Velodyne Digital Drive Plus Subwoofers First Look
by Gene DellaSala last modified March 29, 2011
Velodyne DD-18 Plus
Velodyne DD-18 Plus
  • Product Name: Digital Drive Plus
  • Manufacturer: Velodyne
  • Review Date: September 24, 2010 23:45
  • MSRP: $2499
Executive Overview
Velodyne’s new Digital Series Plus line was announced at CEDIA as a replacement to the venerable Digital Driver series.  The cabinet is contoured so no parallel surfaces are present with 1” thick MDF wall construction and internally braced ensures the woofer does its thing without the cabinet resonating.  I tapped all around the cabinet of a DD15+ and it sounded quite inert, more so that I recall from my reference DD15 subs.
Auto EQ+ has also been improved from the original EQ system of the DD series.  It uses a CD with low frequency sweep tones with an included microphone to establish a baseline of your systems bass performance.  It analyzers room anomalies and adjusting volume, EQ, phase, crossover etc to optimize performance.
Just like the original DD series, the DD+ comes in a 10” model (DD-10+  MSRP:$2,499), 12” model (DD-12+  MSRP:$2,999), 15” model (DD-15+ MSRP:$3,999), and an 18” model (DD-18+ MSRP:$4,999).
Although limited information was available, I directly compared the spec sheets for the DD15 and DD15+ to see what major differences were present.  What I found was the amplifier rated power, and voice coil size remained virtually unchanged but there are some obvious differences (dare I say improvements in the DD+ series).
DD-15
DD-15+
-3dB
15Hz
14.2Hz
Magnet:
24lbs
39.7lbs
Cone:
Kevlar reinforced resign
Fiberglass Rohacell Laminate
Dimensions:
20” x 18” x 18”
20” x 18” x 22.5”
 Controls
 Backpanel
 Frontpanel
Weight:
100lbs
120lbs
Velodyne DD+ Driver
Velodyne DD+ Driver
The woofer of the DD+ series is much less industrial looking than the original DD series and is quite stunning in appearance when you really examine it.  The motor structure is huge and quite different than the original DD driver, while the cone material has also been upgraded to Velodyne’s Fiberglass Rohacell Laminate.  While examining the driver at the Velodyne booth, there were no technical people available at the time of my visit, so I made my own observations as best as I could.  The DD+ driver appears to utilize an underhung designed motor structure where the voice coil is short compared to the top plate of the motor structure.  This is done in order to reduce harmonic distortion since voice coil is held in a constant  magnetic field throughout the entire XMAX of the driver.  This is quite an expensive driver type but shows how Velodyne will spare no expense to ensure the lowest possible distortion out of their flagship DD+ series of products.
Finish options include black gloss ebony, satin cherry or walnut.  The DD+ series will begin shipping this October.  It certainly appears to us that Velodyne has taken a hard look at the JL Audio Fathom series of subwoofers and has put them in checkmate.  As more information arrives, we will update this article.
In the meantime, visit Velodyne.
Recent Forum Posts:
theranman posts on January 30, 2011 13:23
Well, not only is the driver motor upgraded, but I'm guessing that the biggest improvement comes from the increased box size. It would appear that Velo is moving away from an aesthetics driven solution to a performance driven one. It's easy to do if you increase the box size. Trust me, they certainly haven't "checkmated" JL Audio by any stretch of the imagination. Copied them, perhaps, but not "checkmated". That's nothing more than hype, especially without any testing.
Matt34 posts on September 25, 2010 14:47
ratso;754330
matt, where did you see there will be a new standalone eq box?
Oh, I haven't. I'm assuming Velodyne will release a new model of the SMS-1 since there is a new EQ system incorporated with the DD+ subs.
ratso posts on September 25, 2010 13:50
Matt34 posts on September 24, 2010 23:58
Can't afford the subs but it will be neat to see the stand alone SMS-1 replacement.
