You are here: Home Pro Reviews Speakers Satellite and Sound Bars Klipsch THX Ultra2 Loudspeaker System Review Klipsch THX Ultra Setup and Listening Tests
   Alabama
   Alaska
   Arizona
   Arkansas
   California
   Colorado
   Connecticut
   DC
   Delaware
   Florida
   Georgia
   Hawaii
   Idaho
   Illinois
   Indiana
   Iowa
   Kansas
   Kentucky
   Louisiana
   Maine
   Maryland
   Massachusetts
   Michigan
   Minnesota
   Mississippi
   Missouri
   Montana
   Nebraska
   Nevada
   New Hampshire
   New Jersey
   New Mexico
   New York
   North Carolina
   North Dakota
   Ohio
   Oklahoma
   Oregon
   Pennsylvania
   Rhode Island
   South Carolina
   South Dakota
   Tennesee
   Texas
   Utah
   Vermont
   Virginia
   Washington
   West Virginia
   Wisconsin
   Wyoming
by mark last modified December 07, 2006
Each carton was maneuvered to a spot on the home theater floor approximately where each speaker would eventually find its final location. Each item was quickly & easily unpacked and the cartons stowed away elsewhere.
There are a number of guidelines (many available online) which provide ample guidance for setting up a THX-certified home theatre system. In this case, you won't have to look far for setup "How to's" as the Owner's Manual provides all the basics in terms of properly arraying the speakers around your listening space. The actual final position for the various speakers making up the system was very much like that shown in Figure 9, with the exception of the two subwoofers: In the end they were positioned directly beneath the front L & R speakers. If you plan on mounting the KS-525s flush against the wall be prepared to carve out a relief cutout so as to accommodate the protruding binding posts.
Figure 9: Speaker disposition as suggested by Klipsch Manual
Editorial Note on Subwoofer Placement
Subwoofer placement can be a tricky business. Fortunately, there are readily available many resources - codified as recommendations, practices or standards 舑 to assist in choosing the best location for your sub Of course, there 舗 s always available the wherever-they-sound-best-to-you approach. But if you 舗 re interested in applying a more organized approach to subwoofer placement, have a look at:
Subwoofer Placement Guidelines
Subwoofer Calibration - The Place for Bass Part 1
For helpful information about THX in general see also:
THX Select and THX Ultra2 Certification General Questions
Listening Tests
Walk into a Hard Rock café or a Malco, Krikorian, Harkins, Clearview, United Artists, or Regal cinema anywhere on planet Earth and you will likely hear Klipsch systems in action. Go see a concert in an arena or stadium and you will hear horns in action. It seems quite sensible - the idea of bringing the horn-loaded systems technology used in commercial cinemas into a home theatre setting. How well does it work in practice?
The 5 DVDs (and CD) listed below were chosen from several dozen disks that were used during the course of the review sessions; each chosen because in one way or another they demonstrated various individual performance characteristics that when taken together conveyed a sense of the system's overall performance.
Top Gun , sounded like, well, Top Gun, a movie made twenty years ago. I happened to be living in southern California when the movie was first released and I saw it a couple of times in LA and Orange County.
At one point in the movie there's an audio scene where the sound of a fighter jet pans overhead, crossing the listening area. In those LA and Orange County commercial cinemas the pan sounded clear, focused and smooth. Another words, it worked. My experience has been that lesser systems tend to botch the pan, typically sounding like the jet simply faded out in one part of the soundstage and faded in at another, without the audible sense of it crossing smoothly between the two points.
I was particularly interested to see how the Klipsch system would handle the pan, specifically because
of the horns used in the systems - including the back & side surrounds. Horns are synonymous with controlled dispersion, yet current surround sound thinking indicates a diffuse sound field for the surround channels is essential for authentic rendering. It would seem that controlled dispersion and diffuse sound fields are a means contradictory to the ends. The Klipsch solution? Wide dispersion Sound Technology (WDSTTM). According to Klipsch, "By aligning two horns at 90° with respect to each other, along with a front-firing woofer, WDST surrounds smoothly cover a 180° horizontal arc. The surround points at you no matter where you are seated, drawing you into the middle of the action ." When put to the test, WDST worked and the Klipsch sailed through this challenge with ease; the pan was just as clear, focused and smooth as it was intended to sound.
The Hendrix DVD was chosen for the dialog that runs throughout much of the movie. Dialog can be quite a challenge for any speaker system; particularly so for those systems that make use of horns. Lesser quality horns (or even top quality horns used incorrectly) impart a nasally, honky quality to dialog. Occasionally you'll even hear this in theatres that otherwise deliver superb sound to the listener.
I didn't hear the Klipsch system impart any sort of annoying nasality or honkiness to any of the dialog at any point in the movie. This was, of course, in part due to the decent gear upstream of the speakers. But the lions share of credit needs to go to the Klipsch speakers. With a respectably smooth response, the judicious choice of crossover points (measurements below) and the functional abilities of a Tractrix horn, its understandable how a horn-loaded system could deliver such a high quality subjective impression.
The dialog was consistently natural, engaging, and very clean.
Top quality sound systems are ruthless in exposing poor quality media. Ask anyone who owns one and they will tell you how quickly such a system will reveal a particular recording's faults & flaws. Rush's R30 DVD is an example of just such a recording.
Prior to auditioning the DVD using the Klipsch system I had listened to it a few times on a very average system and the DVD sounded average; nothing especially good or bad about it. Played back on the Klipsch system and the impression was altogether different. The Klipsch revealed the audio tracks as sounding very, very heavily compressed, taking away much of the dynamics that are a critical part of the excitement of live entertainment - or attempts to reproduce the moment in a home setting.
