You are here: Home Pro Reviews Speakers Subwoofers Outlaw Audio LFM-1 Review LFM-1 Listening Tests and Conclusion
by Clint DeBoer last modified February 15, 2007
I try not to prejudge or otherwise bring notions of what a product will sound like prior to an actual listening session. Often times you cannot honestly have a clear listening palette due to familiarity with prior models or proximity to a competing product – and this is what often worries manufacturers involved in combined reviews or shootout contests. In this case, the presence of the LFM-1 next to the SVS PB2-ISD left a healthy fear that perhaps this twin review wasn’t such a good idea.
But that was before I switched on the LFM-1 and calibrated it to reference levels. The result could be compared to nothing less than a controlled explosion. Whether it was the downward-firing driver & ports, or the optimization (and intelligence in this case) of settling upon a 25Hz tuning frequency, the Outlaw Audio LFM-1 pushes more air than I thought possible from a single 12” system.
image014_001.jpgLet’s take my favorite subwoofer test, the “Bridge of Khazad-dûm” chapter of Lord of the Rings: Fellowship of the Ring. What a good subwoofer will do with this scene is transfer the visual energy of crumbling rock and stone into a physical response felt by the viewer. Your seat will resonate and respond to the imagery on the screen and the scene will come to life in a way that no satellite/sub system can adequately portray. The Outlaw Audio LFM-1 lost none of the audible power of this scene and, in fact, belied its size with an almost chameleonic ability to confuse me into wondering if I was truly listening to it or the much larger SVS PB2-ISD.
image016_000.jpgPop in Star Wars Episode Two: Attack of the Clones and feel the ships enter the opening scene and land on the city-planet of Coruscant. That kind of powerful portrayal of screen elements is not something that comes easily from a smaller container, yet Outlaw Audio has managed apply optimum engineering to the LFM-1 and eek out a performance worthy of a standing ovation.
Subjective Listening Tests – Music
If it excels at home theater it must be so-so on music, right? For the life of me I cannot understand why it is that so many notions about subwoofer applications for music and movies are skewed. Perhaps it is the proliferation of poorly-designed boomy subs, or those monotonous units that seem to fire off a single tone regardless of what frequencies they are being fed. Neither of the subwoofers in this review exhibited either of these traits. In fact, both units measured fairly consistently within the known characteristics of Reference System 3. There are some great tunes that can be used to hear whether a sub is musical or not. By musical, we refer to the sub’s ability to articulate a full and complete low frequency response without sounding like “Uncle Bubba’s” insipid blowing on a moonshine bottle. We listened to countless hours of music for weeks on end in the evaluation of these two units – not exactly a chore in most people’s books.
image020_000.jpgThe Outlaw Audio LFM-1 had a smooth response for music that made some of my jazz/fusion albums, such as the Rippingtons’ Brave New World CD, sound fantastic. I kept listening for the powerful low end to become overbearing, or reveal a tainted frequency response indicating overcompensation in the LFM-1 as an attempt to achieve a more powerful 25Hz response. There was none. The Outlaw audio subwoofer provided the tightness required for the bass guitar’s quick attacks and rolled out smooth, rich tones for slower tracks like “First Time I Saw Her.” I was enjoying the performance so much I just had to flip over to an older album, Tourist in Paradise, and play the title track to hear how well the powerful kick and sub (which mirror each other nearly the entire song) came through from that mix. Again, the LFM-1 didn’t overshoot, but stayed controlled, tight and even throughout the entire dynamics of the song. If you want a musical sub – find one that doesn’t sound monotonous of overcompensate for low-end response. The Outlaw Audio LFM is a good example.
Objective In-Room Measurements
We did some in-room measurements of the Outlaw Audio LFM-1 and the SVS PB2-ISD subwoofer using the Rives Audio Professional Test Kit and I think the results are surprising:
The above measurement is a low frequency sweep test using the Rives Audio Professional Test Kit. It was taken with the output of the sound card fed directly into each subwoofer and the microphone placed at the listening position. The units tracked fairly closely, with the LFM providing a bit more overall power around 50-60Hz and the SVS extending better down into the 20Hz region. Room modes aside, both subs provided excellent frequency response at 60Hz and below, which is where the system crossover point was set during most listening tests.
Conclusion – What Does It All Mean?
At the end of this review I had finished listening to two incredibly different and unique subs. The LFM-1 from Outlaw Audio is a stellar value performer – but it doesn’t stop there. It held its own against a much bigger, more expensive competitor under normal use loads. Producing an incredible (almost unbelievable) amount of tactile energy during home theater and music use, the LFM-1 had me constantly checking myself to see if I had mistakenly left the SVS subwoofer connected. That kind of frequency response and performance out of a package that is nearly 50% less in volume and about 40% lower in price is something to be acknowledged.
The SVS subwoofer is a bit of an enigma. Not because of anything bad, but because the unit sounds incredible but has none of the space-saving characteristics commonly found on other units. Is it the lack of self-imposed space constraints that makes the sub sound so good? Or is there something else at work? Its performance can be described as flat and yes, even musical. I couldn’t find a serious limitation or flaw, save overdriving the unit while tuned for 16Hz. The SVS has almost limitless power for most applications and doesn’t suffer from any of the typical constraints associated with making a subwoofer that fits through doors or doesn’t require a crane operator to get it into your house (OK, it’s not that big!) My overall impression of the PB2-ISD was that I wished it could pack this punch into a smaller package – but I still never wanted to let it leave my room – and that’s a pretty big compliment.
For those of you who still think “boom is boom. It doesn’t matter who makes it...” I offer these two subwoofers to you for trial. I think you’ll be pleasantly surprised.
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
Bass ExtensionStarStarStarStar
Bass AccuracyStarStarStarStarStar
Build QualityStarStarStarStar
PerformanceStarStarStarStar
ValueStarStarStarStarStar
