Velodyne Digital Servo-10 Subwoofer Preview
  • Product Name: Digital Servo-10 Subwoofer
  • Manufacturer: Velodyne
  • Review Date: September 07, 2011 19:40
  • MSRP: $1999
Specifications
  • Cabinet: Furniture grade satin black
  • Magnet: 19.3 lbs
  • Driver: 10" Kevlar-reinforced with die-cast aluminum basket; 3” dual tandem multi-layer voice coil
  • Amp: 1250 watt RMS (3000 watts Dynamic Power), 97% efficient, ERS Class-D
  • Digital High Gain Servo system
  • Digital Drive room management technology; on-board 8-band digital graphic/parametric EQ
  • Remote control with factory presets
  • Front panel LED
  • Includes: calibrated microphone, cables, built-in signal generator, remote
Executive Overview
Velodyne introduced its newest subwoofer, the new Digital Servo-10 (DS-10). The DS-10 is a sub that comes in right behind the company's Digital Drive (DD) series in terms of pricing and performance and is built to put out as much powerful and musical bass as possible within a smaller-sized, space-optimized enclosure. The DS-10 comes built with a cabinet-grade satin black finish. The driver is equally beautiful, but for different reasons (to those who are so enamored with technology). It's a 10-inch Kevlar–reinforced model with a ginormous 19.3 lbs. magnet structure and 3” dual tandem multi-layer voice coil. The basket is die-cast aluminum and everything is driven by an impressive 1250 watt RMS (3000 watts dynamic) ERS Class-D amplifier that claims 97% efficiency. As if that weren't enough, the sub includes Velodyne's patented Digital High Gain Servo (HGS) system that adjusts cone movement at a frequency of 16kHz (16,000 times a second). This is designed to lower distortion below 1% (or below what is considered audible. Everything is controlled by a high speed DSP processor.
The Velodyne Digital Servo-10 sub also features the company's Digital Drive (DD) room management system designed to use EQ to overcome room limitations and subwoofer placement. The included mic just gets placed at the listening position and the user can press the EQ button on the remote control. At that point the  Digital Servo-10 sub applies any of 8 bands of EQ to smooth out bass interactions caused by the subwoofer's position within the room. The system can also be used manually with 8-bands of parametric EQ made available when using an external calibrated microphone. There is even an output to view the curves and results on your television. The DS-10 sub also gives you amazing user control over the subsonic filter and low-pass crossover, slopes, phase and polarity. This is a sub that can truly be tweaked and optimized for any situation or room.
We mentioned earlier that the DS-10 comes with a remote control. On it there are factory presets for different music and movie settings. These presets can be changed to customize the sub to taste for each mode. You can even engage a “Night” mode which reduces the tactile output of the sub for an experience that (hopefully) won't cause your neighbors to call the cops on you in the middle of the night. A front panel LED read-out reacts to all inputs and gives a visual cue for remote control adjustments. The Digital Servo-10 subwoofer ships with a calibrated microphone, cables, a built-in signal generator and the remote control. The MSRP is expected to be $1,999. We'll update with the expected availability.
For more information on the Velodyne Digital Servo-10, visit http://www.velodyne.com.
hk2000 posts on February 16, 2012 05:47
I was just curious if a review of this was forthcoming. Please!
pbc posts on December 21, 2011 16:37
kini;850678
Apparently. No Amazon (direct) or seemingly Crutchfield either. Crutchfield is down to one Velodyne and it's some in the wall thing.
Too bad as Velodyne won't ship to Hawaii free and Crutchfield and Amazon would put things on sale at least.
Still looks like they have a ton of distributors/dealers listed on their website. Futureshop, Fry's, MODIA just to name a few.
kini posts on December 21, 2011 15:46
pbc;850536
So Velo has cut all their distribution arms and you can no longer buy their subs at a local dealer??
pbc posts on December 21, 2011 09:22
ratso;830036
umm... they're internet direct now, so that IS the price (unless they're going to undercut themselves??).
DS-21 posts on December 20, 2011 21:58
gtpsuper24;829941
Throw in a powerful amp (probably way overrated, but thats marketing)
Velodyne's standalone amp, the SC1250, was tested at ~630W/8Ω and ~1120W/4Ω. Yes, one could quibble that it's rated "1250W/4Ω," but that meaningless difference (0.5dBW) could well be a result of methodology.
Velodyne seems to use the same amp module in a lot of their products, so it's rather hyperbolic to assume that they're not rating the unit honestly, based on an objectively reasonable testing setup/methodology.
Submit News!
