Atlantic Technology 1400 SR-z Height Speakers
1400 SR-Z |
Type |
Sealed-box dipole/bipole surround speaker |
Drivers
Woofer |
(2) 3-1/2" poly-treated full-range with HFAR |
Frequency Response |
110Hz - 20kHz +/- 3 dB |
Nominal Impedance |
8 Ohms |
Crossover Frequency |
N/A |
Sensitivity |
89dB |
Recommended Amplifier Power |
10-100 Watts RMS |
Dimensions w/
grilles |
12.25" x 8" x 5.375" |
Weight (each) |
7 lbs. |
MSRP | $425 /pr. |
Dolby ProLogic IIz is a brand new DSP that introduces height channels above your main left and right speakers. It has only recently started showing up on home theater receivers. The Onkyo TX-SR607 has just started hitting store shelves and already Atlantic Technology had a speaker optimized for th PLIIz processing. The 1400 SR-z (obviously the "z" refers to ProLogic IIz) is a selectable dipole/bipole speaker with a compact size and shallow profile. At just over a foot wide, less than half a foot deep, and 8" tall, they are definitely compact. They are only 7lbs each so hanging them shouldn't be much of a problem.
The idea of height channels is to widen the sweetspot, give a more
enveloping surround experience, and to make the front soundstage, well,
taller. Dolby recommends highly diffuse speakers that will not
be as localizable as direct radiators. These speakers, even more so
than surrounds and rear speakers, are meant to "blend" with your other speaker. They are not supposed to stand out. Atlantic
Technology took this into account with the 1400 SR-z. With only two
midranges (no tweeters) pointed at angles, they really are going for a
speaker that won't makes itself known and add to the speakers around
them. Atlantic’s High Frequency Assistive Radiator (HFAR) technology is
purportedly a "full range" 3.5 inch driver. While I'd take "full range" to
mean "as much of the range as we want," the specs on the speaker have
it dipping down to 110Hz from 20kHz. This is a claim I'd like to see
tested. While it may well do as it claims, linearity is the real question.
The cabinet on the 1400 SR-z's is sealed and voiced for the other
speakers in the Atlantic Tech line. They also claim that the speaker
can be used as a surround or rear speaker but from the specs, I'd
suggest limiting them to height or rear duties. A surround speaker
definitely is going to need to be a little more robust than two 3.5"
drivers. We also recommend something that will at least dip down to 80Hz as per the THX recommendations. The rear of the speaker sports a pair of binding posts (spring type) and a
single keyhole mount. There is a threaded insert at the bottom but it
is unclear if there will be some sort of proprietary mounting system
included or not. The single keyhole is concerning as it isn't the most
stable connection and could lend itself to movement during more robust passages. Plus, it is only one connection point! I don't know about you but a 7lbs speaker should be on two. At least.
Selectable di/bipole is a nice addition to this speaker. Bipole
(both drivers firing in phase) and dipole (drivers firing out of phase)
have different uses. Generally, surrounds will benefit from the dipole
setting as it tends to create a more diffuse surround effect. The rears
and most likely the height channels may lend themselves toward the
bipole setting based on their placement relative to the ear of the
listener. Each speaker is marked Right or Left with an arrow pointing toward the side that should be facing the front of the theater when using the Dipole setting. This
is interesting in that it seems to suggest that the dipole setting is
mostly for side placement (though instructions in the manual may be
different). As always, experimentation with these settings is
encouraged.
I have to say I'm surprised to see a dedicated height speaker out so
soon for the Dolby ProLogic IIz format. Of course, this speaker could
have been in development for years since Yamaha has long employed such
speakers. They could have just been waiting until one of the other
manufacturers caught on and did the same or for someone like Dolby to
make a brand neutral DSP. Regardless, the 1400 SR-z seems to be
perfectly designed for its duties. Whether it will hold its own as a
surround speaker is another question entirely. The big issue is if the
consumer will latch on to these new height speakers (not just Atlantic
Tech's, but the concept in general). Since they are in the front of the
room, the chances seem much better since wires won't have to be run
under carpets or in attics.
For more information, please visit www.atlantictechnology.com.
