You are here: Home Pro Reviews Speakers Subwoofers AV123 MFW-15 Subwoofer
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by Tom Andry last modified February 01, 2008
  • Product Name: MFW-15
  • Manufacturer: AV123
  • Review Date: February 01, 2008 13:53
  • MSRP: $599-$699 (real wood)
Specifications
  • System: Single driver, folded, slot port with front termination
  • Drivers: 15" custom woofer
  • Amplifier: Custom 350 watt high efficiency design.
    • Control: Easy-access top panel with gain, variable phase and crossover
    • Input:  High and low level in and out plus LFE in (crossover defeat).
  • Frequency Response: 18-200Hz; 15-17Hz in room low end.  Greater than 115dB output above 35Hz and 103dB max output at 20Hz at one meter.
  • Dimensions: (H x D x W):  23.94" x 22.44" x 18.125"
  • Weight: ship weight = 125 lbs each
  • 3 Year Warranty
Executive Overview
Some things are worth the wait, and if you're a fan of AV123 you've been waiting for the MFW-15 for a very long time. Well, the MFW-15 has finally been released and AV123 couldn't be prouder. The MFW-15 subwoofer is part of the next generation of subwoofers from AV123.com. The ~100 pound MFW-15 subwoofer, starting at $599 each, was designed from the ground up by AV123's Mark Schifter and renowned subwoofer guru Mark Seaton. The MFW-15 features a 25mm front baffle and plenty of bracing along with a custom designed 15” driver, 350 watt high efficiency design amplifier with separate control panel for Level, Phase and Low Pass Frequency at the top back of the cabinet and an internally folded slot port. The subwoofer is offered in beautiful Rosewood, Cherry, Black and the unique Moho.
According to AV123, you can expect 15-17Hz low end extension in most rooms and output of 103dB at 20Hz (1M measurement) and greater than 115dB above 35Hz (1M). All MFW-15’s are wrapped in a real wood veneer (via renewable resource) or finished in a silky-smooth satin black. The hand finished MFW-15 subwoofer should be right at home with fine furniture, and looks far more expensive than its price would suggest. And that is what excites us most - the price. At only $599 for one (satin black) or $998 for two we can see a lot of enthusiasts foaming at the mouth over this one. As we love to recommend dual sub setups, being able to point to affordable dual sub packages is always a big plus. The first units are shipping now.
For more information, please visit www.av123.com.
Recent Forum Posts:
mike c posts on March 06, 2008 19:47
autoboy;385106
Bummer. I just bought a SVS PB12-NSD. Now I want one of these. I've been very happy with my SVS, what can I expect with the MFW-15 over the PB12?
a longer wait?
seriously though, since both this and your SVS is tuned the same, you can probably expect just more output on the AV123 unit (having a bigger driver).
SQ wise, it's a toss up. (believe me, subjective opinions on subwoofers is so like choosing flavors of ice cream)
though if these were ex-stock ... I might be willing to try one ... or two.
autoboy posts on March 06, 2008 19:29
jaxvon posts on February 25, 2008 20:12
haraldo;380595
I'm actually a bit sceptical to these subs because, unlike all former AV123 subs, these are ported designs, and in my experience ported designs are slower and does not perform as well as sealed sub's
has Av123 compromised with their own design goals?
Regards
Harald N
A ported design should not worry you. It looks to me like AV123 used a large slot port design, meaning there should not be issues with port noise. As for ported subs being "slower", that is a common audio myth. A properly designed ported sub will offer greater efficiency and maximum output when compared to a sealed unit. Distortion and nonlinearity are more functions of the quality of the driver, not the box.
larry7995 posts on February 25, 2008 19:24
Thank you Vaughan and Larry
At first I thought I would save $300 but now I'm thinking for only $100 more I could get two. Decisions, decisions. Room is about 13x24x8, Maybe two would be overkill, I can't decide. Any thoughts?
Thanks
Mine is 11x14x8 and I definitely want two. My room already rocks with Axiom M80s.
haraldo posts on February 25, 2008 18:48
Regards
Harald N