Enjoy the Rails! is a CD that has lately become a favorite of mine for testing subs. It's an interesting disc, comprising a collection of well executed recordings of diesel locomotives, made at close range and with a bare minimum of processing. That's a combination likely to appeal to both audio purist and railroad enthusiast alike.
If you've ever stood beside railroad tracks as a diesel locomotive thundered by you'll be familiar with the earth-jiggling power of these mechanical giants. All the recordings contained in the CD were made at a distance of 1 - 3m meters and carry sustained, substantial amounts of just the sort of LF & ELF content that subs are made to reproduce. Even if you're not a railroad enthusiast, these are exciting recordings to listen to.
Played back through the pair of KW-120s, the tracks shook the immediate vicinity just as you'd expect a diesel locomotive to do if it were passing by a few meters away. There was an almost palpable "realness" to the sound filling the listening space and the subs quite capably defined the presence of those hundreds of virtual tons of heavy metal trundling through the room.
Of all the loudspeakers comprising the Klipsch THX Ultra2 system, the subs were the biggest surprise of all. They look so utterly civilized , yet when called to duty they can kick & roar with masterful authority. As capable as they are at dumping eye-popping amounts of acoustical energy into a listening space, they don't overwhelm or overplay as some subs tend to do. They don't butt in to audio scenes where they don't belong. They integrate seamlessly with the rest of the system and having two cabinets helps immensely when it comes to finding suitable placement when dealing with room modes.
Klipsch opted to build the power amp separate from the subwoofer cabinet; the amp is a stand alone unit that jacks into the subs via the supplied 6m (20') long, Neutrik Speakon plug tipped, cables (See Figure 5b).
Providing a separate power amp is a major convenience, and especially helpful for those who opt to build their system into the walls of their home theatre. Even if you have no plans to build your speakers into or onto the walls of your home theater, racking up the KA-1000 along your AV receiver provides other benefits: If you've spent too much time crawling around behind your sub tweaking this or that setting, perhaps by flashlight, you'll especially appreciate having the sub's power amp close at hand. No more hanging out behind your sub in that forgotten zone where dust, lost toys and the occasional house pet gather while you tweak away in search of the perfect splice.
The cable that comes with the subs is worth mentioning in further detail. They cables sport, as already mentioned, Neutrik Speakon plugs. I see these connectors used all the time in pro audio situations. This, however, is the first time I have encountered them in a home audio application. Excellent! The cable is made up of four 16 gauge wires, paired at the connector end, resulting in a very flexible 13 gauge cable.
The Neutriks are sturdy, pretty much foolproof, can handle prodigious amounts of current (30 A!) and feature self-cleaning contacts. This is yet another example of the nice (functional) touches found in the Klipsch Ultra2 THX system that help separate it from run of the mill products.
If I had only one DVD by which to review this system Eric Clapton's Sessions for Robert J. would be my choice. The DVD from the two disk DVD/CD suite thoroughly explores the outer reaches of the Ultra2 THX system's performance envelope, giving the system the chance to showcase its talent to the max.
Each of the four previously mentioned discs illustrated individual components of the system's performance abilities. The Sessions for Robert J . DVD would help provide the answer to the all-important, over-arching question: how authentic a reproduction is this system capable of delivering? All the right ingredients were certainly in place for the magic to happen once "Play" was pressed.
The Sessions for Robert J. DVD/CD suite is a collection of material originally written & performed in the 1930's by Robert Johnson, an American blues musician, now performed by Eric Clapton and company. The production values found in this compilation are excellent, as is the musicianship. The tracks were recorded at four separate locations, a recording studio in England, a studio in Irving, Texas, a now-abandoned film distribution building in Dallas and a beach front hotel room in southern California.
Once I'd gotten hold of a copy of the DVD it went straight to the top of my play list. Simply put, no other DVD gave the Ultra2 THX system the chance to show off its stuff like this one did. The collection of tracks done at the top of the DVD sounded so authentically lifelike when played back through the Klipsch that I found myself viscerally reacting as though I were sitting through the zillionth sound check of my sound guy career 舑 in my home theater!
Right at the top of "Sweet home Chicago" track they set hi-hat levels with Eric shouting instructions back to the board op as the drummer tapped out measure after measure of kick/snare/high-hat. I kept listening to that segment of the track over and over at levels typical for a band playing in a space the size of the studio it was recorded in. The more I listened, the more apparent it became the Klipsch speakers were reproducing a musical event, in a way, that at times, sounded closer to the real thing than I've ever heard a home theatre system do before. All the benefits to be gained in using horns - controlled dispersion, higher than average sensitivity and low distortion (so long as they're not pushed to hard) - came into play here and contributed to the authenticity of the moment. What a tremendous technical achievement 舑 hats off to all at Klipsch who played a role in designing and/or manufacturing this superb loudspeaker system.
Now what about the "so long as they're not pushed to hard" bit? Any horn, pushed too hard, will spray the listening area with obnoxious amounts of distortion. You've probably been exposed to just this type of horn-pushed-too-far distortion last time you saw an arena concert played through a too-small system, paired back, perhaps, to keep expenses down. If management deems it necessary to leave half a semi's worth of FOH (front of house) speakers behind then everything that's left has to work all the harder to keep levels up. Ouch!
What about the Klipsch horns? Yep, they can be pushed into the obnoxious distortion zone, but only when driven at levels no one would want to expose themselves to for very long. Go back and look at those sensitivity figures again - this system knows how to play REALLY LOUD and enjoy every minute doing so - without having to be pushed into the obnoxious distortion zone. Indeed, in all the dozens and dozens of hours spent listening to this system I never needed to push the system into that particular zone. It was so capable of playing so loudly and cleanly without being pushed beyond its limits.
