You are here: Home Pro Reviews Speakers Subwoofers SVSound SB12-Plus Review
by mark last modified February 14, 2007
SVSound SB12-Plus
SVSound SB12-Plus
  • Product Name: SB12-Plus
  • Manufacturer: SVSound
  • Review Date: October 10, 2006 20:00
  • MSRP: $ 699 (Vinyl) $749 (Veneer)
Specifications
Sensitivity (2.83 V/1m): 86.5 dB spl
Amp. Power: BASH© High-efficiency 425W hybrid-class, digital-switching power amp
Rated Impedance: 4 Ohms
Frequency Response (+/- 3, -6, -10 dB): 22 Hz (-3 dB) - 300 Hz (+ .2 dB); 20 Hz (-6 dB) - 300 Hz (+ .2 dB); 19 Hz (-10 dB) - 300 Hz (+ .2 dB)
Bass Principle: Acoustic Suspension
Cabinet Dimensions (W x H x L): 13.5"x 13.5"x 13.5" (342.9mm x 342.9mm x 342.9mm) without grill cloth
Active Processors: Crossover: active lowpass filter, variable,40 - 120 Hz
Parametric EQ: Variable Q (.1 to .9 octave), variable attenuation level (0 to -12 dB), and variable frequency (20 –80 Hz);
Variable phase (0 –180 degrees), and Room Compensation (variable slope highpass filter) (Small, Medium, Large Bypass)
Connection: Line Level: RCA & XLR jacks; speaker level: 5-way, gold-plated binding posts
Recommended Placing: Corner placement suggested
Shipping Weight: 40 lbs (18.1 kg)
  • Near-20Hz -3dB point in a small cabinet
  • Full Spectrum processor set
  • 5 available finishes
  • Updated driver & well constructed cabinet
  • Driver Mildly Noisy At Max Levels
Introduction
SVSound is no stranger to the hallowed pages of Audioholics.com. Building their reputation on products with a high bang-for-the-buck value (and this small sub is one impressively big bang-for-the-buck product), they are renowned for their comparatively large products, such as the mighty SVS PB12Plus-/2 reviewed earlier in this web page.
