You are here: Home Pro Reviews Speakers Subwoofers Elemental Designs A7S-450 Subwoofer Review A7S-450 System Setup
by david last modified March 04, 2009
a7s450nogrill.jpgSetup began with opening the box and carefully rolling it over to lift it off the subwoofer. With a sub this size, don’t get some silly idea to try and lift it out of the box, the geometric reality is that the typical size of the human body does not provide the leverage to bend over a box this large and then lift a beast like this out. Oversized, chest beating contrarians may balk at my statements, but don’t complain to me of injured backs, broken bones, damaged subwoofers, or collapsed floors if my advice is not heeded.
I then rolled the sub upright onto furniture sliders, maneuvered it into place, and left it on the sliders. Carpet spikes be damned, this thing isn’t going to move significantly from the force generated by the reaction of mere acoustic emissions.
From this point on, everything is mostly subwoofer standard. Select an acoustically acceptable location: crawl for bass, take measurements, or play-it-by-ear, whatever suits your fancy, and then dial in the appropriate settings. With the A7S-450 used for an LFE channel, the correct signal input must be wired into the system for the crossover bypass and the crossover frequency is then set using preamp/receiver bass management functions. If the subwoofer is being used without bass management, dial in an appropriate frequency based on the roll off point for the accompanying main channels. Next, using a full range source signal, adjust the phase to the setting that produces the best integration with the main speakers which usually corresponds to the setting that yields the higher and steadier SPL output via a frequency sweep. Finally, manually adjust the volume level to balance the overall system frequency response and then use the processor functions for speaker setup to tweak the final output setting, either by ear or with an SPL meter or any other available measurement device.
The only difficulty that I found using the A7S-450 is that it kicked a 15 ampere circuit every time I turned it on. Untamed inrush current draw sucked all 15 amps out of the wall consistently without fail. The process of powering up the subwoofer typically involved at least one trip into the basement to reset the breaker as the capacitor took on power. The circuit kicked even when completely unloaded with every other electrical device on the circuit turned off, both from a fresh power up as well as when coming out of standby mode. As such, I am not sure that even a 20 amp circuit will slake the A7S-450 of its initial thirst.
For me, the current situation is temporary; my system will ultimately end up on a 20 amp circuit, but until then and for anyone who does not have a 20 amp circuit available, it will be a problem, especially for older fuse protected circuits. Considering I normally run the more powerful Fathoms from this circuit without issue, I consider the inrush current problem to be an oversight in the design of the amplifier. JL Audio makes a point of discussing current draw for home audio applications and specifically outlines their efforts to mitigate the problem as part of the amplifier design. It would appear that eD has some homework to do to correct this problem.
Equipment Used
I evaluated the A7S-450 subwoofer using my A/V setup with HD-DVD, DVD, and CD content reproduced using a Toshiba HD-A35 and a Sony PS3 for Blu-ray content. Audio processing and power amplification was provided for using a Rotel RSX-1067 driving a 7 channel Infinity Beta speaker array with bass management set at an 80 Hz crossover point. All source material used for the review was reproduced in its native format, multi-channel or stereo, with the Rotel set to two channel mode for stereo material and the Beta 40 towers engaged to reproduce the mid and upper frequencies.
Normally I prefer being provided two subwoofers for review as it is easier to minimize certain room acoustics issues directly, but for this review, I was sent a single unit. The advantage of multiple subwoofers is that they can be used to help limit modal coupling of bass frequencies to the room through judicious placement of the subs relative to the room, each other, and the listening position. I typically run dual subwoofers and shifting to a single sub presents an extra difficulty to sort out what is really coming from the sub and not from the room acoustics, which is best avoided if possible.
Editorial Note on Multiple Subwoofers
Multiple subwoofers are a good choice to smooth frequency response by minimizing room modal behavior through cancellation. Strategic placement of the subs at opposing nodal points for frequencies that trouble the listening area can be used to nullify the worst dips and peaks from the room modes. This is a distinct advantage over equalization, which can only trim peaks but not fill dips.
My own experience with running multiple subs has been a stark improvement with smoother frequency response, improved bass detail, and increased depth at the bottom end beyond what a single well placed sub can muster.
I am including several links where this topic is discussed in greater detail and also an Excel based spread sheet that calculates modes for a rectangular room:
Audioholics: Room Modes and Dealing with Them
Harman multiple subs
Getting the bass right
Harman Room Mode Calculator
As usual, I put my test specimen through a wide range of movie and musical content with some of the highlights detailed below. Overall, I found the A7S-450 to be a highly capable subwoofer, able to generate prodigious output. Despite its rather large size, it was a surprisingly subtle subwoofer. The brute didn’t stumble all over the musical details, bull in a china shop fashion, when reproducing more sublime bass content and it also kept enough composure to render musical subtleties even when more demanding LFE was also present. The subtle playback capabilities allowed the fairly large A7S-450 to disappear, sonically, into my system very effectively; it played deeply, loudly, and transparently, blending into my system extremely well.
