Voice : Yes
Dolby : Dolby Digital
Invisible Speaker (w/Sound Elevation) : Yes
S-Master : Yes
Sony Original Surround : Yes
Sound Enhancer : Yes
Sound Mode : Dynamic, Standard, Clear Voice, Custom
SteadySound Automatic Volume Control : Yes
Stereo System : MTS
Surround Effect : Cinema, Music, Live Sports, Game
24p True Cinema Technology : Yes
3D Comb Filter : Yes
4:3 Default : Yes
Advanced Contrast Enhancer (ACE) : Yes
Auto Wide : Yes
CineMotion Reverse 3:2 Pulldown Technology : Yes
Cinema Mode : Yes
Deep Color : Yes
Live Color Technology : Yes
MPEG Noise Reduction : Yes
Motionflow Technology : 120Hz
PhotoTV HD : Yes
Picture Mode : Vivid, Standard, Custom, Cinema, Game-Standard, Game-Original, Graphics, Sports, Photo-Vivid, Photo-Standard, Photo-Original, Photo-Custom
Video Processing : BRAVIA Engine 3 Technology
Wide Mode : Normal, Zoom, Wide Zoom, Full (Full1-2 for PC), H Stretch
Limited Warranty Term : 1 Year Labor / 1 Year Parts
Online Instruction Manual (Reference Book) : Yes
VESA Hole Pitch : 300x300 M6
VESA Hole Spacing Compatible : Yes
AC Power Input : 1 (Rear)
Analog Audio Input(s) (Total) : 4 (1 Side / 3 Rear)
Audio Out : 1 (Rear)
Component Video (Y/Pb/Pr) Input(s) : 2 (1 Rear / 1 Rear (Composite input common use))
Composite Video Input(s) : 2 ( 1 Rear (Component input common use)/ 1 Side)
Digital Audio Output(s) : Optical Digital Output - 1 (Rear)
Ethernet Connection(s) : 1 (Rear)
HDMI™ Connection(s) (Total) : 4(2 Side/2 Rear)
HDMI™ PC Input : Yes
PC In (D-Sub) + Audio In (Stereo Mini) : 1 (Rear)
RF Connection Input(s) : 1 (Rear)
USB 2.0 : 1 (Side)
Executive Overview
The Sony BRAVIA KDL-40EX700 is one of five Internet-connected HDTVs announced in 2010 as part of the KDL-EX700 Series. As a more affordable option to the KDL-NX700 series, the KDL-EX700 models, including the 40” KDL-40EX700, do not include integrated wireless connectivity, although it is available as an optional upgrade. The KDL-40EX700 supports full 1080p high-definition resolution with an ultra-fast frame-rate, partially thanks to its Motionflow 120Hz technology. Included also are a plethora of connectivity options, including HDMI, composite, component, PC, and most importantly, Ethernet. Once connected to a network, users can stream movies and videos, or directly access the latest news and Twitter updates. Plus, USB-enabled devices like camcorders and MP3 players can be accessed through the unit’s USB port.
Audioholics hasn't yet done a formal review of this product,
but we wanted to get as much information as possible to our readers in order to
help them make the best possible purchasing decisions. If possible, we will
provide additional info or even a product review at a later date.
For more information, please visit: http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921666077676#specifications
