Paradigm Signature Sub 2 Subwoofer Review Conclusion
Paradigm
has produced a tour de force with the Signature Sub 2. It is overall
the highest performing and most thoroughly impressive subwoofer that
I have encountered. The msrp of $8,999 is undoubtedly a large chunk
of cash but with the amount of development, technology and hardware
packed into each Sub 2 coupled with the attention to detail, high
tech look, beautiful finish and high
performance, that big sticker starts to look more reasonable. The
performance basics are well covered with a linear response, deep
extension, low distortion and plenty of headroom. Additionally
Paradigms PBK system is probably the best example of an automatic
equalization system that I have used to date. It made a measurable
and clearly audible improvement in response smoothness in my room. I
was also pleasantly surprised at the basic control scheme and lack of
filler features of limited usefullness on the Sub 2. The result is a
subwoofer that is surprisingly easy to integrate and set-up. I had it
dialed in in about an hour and a half, at which point it sounded very
good indeed. Wall shaking power is on tap at will as the Sub 2
clearly demonstrated with a couple of big time performances on movie
night. Obtaining useful extension and output down to the 10Hz range
is not out of the question with this subwoofer. Likewise with two
channel music there is plenty of headroom to serve up near live
output levels. But the kicker is that no matter how hard the Sub 2 is
pushed the output is always well controlled and lacking in
significant coloration. You are more likely to run into issues with
objects vibrating due to the Sub 2’s output in your listening
space. That sort of neutrality coupled with lots of headroom goes a
long way towards making the foundation of any material sound its
best. The Sub 2 simply performed magnificently no matter what I
happened to be listening to. One other unanticipated attribute of the
Sub 2 that I noticed was that it always started a conversation
whenever one of my friends or family would be over and see it for the
first time where they would ask what it was or “how
does that one sound”? Most
of my friends have seen so many speakers come through my house that
they barely get a second glance or draw a comment anymore. Not the
Sub 2, it invariably received comments and questions. Paradigm’s
Signature Sub 2 is undoubtedly one of the most impressively
engineered powered subwoofers on the market today. If this fine
subwoofer is within your financial means you would be remiss to not
give it an audition.
The Paradigm Signature Sub 2 receives the Audioholics Bassaholic Extreme Room rating, which means that this sub is recommended as maintaining adequate headroom in rooms or spaces of 5,000 cubic feet or greater and/or for users who usually listen at high volume levels. For further information in how we make these recommendations see the full article here.
See: Audioholics Subwoofer Room Size Rating Protocol
Paradigm
Signature Sub 2 Review
Paradigm
Electronics Inc.
Paradigm.com
Customer
Support: (905)696-2845
MSRP:
$8,999
— Excellent
— Very Good
— Good
— Fair
— Poor
| Metric | Rating |
| Bass Extension | ![]() ![]() ![]() ![]() ![]() |
| Bass Accuracy | ![]() ![]() ![]() ![]() ![]() |
| Build Quality | ![]() ![]() ![]() ![]() ![]() |
| Fit and Finish | ![]() ![]() ![]() ![]() ![]() |
| Ergonomics & Usability | ![]() ![]() ![]() ![]() |
| Features | ![]() ![]() ![]() ![]() ![]() |
| Dynamic Range | ![]() ![]() ![]() ![]() ![]() |
| Performance | ![]() ![]() ![]() ![]() ![]() |
| Value | ![]() ![]() ![]() |
See also:
3db;880459
I still want that Sub 1
No why do you cheat us like this.....
You want at least two sub 1's' perhaps even two sub 1's at each channel...... he he
mbfleming;880716
The sides with drivers are a little wider than the sides that don't, so it's not exactly hexagonal either.
You have a nice looking ceiling. lol
Yep, that's 100% correct. I started out saying octahedron which isn't right considering all sides aren't equal, then when I realized my error, I made another error in forgetting that the "prism" part denotes it's 3d-ness.