Comparison of Subwoofers
I’ve recently had my hands on a number of subs in this price category, between $800-$900, that pushed a kilowatt or more output. Both the Sunfire HRS-12 and the Chrysalis Acoustics Photon-8 can be considered direct competitors at the price and comparable power specifications.
The A7S-450 bested both in terms of absolute performance as a subwoofer providing the greatest acoustic output capabilities and the least colored sonic signature. The tighter acoustic performance helped the A7S-450 to be the most sonically invisible of this group of subs and presenting the best sonic integration into my system. This is not to say that the other subwoofers are inferior in any way. The performance of these subs simply represents different engineering tradeoffs.
The A7S-450 is the least subtle design, sheer size gives it the upper hand against the HRS-12, and the extra 300 watts don’t hurt either, but it’s a close race and the considerably smaller sub still puts up some stiff competition for the much larger A7S. Appearance considerations will give the Sunfire sub the clear upper hand, as it will at least look decent with more upscale décor, having a much nicer pseudo-piano gloss finish.
The Photon-8 on the other hand represents the complete opposite design philosophy, and while the A7S can handily outdo the little guy in an absolute sense, the Photon-8 is an extremely impressive subwoofer after taking into account its very diminutive size. Some people may not want a sub as big as the A7S or simply do not have the room. The Phototn-8 is easily tucked away and it will still impress friends with a very convincing imitation of being a much larger sub than it is.
As for higher end competition, the A7S will not best subs of the caliber of the Fathoms, either in terms of output or in terms of musical accuracy. To my surprise, considering her relative apathy to my audio preoccupations, even my wife could tell the difference and preferred the Fathoms. But the difference should be tempered by considering the effect of diminishing returns for subs like the Fathoms: the $860 spent on the A7S will get one a disproportionate fraction of the Fathoms performance for the price.
The moral of the story is that every design has its pros and cons and there is a variety of competently designed subs available to satisfy different needs, preferences, and priorities. Everyone should temper the selection process with actual product auditions before making a purchase.
Overall, the A7S-450 is a good subwoofer, and excellent for the asking price, if the size is not an issue.
Recent Forum Posts:
TheFactor posts on May 19, 2010 18:02
croseiv;641641
yep, same here. Wait a minute, i did...:d
lol :d :d
darien87 posts on May 19, 2010 12:45
croseiv;533454
Sounds like they are just slapping a car subwoofer into a box...
But if it has a nice frequency response and sounds good, who cares? A sub's a sub right?
BufordTJustice posts on May 18, 2010 19:39
Seriously, the A7s-450 is a completely different sub (if you want it to be) when you use the eQ.2. Amazing performance from this thing since it has so much headroom. I has no limits in my open living room for my listening purposes. Amazing output down to 10Hz. Great dynamic impact for music. You can make it sound like whatever you want. Here is my review I posted for the one I own on eD's website:
I have had my A7s-450 for almost two weeks now. I begged the wife to let me get it as I already had an A2-300 that has worked wonders in our old, smaller living room. However, a new house meant more room and a higher ceiling...the A2-300 was struggling on some movie scenes that had the lowest bass (i.e, Master and Commander, Terminator, etc.) as I had to turn the gain higher than before, despite a corner location. I just needed to move more air.
I e-chatted with Brett to great effect; he was very knowledgeable from a design standpoint and had much insight into what was mechanically and electrically required from a subwoofer to accurately reproduce bass. I learned a lot and centered on the A5-350 15" ported and the A7s-450 18" sealed units. Brett helped me figure out how much air i needed to move (as in total driver linear displacement and the proper amp power to take advantage of it.) and the type of sound I was looking for for my music listening. We had an extremely productive chat and Brett was both very friendly and very professional. I was taken aback because it was much more like speaking with a friend on IM than a person I've never met in Iowa (I'm in Florida). His open-ness to share specific figures and specs on his products sold me. Having a background in live pro-sound mixing, I know enough to know that he did not BS me. Not even once. He didn't even try...he just knew his stuff inside and out. Then I pried it out of him....he had a direct hand in the actual DESIGN of several eD sealed subwoofers, to include the A7s-450. We talked turkey for about 15 minutes and then I let him go. NO pressure and he got ZERO info from me. There was no guarantee of a sale on his part...he just poured out the info.
