Velodyne MicroVee Subwoofer Review
by Gene DellaSala last modified September 24, 2011
Velodyne MicroVee
Velodyne MicroVee
  • Product Name: Velodyne MicroVee Subwoofer
  • Manufacturer: Velodyne
  • Value Rating: StarStarStar
  • Review Date: January 11, 2010 21:25
  • MSRP: $ 799
Specifications
  • Driver: Active 6.5" forward firing anodized aluminum cone (5" piston diameter), 2 x 6.5" side-firing passive radiators with aluminum cones (5" piston diameter)
  • Magnet Structure: 64 oz. (4 lbs)
  • Voice Coil: 2" Dual Layer
  • Amplifier: (Class D) 2000 watts Dynamic power, 1000 watts RMS power
  • Low Pass Crossover: 50 Hz - 200 Hz (adjustable) (12 dB octave initial, 48 dB ultimate)
  • Frequency Response: 38 - 120 Hz (+/- 3 dB)
  • Inputs: Speaker-level, mini-jack and gold plated line-level Outputs: Speaker-level (120 Hz high-pass crossover), mini-jack (thru) Phase: 0° to 180° (selectable) Subwoofer Direct(Crossover Bypass)
  • Digital Dynamic Driver Control
  • Auto On/Off
  • Dimensions (H/W/D):(inc. grille) 9" x 9" x 9.6"
  • Warranty:(parts/labor) Electronics: 3 years / Driver: 5 years
  • Shipping Weight:(approx) 20 lbs. (9.1 kgs)
  • Finish: Black Anodized or White Specifications are subject to change without notice.
  • Small on size, big on sound
  • Excellent fit and finish
  • Touchy master volume control
  • pricey
Introduction
Velodyne has once again demonstrated it could provide the most amount of bass per square inch that the laws of physics would allow. I love seeing the reaction in my friends' and family's faces when they sit down to hear my computer system - not realizing there is a MicroVee sub hidden behind my trash can providing all the low end boom. It blended well with my desktop system, transforming its sheer depth and soundstage by providing the much needed low end extension my small speakers were incapable of producing. If your crammed for space and need some bass, give the Velodyne MicroVee a try.
Recent Forum Posts:
bandphan posts on January 12, 2010 05:29
Gene, although The Beatles I Want You doesnt slam, its a great song for clear bass passages
