You are here: Home Pro Reviews Speakers Subwoofers Velodyne HGS-15X Subwoofer Review
by ray last modified May 01, 2007
Velodyne HGS-15X
Velodyne HGS-15X
  • Product Name: HGS-15X
  • Manufacturer: Velodyne
  • Review Date: June 10, 2005 20:00
  • MSRP: $ 1995
Specifications
Features
  • THX Ultra II
  • High quality crossover system
  • High Gain Servo System
  • Selectable subsonic filter (15/35Hz)
  • Infrared remote control (optional)
  • Adjustable low-pass filter
  • Subwoofer Direct crossover by-pass
  • Phase adjustment
  • XLR-Connector
  • Auto On/Off
Amplifier: Class D 1250 Wrms (3000 W peak)
Woofer: 15" forward-firing (12.7" piston diameter)
Voice Coil: 3" Dual Tandem push-pull
Excursion: 2" maximum
Magnet Structure: 380 oz  (24 lbs)
Cone: Kevlar reinforced
High Pass Crossover: passive 80/100Hz (6db/octave filter)
Low Pass Crossover: 40Hz-120Hz (12db/octave initial; 48dB/octave ultimate)
Crossover Bypass: Yes - subwoofer direct
Anti-clipping Circuit: Yes
Inputs & Outputs: Line Level & Speaker Level
Frequency Response: 18-120Hz +/- 3dB
Phase: 0 or 180 degrees
Distortion: Less Than 1%
Weight: 95lbs
Cabinet: 19.875"H  x 18" W x 17.875" D (including grill and feet)
  • High End Audiophile Performance
  • High Impact, WOW and Slam
  • Excellent LFE Performance
  • Very easy to integrate into room and custom cabinetry
  • Excellent build quality (Built in the USA)
  • Lots of performance at this price
  • No Variable phase control
  • No provision for aftermarket feet
Introduction
Velodyne helps audiophiles and videophiles assemble their dream home theater or music system with a satisfying subwoofer. The HGS-series appeases the musical side of the audiophile as well as the videophile's need for SPL.