Days later, I spoke with Matt over the phone, who was equally knowledgeable and helpful. I verified the free eQ.2 promo for the A7s-450 and ordered one over the phone. Wam, bam, thank-you-ma'am. No hassle and I was G2G.
I received it via, as always, free shipping. This sub was so big, I had to un-pack it completely just to fit it in my Hyundai Elantra (don't try this at home boys and girls). After a few sacrificial (and permanent) modifications to my front passenger seat, two little helpers at the UPS depot, I shoe-horned the beast in.
After getting it home and turned-on, it was a revelation; the sub just had no limits in my new living room. This was before tweaking via the included eQ.2 (a steal, I might add). I went to bed, perfectly happy with my purchase.
A few days later I found the time to fiddle with the eQ.2 Long story short, you can dial this sub to make it sound like whatever you want in your room. I've got the mid-bass shelved by about 6db from 60-65Hz on up and the low EQ centered on 25Hz with a Q of 2 and about 7 or 8 dB of boost. It's dynamic from barely audible night-time everyone-else-is-sleeping volume levels to neighborhood-rapport-destroying levels with Terminator:Salvation, Transformers II RoTF, and Master & Commander. Amazing output at well below 20 Hz. I test-toned it down to about 10Hz. Amazing. Just stupid levels of sound from this thing. It left me shaking my head at how low it went and still maintained its composure....it just kept getting louder and louder...I decided to stop testing as it was getting late and the sub just kept getting louder. I became legitimately concerned that it was going to break my sliding-glass-door as it was sitting not far from it.
Music performance is as accurate as I could ever hope. It's dynamic and impactful. It sounds great with Metallica, Anberlin, MuteMath, Diana Krall (her damn-near-perfectly recorded 'Live in Paris'), Van Morrison, Dave Brubek, AC-DC ('Shoot to Thrill' and 'Thunderstruck' will change your life using this sub), John Mayer, Michael Jackson, Jack Johnson, Black Eyed Peas, Red, Breaking Benjamin, Bach, Handel, U2, etc. It sounded great with everything I played through it...Once I got the levels dialed in, NO further adjustments were needed. I have never experienced this...it just disappeared and added depth and impact to what I thought were familiar recordings. Every song had added depth and the soundstage seemed HUGE....much bigger than the room....especially with live recordings (like U2's 'Live in Chicago' DVD). The eQ.2 adds so much versatility to this sub...they should be considered a pair. You can adjust the sub to even out your room response in so many ways, it would be worth the price of the upgrade (even though it's free now). Just amazing. I haven't heard ANYTHING any where near this price point that can even match this performance in a regular guy's living room. I do not have any sound treatments or other goodies...I have a wife who uses her magnifying glass about what the room looks like. The sub sounds so good, she even passes it now. She was able to clearly articulate that it sounds MUCH better than ANY theater she has ever been to. She said that anything that 'sounds this amazing' is okay in her living room, regardless of size. She watches romantic comedies with the sound system now because even she thinks it makes the closing of doors and city scenes seem more real. Who am I to argue?
I can whole-heartedly recommend this sub. The only thing I could imagine that would be better than an A7s-450 would be TWO A7s-450's.
gorillacooch posts on November 01, 2009 17:24
I am really pulling my hair out here, I think the A7-450 and the SVS PB-13 Ultra would be the best choice, but the only reason why I'm skeptical from buying the eD is the power rating. I"m using one 15 amp breaker for my bedroom, and my high powered gaming system, which uses 500 watts, and my xpa-5, integra dtc-9.8 and mirage OMD system, are all on the same breaker. So far it says I'm using 4.6 amperes on my power conditioner. When I game its at 7. I'm worried about using the eD cause of the 1300 watt draw. eD told me that it uses 500-800 watts on low to medium volumes. But still when you turn on the sub I'm worried about the large inrush that Audioholics mentioned. And electricians today are ripping people off like crazy just to install a 20 amp breaker, which only takes 20 min in my house to install. They want to charge something like $1000. which is ridiculous. But they quote me on the phone at 300 but then they see the house they say $1000. No offense but electricians aren't worth more than $50/hour let alone $1000 for 20 min. And this also includes me providing the breaker and the cable. So he's just charging me labor.
djreef posts on November 01, 2009 10:22
gorillacooch;641815
And buy a subwoofer that is one year into the warranty? If it was 1200 with shipping I'd say yes, but 1350? id rather spend the extra 350 and make sure i get my full 3 years.
Also 3 years doesn't really seem that long. If you look at eD they have a 5 year warranty. Now thats a warranty, that shows they really stand by their product.
That's true, but then I wasn't sure where you are. It could've been a short road trip. Then at $1200 it would've been a steal.
DJ
